Page 2 of 3 1 2 3
Re: Encroachment issue/property line [Re: varunner] #2899493
03/15/21 08:15 PM
03/15/21 08:15 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Subdivision. Read the covenants. He also may not be able to construct a certain distance to the property line. If he is encroaching your property he has to fix it on his dime.
Re: Encroachment issue/property line [Re: CYACOP] #2899494
03/15/21 08:21 PM
03/15/21 08:21 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
good point. Building restriction line. probably 10 or 20 ft.
Re: Encroachment issue/property line [Re: varunner] #2899498
03/15/21 08:28 PM
03/15/21 08:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Where would you be putting your road?
Re: Encroachment issue/property line [Re: NITROUSN] #2899502
03/15/21 08:36 PM
03/15/21 08:36 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Our driveway is already installed on the other side of the lot
Re: Encroachment issue/property line [Re: varunner] #2899531
03/15/21 10:31 PM
03/15/21 10:31 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
No way in a subdivision like that that he doesn’t have his own access to the street. You wouldn’t have a neighbor easement issue in a place like that.
I want my fair share
Re: Encroachment issue/property line [Re: varunner] #2899548
03/16/21 12:15 AM
03/16/21 12:15 AM
AndyF Offline
AndyF  Offline
Moving a marker pin isn't normal so I'd focus on that. That map you have seems pretty clear so double check to make sure that it is the "official" map that was filed with the city or county when the subdivision was approved. There should be a surveyor name on the map and the developer who laid out the subdivision should know where everything is supposed to be. Subdivisions are laid out by engineering firms who keep records and everything is filed with the city or state. Everything is permitted and filed and checked off when a subdivision is put in so there will be plenty of records. All you are going to need to do is follow the paper trail on where the pins should be and where the driveways should be.
A lawyer could be useless unless he knows something about subdivisions. If it was me I'd start with the developer who laid out all of the lots and see how they wanted things done. That is the plan that everyone should be following. Moving pins and changing land boundaries isn't allowed unless the proper paperwork is filled out.
And in a case like this it is always best to assume that it was an honest mistake. Give the guy plenty of room to fix his mistake, especially if the map is clear. I wouldn't get a lawyer involved up front, just get the pin moved back to where it should be and go from there.
Re: Encroachment issue/property line [Re: AndyF] #2899554
03/16/21 12:55 AM
03/16/21 12:55 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Drainfield Area??? Is this an area that cannot be built on? If so, the neighbor has a lot with very little real access, but then again so do you. Property line should be followed, though. You might give a guy a foot mistake, but 19' is on purpose...
Re: Encroachment issue/property line [Re: varunner] #2899580
03/16/21 07:57 AM
03/16/21 07:57 AM
Addison Twp, Mi.
RobG Offline
RobG  Offline
Addison Twp, Mi.
First, call and report this to the building department and ask them to investigate/pull his permit.
Measure the length of the property bounty from the other corner and paint a line where the marker should be located.
The building officials will have a lot to say....
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: Encroachment issue/property line [Re: RobG] #2899643
03/16/21 11:32 AM
03/16/21 11:32 AM
5thAve Offline
5thAve  Offline
If the city/town won't do anything go higher up or get a lawyer involved to push them. The contractor shouldn't have moved the marker. Maybe there's more going on then you know.
Re: Encroachment issue/property line [Re: 5thAve] #2899677
03/16/21 01:08 PM
03/16/21 01:08 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I have someone from the county environmental office going over there to check it out and talk to the owner. We've also typed up a certified letter stating our concerns and have CC'd our lawyer. Also should have a surveyor there, hopefully this week. I'll update as it evolves. thanks
Brian
Re: Encroachment issue/property line [Re: AndyF] #2899766
03/16/21 04:33 PM
03/16/21 04:33 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
------ this is easy. have it checked/ surveyed and then whats yours is yours. you can legally notice them to keep out and the police can enforce it. this is not hard to do. its private property and they dont own it..........
Re: Encroachment issue/property line [Re: ek3] #2899839
03/16/21 07:59 PM
03/16/21 07:59 PM
GA
roadrunninMark Offline
GA
If the guy is being a PITA, let him build it then have zoning show up and make him remove it. Nothing hurts more like hitting him where it counts.
