Re: Bendpak lifts, anyone have one?
[Re: Guitar Jones]
#2905636
04/03/21 01:38 AM
04/03/21 01:38 AM
Posts: 21,704 N.E. OHIO, USA
A12
N.E. OHIO, USA
A few years ago I told my friend that I was thinking about getting a low ceiling garage lift and he said save yourself a lot of time and start by looking at a Mohawk Lift and work from there. Click on "Feature Images" Here: Feature Images How they are Made In USA https://mohawklifts.com/library/How_2Posts_Lifts_Are_Made.pdf https://mohawklifts.com/automotive-lifts/2-post-lifts/a7/If you look at the comparison of features it's hard to not think about maybe spending a little (or is that a lot?) more? Dang the Mohawk lifts are built to a little higher grade.....but you pay for what you get as always. Not saying the Bendpak lifts are not worth their price, in fact I was considering a Bendpak all along and might end up with one if I can't figure out how to get the Mohawk.
[Re: A12]
#2905667
04/03/21 08:55 AM
04/03/21 08:55 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
Question, are Bendpak cable raising lifts? Yes, with two redundant cables.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: moparx]
#2905793
04/03/21 01:03 PM
04/03/21 01:03 PM
Posts: 6,264 ohio
ruderunner
ohio
If you can't raise the roof, you might lower the floor.
Angry white pureblood male
[Re: ruderunner]
#2906187
04/04/21 12:22 PM
04/04/21 12:22 PM
Posts: 20,272 north of coder
moparx
If you can't raise the roof, you might lower the floor. i have considered digging a pit, but as i live on a hillside, i'm concerned about how ground water flows here. and if i lower the floor, i will be below street level with a steep incline to the street, as the street is just over 1 1/2 car lengths from the garage.
