Re: My 63 Dodge 330 Project:
[Re: carnut68]
#3010767
01/31/22 09:44 AM
01/31/22 09:44 AM
Posts: 4,888 Wichita
GY3
Wichita
I'm pulling apart the 505 this winter for a health check. No issues with it but after beating on it fairly regularly, I'm thinking I should give things a once-over. While It's apart I'm putting in .027 Cometic head gaskets to replace the .060. It should bump compression up near 11:1. Hoping to gain around 30 HP or so from the change. I will probably upgrade the main fuel line and pickup in the tank to 3/8" as well while the engine is out. Goals are: 10.99 N/A 9.99 with the 250 shot Drive it to the track and home. All through the mufflers and on street tires. The pump gas thing may be out the window. Have you considered E85? changes sound good....Just be careful approaching that 300 threshold, it may like more retard than you expect. It all depends on how early the exhaust is opening. Just for comparison i would do a cranking compression test now, and after the changes. Then pump it every time you race. You will really be able to keep track of the engines "health" that way I considered E85 when I first built the engine and talked myself out of it. Availability, hassle, larger fuel system, etc. Very good idea on the compression check! I would stay away from race fuel since you street drive. Race fuel is a hassle just keeping jugs filled and or dealing with buying in a drum. I'm going from 10.3 to 11:1. It ran fine with the cheapest pump gas before at 36° total timing. I have stations that carry 91 octane fuel so that coupled with the fact I can pull timing with the turn of a dial, I'm sure it will be fine. The race gas will be in the nitrous stand alone cell (and maybe a little in the main tank) for those nights that I'm e.t. chasing at the track. Cometics are re-usable so if I don't like the higher compression, I'll just swap back to the .060 gaskets.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#3011175
02/01/22 02:28 PM
02/01/22 02:28 PM
GY3
Wichita
I pulled the engine out and started disassembly this past weekend. Nothing out of the ordinary and the bearings in the one main cap and rod cap I pulled looked really good. The main caps looked really good for what I put this thing though as I fully expected to see some transfer marks or "fretting" and it was very minimal.
'63 Dodge 330
[Re: GY3]
#3017783
02/22/22 04:33 PM
02/22/22 04:33 PM
GY3
Wichita
Pulled it down the rest of the way yesterday and installed new rod bearings. Shortblock is assembled and ready to go.
'63 Dodge 330
[Re: DynoDave]
#3024568
03/16/22 12:44 PM
03/16/22 12:44 PM
GY3
Wichita
Dumped the engine back into the car last night. Should be ready to rock this weekend!
'63 Dodge 330
[Re: GY3]
#3025805
03/20/22 04:59 PM
03/20/22 04:59 PM
GY3
Wichita
Back running and sounding crisp!
'63 Dodge 330
[Re: GY3]
#3044784
05/24/22 08:12 AM
05/24/22 08:12 AM
GY3
Wichita
After some self-induced issues with oil pressure and ending up with WAY too much, I went back to a stock spring in the oil pump. It comes close to sucking the pan dry with 7 quarts in the pan at the end of the 1/4 mile as it is with a stock spring. 75 psi cold idle and 45-ish warm idle now with .002 bearing clearance on the rods.
Shook it down by driving it around Sunday and drove it to work yesterday.
Just adding 7/10 of a point of compression made a difference. You can tell it's a little snappier and a little crisper. Hopefully the track #'s bear that out, but after getting used to the sound and feel of it over the last 6 years, it is definitely different.
'63 Dodge 330
[Re: GY3]
#3049066
06/09/22 07:18 AM
06/09/22 07:18 AM
GY3
Wichita
We did a Wednesday night test and tune at the track to make sure all was good before the Midway Drags nostalgia event this weekend. I had way too much timing pulled to be safe so the first couple of passes on nitrous were popping going down the track. By the time I got the timing corrected, the bottle was getting low (only brought one with me). With really sketchy prep, it still pulled off a 10.69 @ 131.7 mph popping and banging in the 60 ft. With me adding timing on the fly. LOL! Mph was about the only way to tell what was going on with no traction, but it went with 1 mph of the 133 best it has done, so pretty happy.
The DA was 3200 when we got there so not great, either.
It was a great shakedown with no issues.
'63 Dodge 330
[Re: B1duster]
#3050005
06/12/22 05:53 PM
06/12/22 05:53 PM
GY3
Wichita
Awesome build ! Which Howard’s cam are you using ? Thanks 235/241 duration at .050, 545 lift hydraulic roller.
