Best for last....she hits a .023 like...other guy is .000,,,,,Dart slows 10.29 on a 10.20 dial...and then...and then...she accidentally downshifts in 2nd gear...at 127 mph,,,,old 904 is pretty tough....and 4 flat spotted tires....
i never realized you moved the typewriter to where the heater control used to live ! what was involved doing that ? are the factory cables long enough, or did you have to have custom ones made ? GREAT run by the way !
Re: In car Videos-Post them up
[Re: Bad340fish]
#2906307 04/04/2102:28 PM04/04/2102:28 PM
Cables fit fine. New holes in the firewall. New bezel from the heater to the shifter was the trickiest. Cut two apart and made one. The only reason was because the cage tubes were in the same area as the shifter. Doug
[Re: dvw]
#2906558 04/04/2109:00 PM04/04/2109:00 PM
That is a slick setup, Doug! Glad you are still using the old typewriter keys. A buddy of mine here still uses them, too, in a 64 Plymouth that runs mid tens and wins all the time! The youngsters look in there and don't get what they are looking at!
"Old age and treachery trumps youth and enthusiasm, every time!"
