Page 2 of 3 1 2 3
Re: New Headers [Re: Leigh] #2904077
03/29/21 06:33 PM
03/29/21 06:33 PM
MN
JERICOGTX Offline OP
MN
Originally Posted by Leigh
Originally Posted by JERICOGTX
Originally Posted by greendart408
Now the tig welding, I'm not sure about you but that's my fav part.
I enjoy TIG welding, but I'm lucky enough to have a coworker that is WAY better then I am at it, willing to weld them up for me. A man has to know his limitations.
They look great. If the National Geographic photographer is doing the finish welding, will he be back purging?
Yes they are being back purged. Leigh, do you know a coworker of mine?
69 GTX 68 Road Runner
Re: New Headers [Re: JERICOGTX] #2904092
03/29/21 07:13 PM
03/29/21 07:13 PM
gregsdart Offline
gregsdart  Offline
Looking great Jeff!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: New Headers [Re: gregsdart] #2904131
03/29/21 09:30 PM
03/29/21 09:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Good looking set of tubes! You are much more patient than I.
Re: New Headers [Re: slantzilla] #2904138
03/29/21 09:50 PM
03/29/21 09:50 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Now I want a set!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New Headers [Re: hemi-itis] #2904153
03/29/21 10:29 PM
03/29/21 10:29 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Awesome job !
Having been down this path , I have some idea.
But I have an AlterKtion and 1 7/8" tubes , so maybe I have no idea. LOL
Really nice work.
Re: New Headers [Re: tubtar] #2904248
03/30/21 09:51 AM
03/30/21 09:51 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks awesome Jeff!
Re: New Headers [Re: Leigh] #2904256
03/30/21 10:20 AM
03/30/21 10:20 AM
Las Vegas
Al_Alguire Offline
Happy Birthday Al_Alguire  Offline
Las Vegas
They look awesome!!
Re: New Headers [Re: JERICOGTX] #2904266
03/30/21 11:15 AM
03/30/21 11:15 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Nice work.
Re: New Headers [Re: DusterKid] #2904424
03/30/21 09:37 PM
03/30/21 09:37 PM
IL
furious70 Offline
furious70  Offline
IL
Doing a single 2.5" -> 3" per side for the turbos on my Fury was bad enough, can't imagine fitting those in there.
Not in the 'did it wrong' category, but from curiosity and my own battle with the T bars, did you first try to avoid trapping them or is there no way with that size pipe?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: New Headers [Re: furious70] #2904441
03/31/21 12:17 AM
03/31/21 12:17 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Beautiful work, Jeff. Now to complete the journey and without worry of damage, build yourself some header/pan "savers" under each side of the car. Simple to do, and you will thank yourself later bud. Here's what Team Z sells, but you can make your own to fit how you like. Unless of course you already have a set installed.
Wes
[img]http://www.teamzmotorsports.net/product_p/tzm-wsop.htm[/img]
"If you can still hear your fears - shift a gear."
Re: New Headers [Re: furious70] #2904461
03/31/21 05:14 AM
03/31/21 05:14 AM
MN
MN
I could have made them like TTi Headers, but didn't see any reason to do so. Since these pictures were taken, I cut the tube going around the torsion bar, and welded in a V band clamp. makes it super easy to install. I can install the headers with the engine in place. On the driver side, I'll be putting in a t lest 2 V band clamps. One for the header going around the torsion bar, and another to remove a tube, to easily change a starter if I have to.
Wes, my K member is shaped just like what you posted. The headers actually don't hang down as much as my old Hooker Headers.
Re: New Headers [Re: JERICOGTX] #2904465
03/31/21 05:30 AM
03/31/21 05:30 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Supersonic indeed!
Now for the questions?
What car is they on ( 69 Gtx or 68 runner ) and why SO BIG?
If an exhaust valve is approx. 1.81 diameter in a good wedge motor then 2.00 ‘OD’ pipe should be plenty?
Would this design work my 71 Gtx (512, 440-1) and how much for another set ( please ) lol...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: New Headers [Re: Gtxxjon] #2904472
03/31/21 06:00 AM
03/31/21 06:00 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Originally Posted by Gtxxjon
Supersonic indeed!
Maybe 1-7/8 od is ok too in most cases, or am I missing something???
563 CID and 440-1 CNC 345 heads, I don't know the specifics of the build but that foundation can easily make well over 800 horse. Regardless of the valve size his headers are not too big.
As far as 1-7/8" headers, I don't think I'd run them on anything more than a warmed 383
Re: New Headers [Re: Gtxxjon] #2904494
03/31/21 08:19 AM
03/31/21 08:19 AM
MN
MN
Supersonic indeed!
These fit my 68 Road Runner,
As for building a set for someone else, I just can't do it. One is time, and the other is I have a coworker do the final welding. Not that I couldn't do it, but I don't want that pressure.
Re: New Headers [Re: JERICOGTX] #2904750
03/31/21 08:37 PM
03/31/21 08:37 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Originally Posted by GTS340
Those turned out really nice!
Should we start a pool to bet on how long before one of the resident geniuses comes along to tell you what all you did incorrectly?
Shouldn't take too long.
haha.....They do look nice tho, but i have a question did you you tack them with mig and then have them tig them up? I can't imagine how hard it would be to fab your own headers. I thought of building a set of turbo headers once tho.
Re: New Headers [Re: racerx] #2904820
04/01/21 05:05 AM
04/01/21 05:05 AM
MN
MN
I tacked them with a TIG. Sometimes in the car, and most time's I'd mark the piece, and lay it out on a table, and tack it, retest fit everything.
Re: New Headers [Re: JERICOGTX] #2909372
04/12/21 07:24 AM
04/12/21 07:24 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice fab work!
Re: New Headers [Re: JERICOGTX] #2909458
04/12/21 11:47 AM
04/12/21 11:47 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Already seen a few times on the phone, but looks even better on a larger computer screen.
Not many will attempt this. Hats off to ya.
Rich H.
Esse Quam Videri
Re: New Headers [Re: ZIPPY] #2909468
04/12/21 12:18 PM
04/12/21 12:18 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Looks good! Lots of work went into those, I'm sure.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: New Headers [Re: Hemi_Joel] #2909488
04/12/21 01:42 PM
04/12/21 01:42 PM
MN
MN
Thanks everyone. I'm almost finished with the headers. The passenger side is 100% complete, and I just need to weld in my EGT bungs, and add a couple V band clamps to the drivers side header, and they are complete. I'm more than happy with how they turned out. Even if they do not make 1hp over my 2" Hookers, I'll still be happy, as they fit, and will not rust.
Page 2 of 3 1 2 3
