Dry ice cleaning for your car #2895513
03/04/21 09:18 AM
03/04/21 09:18 AM
Puttin' on the foil in Charles...
not_a_charger Offline OP
Mr. Big Shot Moparts Moderator
Who knew? This seems like a great way to clean the undercarriage, etc, and would be a huge time saver.
https://www.youtube.com/watch?v=K1WEfIAChJ0
Earning every penny of that moderator paycheck.
DBAP
Re: Dry ice cleaning for your car [Re: not_a_charger] #2895530
03/04/21 10:30 AM
03/04/21 10:30 AM
St. Louis, Missouri area
Cometstorm Offline
"Beat It"
Cometstorm  Offline
"Beat It"
Don’t know what to say...
I would think that could threaten rubber and/or plastic integrity? shruggy
Re: Dry ice cleaning for your car [Re: not_a_charger] #2895555
03/04/21 11:13 AM
03/04/21 11:13 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
shock shock
WOW Mike thanks for posting that up
Re: Dry ice cleaning for your car [Re: not_a_charger] #2895586
03/04/21 11:56 AM
03/04/21 11:56 AM
IMGTX Offline
IMGTX  Offline
That is awesome but will it do rust and I'm sure if it gets used to restore old cars someone will ban or tax it because of CO2 emissions.
Thanks for posting
Re: Dry ice cleaning for your car [Re: not_a_charger] #2895614
03/04/21 12:42 PM
03/04/21 12:42 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
The Air Force has been using dry ice for stripping paint for years. I do wonder if this would clean up aluminum manifolds and so forth so they could be clear coated rather than painted.
Re: Dry ice cleaning for your car [Re: not_a_charger] #2895627
03/04/21 01:18 PM
03/04/21 01:18 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Looks like it did a great job on "dry" dirt. I wonder how it would do with oily/greasy/sticky dirt?
Re: Dry ice cleaning for your car [Re: BSharp] #2895647
03/04/21 01:45 PM
03/04/21 01:45 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
We used dry ice blasters to clean stuff at one of my jobs. The dry ice doesn't leave any residue, whatever you are blasting off will though. We still had to use acetone to wipe of the residual from the parts.
Dry stiff like paint probably can just be blown off with air, wet stuff like oil, grease, etc will leave a film that still needs wiped down to remove it.
Re: Dry ice cleaning for your car [Re: not_a_charger] #2895709
03/04/21 04:03 PM
03/04/21 04:03 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The wife works at True Manufacturing where they make commercial refrigerators many of which are all stainless steel.
They are insulated using spray expansion foam, they used blasted dry ice like that to clean the stainless steel to clean off what ever foam insulation squeezes out of the gaps at seams. If you're ever in a Walmart, Dollar General or a Starbucks and you see a cooler that says "True" on the front that's what they make.
It doesn't leave any marks behind like from scraping the foam away.
There is no way to remove a scratch from the stainless steel and it leaving no marks is a big deal to them since commercial refrigerators aren't cheap so they have to be perfect.
It melts away leaving no residue and is obviously food safe.
I hadn't ever thought about it being used to clean the underside of a car, but I can't see why it would be a problem.
Re: Dry ice cleaning for your car [Re: SNK-EYZ] #2895715
03/04/21 04:14 PM
03/04/21 04:14 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The disaster restoration industry uses dry ice blasting for mold remediation.
'63 Dodge 330
11.19 @ 121 mph
Re: Dry ice cleaning for your car [Re: GY3] #2895807
03/04/21 07:54 PM
03/04/21 07:54 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
The first time I ever heard of dry ice blasting was a local large food processing plant did that to clean their equipment. One of the maintenance guys is a friend and he told me about it. Absolutely no threat to food surfaces or contamination from blasting material. He said it made everything look like new.
Re: Dry ice cleaning for your car [Re: BSharp] #2895836
03/04/21 09:15 PM
03/04/21 09:15 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I didnt watch the posted video, but if the individual performing the blasting is based out of California, I think he's from Germany? and knows his stuff. One of his videos takes you through the equipment involved and cost of his equipment. Some of his videos have oily greasy crusty garbage covering driveline assemblies and it cleans them beautifully. Also, I saw a comment about rubber and or plastic damage-- once again, watch all the videos related. It makes the material look brand new and does no damage.
Re: Dry ice cleaning for your car [Re: GY3] #2896593
03/06/21 09:24 PM
03/06/21 09:24 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
We have used it in the plants to for cleaning assembly lines and robots. Great idea for the undercarriage.
KID
Re: Dry ice cleaning for your car [Re: Kidsixpack] #2896805
03/07/21 04:05 PM
03/07/21 04:05 PM
Ontario Canada
Caper1 Offline
Caper1  Offline
Ontario Canada
This article is from 2010 where they did 3 cars for their customer
https://www.nitrofreeze.com/dry-ice-blasting-for-auto-body-and-classic-cars/
Re: Dry ice cleaning for your car [Re: Caper1] #2896967
03/08/21 01:28 AM
03/08/21 01:28 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Its well known any removal of asbestos is currently suggested with a water component to keep dust controlled, what happens to the removed paint if no liquid or abrasives are used for it to stick to? Seems one problem cured to cause another?
