2010 5.7 valves ? #2903534
03/28/21 09:44 AM
03/28/21 09:44 AM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
I have a 2010 power wagon with a 5.7 and the valve tips are worn and the heights are all over the place.
I am getting the heads rebuilt soon and would like to have the valves replaced with better quality parts.
Does anyone have a recommendation on good quality replacement valves with hardened tips?
Re: 2010 5.7 valves ? [Re: mk_] #2903588
03/28/21 12:29 PM
03/28/21 12:29 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Just out of curiosity, did you price compare edelbrock heads new to your recon'd units?
Re: 2010 5.7 valves ? [Re: moparjim79] #2903620
03/28/21 01:34 PM
03/28/21 01:34 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Hi, not yet but that may be something I should check into
Re: 2010 5.7 valves ? [Re: mk_] #2903641
03/28/21 02:07 PM
03/28/21 02:07 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I think you'll find the cost of new and improved heads o er the refurbished job you seek will surprise you, and no worrying about valve seats either.
Re: 2010 5.7 valves ? [Re: moparjim79] #2903844
03/29/21 01:04 AM
03/29/21 01:04 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
couple hundred springs $200 new factory springs usually last at least 150,000
couple hundred fer valves $200 new factory valves usually last 200,000
resurface at my local machine shop $140
valve job $200
valve seals $30
Total is under $800 and I don't worry about valve seats, the only time they fall out is if the engine gets very hot and an eddy would do the same thing and they still need checked over by a machine shop first.
Re: 2010 5.7 valves ? [Re: HotRodDave] #2903873
03/29/21 06:41 AM
03/29/21 06:41 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
valve job $200
valve seals $30
That gives everyone a good idea about a factory direct replacement type rebuild. He did ask for better valves though. If he is not putting these on a built motor I think they would be fine right out of the box for his application.
Re: 2010 5.7 valves ? [Re: moparjim79] #2903990
03/29/21 01:20 PM
03/29/21 01:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
valve job $200
valve seals $30
My next step up would be to find a low mile set of BGE heads then... they have better valves, better aluminum, better flow and still a lot cheaper than eddelbrocks and yes, they clear 5.7 bores. Should be able to buy a pair, inicluding shipping and machine .030 off to keep compression close for round $1100 total.
Re: 2010 5.7 valves ? [Re: HotRodDave] #2908035
04/08/21 02:22 PM
04/08/21 02:22 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I believe the valve seat dropping problem ended with the introduction of the Eagle heads in '09.
Re: 2010 5.7 valves ? [Re: John_Kunkel] #2908073
04/08/21 03:43 PM
04/08/21 03:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I torn apart by now at least 100 of these, seen 1 eagle drop seats, probably a dozen pre eagle and every. single. one. of them showed blue, and scuffed cylinders, warped heads, some even have melted plaz tech intakes. They all come from vehicles that also have leaking water pumps or radiators, you would think after building water pumps and radiators for 100 years they would finger out how to make em last longer.
Re: 2010 5.7 valves ? [Re: HotRodDave] #2908324
04/09/21 08:44 AM
04/09/21 08:44 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Agreed on waterpumps. When buying a modern hemi powered car, they should throw a new one in with the spare tire. I have had to put 1 on every hemi powered car ive bought. Its an easy job, but it still costs money.
Re: 2010 5.7 valves ? [Re: moparjim79] #2909212
04/11/21 08:23 PM
04/11/21 08:23 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
People ought to be watching their temps also. I've not noticed a lot of early water pump failures at work and our cars are idling a lot. Particular years of bad water pumps?
Facts are stubborn things.
Re: 2010 5.7 valves ? [Re: HotRodDave] #2909296
04/11/21 10:34 PM
04/11/21 10:34 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
valve job $200
valve seals $30
Good info...... I am going to get my heads redone with new springs, guides, seals, and hopefully better quality valves with hardened tips if I can figure out who offers them.
Re: 2010 5.7 valves ? [Re: mk_] #2930638
06/06/21 09:42 PM
06/06/21 09:42 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I have a 2011 ex police car that my son drives. I put a cam in it last winter and found all the valves beat up. I disassembled the rockers and found that some of the holes in the rocker bodies had worn shut. I replaced all the rocker assemblies and noticed they updated the rocker bodies to have chamfered holes just an FYI.
Re: 2010 5.7 valves ? [Re: biff426] #2930647
06/06/21 10:01 PM
06/06/21 10:01 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
[b][/b]
Yes I installed the new rockers and they helped some but the tips of the valves show wear.
I just bought a set of SI stainless valves with hardened tips and will get the heads done shortly.
Re: 2010 5.7 valves ? [Re: mk_] #2930729
06/07/21 12:05 AM
06/07/21 12:05 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
SSAHfan, would mind sharing the approximate cost for the SI valves?
Re: 2010 5.7 valves ? [Re: HotRodDave] #2930731
06/07/21 12:13 AM
06/07/21 12:13 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
HotRodDave, do you have a vendor you could suggest that sells a pair of Apache heads for $1100.00? One other quick question. Since the Apache head flows more than the Eagle head, would the ports be too big for a stock displacement 5.7? Not implying they are, just something I've wondered about.
Re: 2010 5.7 valves ? [Re: Wailin D] #2930866
06/07/21 12:56 PM
06/07/21 12:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Carpart.com, tons of them on there
Re: 2010 5.7 valves ? [Re: HotRodDave] #2931437
06/08/21 08:17 PM
06/08/21 08:17 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Apache head is the 6.1?
Re: 2010 5.7 valves ? [Re: larrymopar360] #2931447
06/08/21 08:32 PM
06/08/21 08:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Cylinder heads
Apache is 6.4 SRT8
BGE is identical to apache but better metal and comes on truck 6.4 (and I think on latest SRT8s)
6.1head is just called 6.1 head
5.7 03-08 is called the early 5.7 head
09-now 5.7 is called the eagle head
Engines
03-08 5.7 is early 5.7
09-now 5.7 is called eagle 5.7
6.1 is just called a 6.1
BGE is 14-now truck 6.4
SRT8 6.4 is 11-now Car suv 6.4 (Again I think the SRT8 6.4 has now switched to using BGE block and heads somewhere along the way)
Re: 2010 5.7 valves ? [Re: HotRodDave] #2931508
06/09/21 12:05 AM
06/09/21 12:05 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Thank you!