Re: Encroachment issue/property line [Re: roadrunninMark] #2899849
03/16/21 08:14 PM
03/16/21 08:14 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'd be hesitant to go this route. All the building official has to ask is how you became aware of the problem and when the answer is "we knew before he started but we didn't stop him until now", that isn't going to go well.
Re: Encroachment issue/property line [Re: 6PakBee] #2899872
03/16/21 09:17 PM
03/16/21 09:17 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
What he is doing is theft... plain and simple. take your survey map/Deed to the local Zoning clerk and make a formal complaint.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Encroachment issue/property line [Re: 6PakBee] #2899926
03/16/21 11:56 PM
03/16/21 11:56 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Which really drives home the seldom mentioned point here. "time is of the essence", and its not on the OP's side.
Re: Encroachment issue/property line [Re: jcc] #2899979
03/17/21 09:01 AM
03/17/21 09:01 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Made some major progress yesterday. I went to the county offices to find someone to get involved. First building inspection, the head guy wasn't there, so headed to the zoning office. They listened to me, made a copy of the plat and said nothing we can(won't) do. They recommended I go to the environmental enforcement office. These are basically the 3 offices that you deal with getting permits to build a house. I talked to the guy who I've already spoken with who deals with the land disturbance permit. He's a former surveyor and knows the contractor. Seems like a standup guy. He went over there and checked several pin locations and basically agreed with what I've saying that somethings going on here. He's getting the contractor to re-survey the lines and will move the new culvert if necessary.. Also will get any equipment moved off our lot asap. We'll see how it pans out. They will also get our certified letter today. So there're getting it from 2 directions. The contractor nor the technician from the environmental office are straight up saying the pin has been moved. And I'm not shocked about that since it's a crime. As long as we get what we want, all good. The deal is here is that the county still has an open permit for this lot, so they have leverage. Leverage that I don't have, until the lawyer starts on them. We'll see.
Re: Encroachment issue/property line [Re: varunner] #2900057
03/17/21 01:07 PM
03/17/21 01:07 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
That looks like good progress, except I would like have the scoundrel that intentionally moved the iron rod held accountable, just on principles, and it be mark on his professional reputation, but then, I'm not the average person? grin
Re: Encroachment issue/property line [Re: varunner] #2900068
03/17/21 01:27 PM
03/17/21 01:27 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
We had our 2 acre lot surveyed and they found every pin and marked them with a wooden stake. Next day three of the stakes were throw in the street from a neighbor who wasn't thrilled about where they were. I paid to have the three pins relocated, then cut down every single tree along that 300" stretch. Told him to try and move that.
Hope it works out, neighbor sounds like a real peach.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Encroachment issue/property line [Re: A39Coronet] #2900152
03/17/21 05:37 PM
03/17/21 05:37 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Good one. it would many years to erase that line.
The neighbor is a modular home installer and has put many homes in our county. The home in question is a couple weeks from completion and I'm sure it's already sold. So they are 100% off our property, But the newly installed culvert is in front of our lot by about 10 ft. No ones lot includes the ditch that the culvert is in. I'm in process figuring out who owns the ground the culvert is installed. It will removed one way or another, but I need to do it before they close on the sale so this issue doesn't fall onto the new homeowner.
Re: Encroachment issue/property line [Re: ro23_j] #2900168
03/17/21 06:30 PM
03/17/21 06:30 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Originally Posted by ro23_j
Go to your county's website and find the GIS (geographic information system) link. Many counties have your property lines mapped and you can see them overlaid on maps.You may be able to see your property and the state/county right of ways. There is a lot of information that is public record that you can find by doing some research.
Great idea. Check the county website
I had a 48x36 pole barn/garage built...a neighbor who (lives across street) didn't want it to be built because it would block the scenic view of nearby woods would surely have waited for me to build and then raise hell (another great idea IF you are right about lot lines). I used the County GIS 'parcel viewer' to verify the property lines. A county employee told the builder that the lines shown on the viewer are accurate to within 2 feet. Didn't hurt that the next door neighbor was the local property tax collector. She knew the property lines very well.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Page 2 of 3 1 2 3
