2020 T/A
#2900879
03/19/21 07:59 PM
03/19/21 07:59 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
posting what I have done to my T/A, still up in the air on selling the 68 Charger if I do I will put a Magnuson Super Charger on the T/A Put some 305/40-zr20 on the back, Lil Devil flares & a Down force Solutions wicker bill, I also took all the neg camber out of the front & rear, the rear plants the tire MUCH better on launch, did a mid muffler deleat, , & locked out the active exhaust. would not have done the muffler del if I had known the stock mufflers are a straight through design, BUT it does sound better, also got a Tazer to set for the taller rear tire, bonus was the auto seat function & the shift light, also put a Kicker Sub combined amp where the factory sub goes. I REALLY like this T/A 392 !!!!! I will get some Drag Radials & run it stock & see how it does before I do any mods
Re: 2020 T/A
[Re: 68_661charger]
#2900898
03/19/21 08:39 PM
03/19/21 08:39 PM
CSK
Pattison Texas
Beautiful car. Any under hood shots? Is the hood functional on those? Thank you,Yes it is, the T/A comes with the same set up as the Hellcat, the hood is functional & the inside headlights are also cold air.
Re: 2020 T/A
[Re: moparjim79]
#2900902
03/19/21 08:40 PM
03/19/21 08:40 PM
CSK
Pattison Texas
What a black beauty! Love the black with black stripes! Thanks, when the sun hits the side stripes they kind of light up & become VERY vivid
