SST Unveils The Mopar E-body Tremec TKX #2899973
03/17/21 08:26 AM
03/17/21 08:26 AM
Nashville, TN
Rustymuscle Offline OP
Mopar Connection Magazine
Nashville, TN
Silver Sport Transmissions (SST) is primed for pistol grip shifting as research and development finishes up on their proprietary Tremec TKX for Mopar E-body applications. Teaser pictures surfaced online for this highly-engineered modification that puts the TKX shifter in the factory location for 1970 to 1974 ‘Cudas and Challengers.
Read the whole story at Mopar Connection Magazine HERE:
Mopar Connection Magazine, your source for daily news, real-world tech, features and much more.
Got a comment, question, or a story? Email me at kevin.shaw@shawgroupmedia.com
Re: SST Unveils The Mopar E-body Tremec TKX [Re: Rustymuscle] #2900261
03/18/21 06:41 AM
03/18/21 06:41 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I have a 70 Challenger you can use for a test fit. smile
Re: SST Unveils The Mopar E-body Tremec TKX [Re: 70VcodeCoronetRT] #2900263
03/18/21 07:24 AM
03/18/21 07:24 AM
Nashville, TN
Nashville, TN
The kit is done. You missed all the test fitting. grin
Re: SST Unveils The Mopar E-body Tremec TKX [Re: Rustymuscle] #2900389
03/18/21 02:07 PM
03/18/21 02:07 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
whats the availability and cost for these. can you get the trans alone? does this use the same bellhousing, driveshaft and trans mount as the tko?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: SST Unveils The Mopar E-body Tremec TKX [Re: Jerry] #2900403
03/18/21 02:42 PM
03/18/21 02:42 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
You’ll have to call them for more details. The author doesn’t know everything.
China is the enemy.
Re: SST Unveils The Mopar E-body Tremec TKX [Re: Rustymuscle] #2900432
03/18/21 04:22 PM
03/18/21 04:22 PM
Alberta, Canada
572hemi Offline
572hemi  Offline
Alberta, Canada
So I see that they supply a rear cross member, I would be checking that this kit does not lower the rear of the trans to get there. I bought a A41 from keisler way back when and it was also called a perfect fit, lowered the rear of the trans by about 1.5" which makes for a lot of driveline vibration. I have one of the first 855's and could not be happier. Just Sayin
1967 GTX 572 HEMI 735 HP, 717 FT Lb T, , A-855 5 Speed, Dana 60 4:30 Gears, 30" Rear Tires
Re: SST Unveils The Mopar E-body Tremec TKX [Re: 572hemi] #2900625
03/19/21 08:13 AM
03/19/21 08:13 AM
Nashville, TN
Nashville, TN
Considering the RADICAL size difference from a 4L60E (SST's A41, which I ran in a '69 Charger for 2 years) and the new, compact TKX 5-speed manual, your concerns over tail cone angle are a little "misaligned." But yes, you will need to call Jeff Kaufman at Silver Sport Transmissions for the nitty gritty details for your particular application.
Moderated by  Rustymuscle
