Ebay Power Washers? #2902564
03/25/21 05:46 AM
03/25/21 05:46 AM
Super Spudsville
Mr PotatoHead Offline OP
Half Baked
Half Baked
Super Spudsville
Anyone roll the dice on the $100 ebay power washers?
The you tube vids show they seem to work ok, crazy they seem to pull 1800 watts when spraying. Many old places are not set up for that.
Id not expect it to have a long service life.
Mainly just looking for a way to blow the dust off the SRT black rims since here in the dust bowl the fine dust is semi abrasive to just use a brush and soapy water.
TIA!
STOP POTATO HATE!
Re: Ebay Power Washers? [Re: Mr PotatoHead] #2902629
03/25/21 11:07 AM
03/25/21 11:07 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Guys I know that have bought the cheap ones always end up breaking some plastic fitting that's unobtainable.
Maybe just check around for a good used one ?
1800W ?! Wow. Older ones I've used worked fine at a '50s house with 110V.
Re: Ebay Power Washers? [Re: Mr PotatoHead] #2902640
03/25/21 11:28 AM
03/25/21 11:28 AM
5thAve Offline
5thAve  Offline
I don't know what the ebay ones are like but I bought a cheap electric one around 20 years ago and it still works and does everything i need it to. I'd by local over ebay at least if it has pressure problems or doesn't work right you can return it easier.
Re: Ebay Power Washers? [Re: 5thAve] #2902644
03/25/21 11:34 AM
03/25/21 11:34 AM
KY
65pacecar Offline
65pacecar  Offline
KY
I bought a HF one about 7 years ago and it still works great for what I need. No issues.
Re: Ebay Power Washers? [Re: 65pacecar] #2902664
03/25/21 12:32 PM
03/25/21 12:32 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If you have to string a hundred feet of cord to clean your project without flinging poo all over the side of your house, it's not going to put out it's maximum.........and a $100 washer is going to need all the power you can get to it.
Gas washer. Use it anywhere. Pick one up on Craigslist that "starts but won't stay running" (clean the carb) for fifty dollars. twocents
Mo' Farts
Moderated by "tbagger".
Re: Ebay Power Washers? [Re: Grizzly] #2902791
03/25/21 07:49 PM
03/25/21 07:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My wife bought one of those on line power washers. It worked great for cleaning about 1/2 of the siding on our house, then the water started coming out of the handle. I got the job done, but towards the end, there was more water running down my arm then was coming out of the pressure end.
The next one my wife bought was a cheap one from HF, it did the house, and still works, and was cheaper then the online washer was.
The online washer had a much nicer soap dispenser and also had a longer wand which made cleaning the higher places much easier, too bad it died so soon.
If there is a HF store near you, I'd buy one from there before I'd buy one on line, at least when the HF one dies, you have someplace to take it to and get another one "just like it". Gene
Re: Ebay Power Washers? [Re: poorboy] #2902917
03/26/21 09:35 AM
03/26/21 09:35 AM
Richmond, Indiana
19swinger70 Online work
19swinger70  Online Work
Richmond, Indiana
I have a cheap, electric Harbor freight power washer that so far has lasted 4 years. I use it for quick, lighter duty washing. (easier for the wife to use as well)
I do have a gas unit for the heavy jobs.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Ebay Power Washers? [Re: 19swinger70] #2902925
03/26/21 09:43 AM
03/26/21 09:43 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Thanks for the feedback. Looks like it will work for no more then im gonna do.
Ive had a steam cleaner for 35 years thats diesel powered and has the water coil in the fire blower area that will strip the paint off a tractor or clean a semi block in short order, its nuts but its not car friendly.
STOP POTATO HATE!
Re: Ebay Power Washers? [Re: Mr PotatoHead] #2902964
03/26/21 11:14 AM
03/26/21 11:14 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Back when I wanted one , I looked at the electric ones and decided it wasnt worth the risk. For a few dollars more . I bought a gas one from Tractor supply about 6 or 7 years ago. Still works perfect. But was about $250
the best I remember its something like 2800 psi
