Speedometer gear Teeth. How many #2896929
03/07/21 11:40 PM
03/07/21 11:40 PM
KY
65pacecar Offline OP
KY
Glad to see the repop of the 65 speedometer gear. I have a 3.91 geared 65 Automatic car, does any have a chart for the tooth count? Planning to run 275-60/15 tires on it.
Re: Speedometer gear Teeth. How many [Re: 65pacecar] #2896943
03/07/21 11:56 PM
03/07/21 11:56 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
brewers can tell you ....
Re: Speedometer gear Teeth. How many [Re: 65pacecar] #2896998
03/08/21 07:14 AM
03/08/21 07:14 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Here 'tis. Also wants an adapter.
Re: Speedometer gear Teeth. How many [Re: 1E2C] #2897003
03/08/21 07:53 AM
03/08/21 07:53 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you need a 21 tooth pinion and a .80 ratio reducer and most likely a different speedo cable. don't confuse this with the '66 and up speedo pinions.
Re: Speedometer gear Teeth. How many [Re: lewtot184] #2897024
03/08/21 09:44 AM
03/08/21 09:44 AM
not sure if the antique tires sizes compared to P numbers will be a problem or not?. there was another chart (MP?) that used diameters. Way back I used it & it was dead on.
Re: Speedometer gear Teeth. How many [Re: 65pacecar] #2897085
03/08/21 12:21 PM
03/08/21 12:21 PM
KY
KY
Thanks.
