Page 42 of 48 1 2 40 41 42 43 44 47 48
Re: Modern Bullitt build [Re: Keepat] #2912733
04/21/21 05:44 AM
04/21/21 05:44 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Nice work Pat!
What are you using to weld the aluminum brake duct scoops? Spool gun in a MIG?
Re: Modern Bullitt build [Re: larry4406] #2912745
04/21/21 07:41 AM
04/21/21 07:41 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by larry4406
Nice work Pat!
Larry, Easy to mistake my ugly welds for a spool meg welder;-) but I’m slowly getting more comfortable with TIG welding as long as I know I’m going to grind and polish the welds down;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2912944
04/21/21 02:55 PM
04/21/21 02:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Pat your wheel opening stainless moldings are they original or reproductions? If reproductions what company and how did they fit? Thanks.
Re: Modern Bullitt build [Re: NITROUSN] #2912961
04/21/21 03:20 PM
04/21/21 03:20 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
They are original, just needed a little massaging and a good polishing. I think there are 2 manufacturers for them 1 bad and 1 ok.
Good luck!
Pat
Re: Modern Bullitt build [Re: Keepat] #2915520
04/27/21 05:40 AM
04/27/21 05:40 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Mounted the front bumper, and painted & installed the front brake air ducts. The air ducts are inconspicuous painted black.
Pat
Re: Modern Bullitt build [Re: Keepat] #2916310
04/28/21 09:34 PM
04/28/21 09:34 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Man I'll say they do. Very stealthy.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Modern Bullitt build [Re: DynoDave] #2916739
04/29/21 09:24 PM
04/29/21 09:24 PM
Vancouver,BC
Mopar300F Offline
Mopar300F  Offline
Vancouver,BC
I can’t help but think that you could have used the signal light opening for your duct work, build a faux screen that looked like a lens and built an led light into them.
Re: Modern Bullitt build [Re: Mopar300F] #2918869
05/05/21 01:16 PM
05/05/21 01:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The repro parking light fit and look much better then the ones I used 15 years ago on my 1st Charger.
Pat
Re: Modern Bullitt build [Re: Keepat] #2920520
05/09/21 07:47 PM
05/09/21 07:47 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Short running video
https://youtu.be/h2o71VuaD2E
Re: Modern Bullitt build [Re: Keepat] #2920582
05/09/21 11:10 PM
05/09/21 11:10 PM
Medford OR
FrankenScamp Online happy
FrankenScamp  Online Happy
Medford OR
Sounds killer!!! Love it..... beer
Re: Modern Bullitt build [Re: FrankenScamp] #2920943
05/10/21 09:25 PM
05/10/21 09:25 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir!
Pat
Re: Modern Bullitt build [Re: Keepat] #2923817
05/18/21 08:16 AM
05/18/21 08:16 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The reproduction Map pocket cufflinks did not look as nice as my originals (3rd pic) Unfortunately removing the originals doesn’t leave enough of the stud to reattach to the new panels. So I used my Weld Mount studs and epoxy on longer threaded studs making the cufflinks installation very simple. I think the 68 map pocket is a little big for today’s maps;-)
[Linked Image]pj
Re: Modern Bullitt build [Re: Keepat] #2924191
05/19/21 12:10 AM
05/19/21 12:10 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I have not heard of weld Bond before. Nice work on those though.
DynoDave
Member # 12304
Re: Modern Bullitt build [Re: DynoDave] #2924400
05/19/21 01:20 PM
05/19/21 01:20 PM
Vancouver,BC
Mopar300F Offline
Mopar300F  Offline
Vancouver,BC
Where did you get the map pocket chrome squares. I did my interior 10 years ago and Legendary no longer had them.
Paul
Re: Modern Bullitt build [Re: DynoDave] #2924666
05/19/21 10:02 PM
05/19/21 10:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thanks!
Re: Modern Bullitt build [Re: Mopar300F] #2924667
05/19/21 10:04 PM
05/19/21 10:04 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Paul
Year One sells the repro map pocket chrome squares!
Pat
Re: Modern Bullitt build [Re: Keepat] #2924668
05/19/21 10:05 PM
05/19/21 10:05 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Legendary‘s carpet set fits great with a few modifications and the addition of some foam to fill the gap around the modified shifter tunnel. It’s nice that they make this carpet extra long at the firewall so you cannot see any of firewall. Just letting it relax for a few days with a some 25 pound lead bags.
Pat
Re: Modern Bullitt build [Re: Keepat] #2924990
05/20/21 07:43 PM
05/20/21 07:43 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
You never disappoint Pat!
Re: Modern Bullitt build [Re: larry4406] #2926163
05/24/21 01:23 PM
05/24/21 01:23 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I decided to reuse the original door sills. The repro‘s don’t look as nice as the originals after polishing, even with a few dents and scratches.
Pat
Re: Modern Bullitt build [Re: Keepat] #2926176
05/24/21 02:13 PM
05/24/21 02:13 PM
Vancouver,BC
Mopar300F Offline
Mopar300F  Offline
Vancouver,BC
As a serious 68 fan and Bullitt Charger owner myself, this is the most amazing Charger I have ever seen. Been following the thread for 5+ years and am anxiously waiting to see the final result. Next up would be seats. Bone stock or modified?