'63 Dodge 330
[Re: GY3]
#3056596
07/06/22 10:13 AM
07/06/22 10:13 AM
GY3
Wichita
Not many pics (kind of ashamed to post what I do have) but we had issues a while back with the alternator going bad and back feeding through the engine harness. The engine harness was replaced with a reproduction but what I didn't realize at the time (because the car still worked fine) was the under dash harness got roasted pretty badly! It started having random issues lately with starting and lights flickering so I dug in and found bare power wires under the dash! I'm pretty fortunate that the car didn't burn to the ground!
Unfortunately, new dash harnesses aren't available for a '63 Dodge so I looked around to see if anyone had a used one. I found one but the guy wanted $400 for a used one! Kinda crazy for a small, 60 year-old wiring harness, but I guess people know an opportunity with they see one!
This prompted me to dig into mine and found it was mainly the two power wires that were fried. The rest of the harness was in surprisingly good shape! A good friend and neighbor helped me dissect and improve it. We spent about 3 hours on it last night and did wire replacement along with the ammeter delete. Gonna do the alternator wire directly to starter relay wire setup as well. I highly recommend this! I need to re-wrap the harness and put it back in the car and we should be good to go!
'63 Dodge 330
[Re: GY3]
#3080325
09/24/22 05:56 PM
09/24/22 05:56 PM
GY3
Wichita
Again, pics will not tell the whole story. It's been a hot Summer and we missed The Rumble race due to rain and the car simply not being done. I re-wrapped the dash harness, bypassed the ammeter and put a waterproof fuse housing on the firewall next to the master cylinder to protect the interior wiring should a failure happen. Very happy with how everything works especially since the dash and harness was scattered all over the interior a few days ago. I should have done this mod a long time ago! We are going to Mid America Dragway to race a nostalgia race tomorrow and looking forward to it!
'63 Dodge 330
[Re: GY3]
#3080611
09/25/22 06:07 PM
09/25/22 06:07 PM
GY3
Wichita
Awesome day at Mid America Dragway as we took home the win for '64 and earlier street tire class! Hard to believe it had a gutted dash last Wednesday! Dialed 11.50's n/a and it was flawless off the trailer. Beautiful day with perfect temp to boot!
'63 Dodge 330
[Re: GY3]
#3085870
10/13/22 11:08 PM
10/13/22 11:08 PM
Posts: 3,031 Sac, CA
mopowers
Sac, CA
Working on the stand alone battery power for the bottle heater. Made some progress on that today...
The bottle has an adjustable pressure switch that will turn off the heater when it reaches 1000 psi. Uses DeWalt 20v cordless batteries for power to maintain temp yet keep the drain off the car battery in the staging lanes. That is such a great idea using the dewalt battery. Do you have a photo of the panel mounted in the trunk??
[Re: mopowers]
#3085937
10/14/22 09:55 AM
10/14/22 09:55 AM
GY3
Wichita
The bottle has an adjustable pressure switch that will turn off the heater when it reaches 1000 psi. Uses DeWalt 20v cordless batteries for power to maintain temp yet keep the drain off the car battery in the staging lanes. That is such a great idea using the dewalt battery. Do you have a photo of the panel mounted in the trunk?? I do not, but I can get some tonight. The board is mounted right behind the bottle on some rubber MSD Box isolators.
'63 Dodge 330
[Re: GY3]
#3085945
10/14/22 10:23 AM
10/14/22 10:23 AM
mopowers
Sac, CA
The bottle has an adjustable pressure switch that will turn off the heater when it reaches 1000 psi. Uses DeWalt 20v cordless batteries for power to maintain temp yet keep the drain off the car battery in the staging lanes. That is such a great idea using the dewalt battery. Do you have a photo of the panel mounted in the trunk?? I do not, but I can get some tonight. The board is mounted right behind the bottle on some rubber MSD Box isolators. Thanks man. I appreciate it! I just noticed this thread and really love this build.
[Re: mopowers]
#3085948
10/14/22 10:58 AM
10/14/22 10:58 AM
GY3
Wichita
The bottle has an adjustable pressure switch that will turn off the heater when it reaches 1000 psi. Uses DeWalt 20v cordless batteries for power to maintain temp yet keep the drain off the car battery in the staging lanes. That is such a great idea using the dewalt battery. Do you have a photo of the panel mounted in the trunk?? I do not, but I can get some tonight. The board is mounted right behind the bottle on some rubber MSD Box isolators. Thanks man. I appreciate it! I just noticed this thread and really love this build. Thanks! I often wonder if I should keep posting here as it's not the typical Mopar "build" and is more about making performance upgrades, experimenting and chasing a number. As you can see, the cosmetics take a backseat! I'm always surprised by the views this thread gets.
'63 Dodge 330
[Re: mopowers]
#3086047
10/14/22 03:32 PM
10/14/22 03:32 PM
GY3
Wichita
Okay, here are the pics of the board in the trunk. Don't look too closely as the trunk floor has lots of patina and is low on the priority list.
'63 Dodge 330
