Re: OD/locking trans options for 1971 413
[Re: Ray S]
#2896216
03/05/21 08:20 PM
03/05/21 08:20 PM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
The converter also protrudes from the face of the bellhousing about an inch or so when fully seated vs the 1/2" the converter is recessed into the face of the bellhousing on gas versions and non lockup diesel versions. It's not because the bell is cut back, it's because the converter is thicker to accommodate larger, heavier duty components. You could cut the bell off a 46 or 47 and use an Ultra Bell for a 727 to B/RB pattern or an adapter for the 46 gas engine trans but you are still stuck with the smaller and narrower converter. I was just buying other stuff and saw https://www.ebay.com/itm/Engine-to-...-Ram-Cummins-Diesel-12v-24v/233911930079So, the Cummins has its own adapter to handle the deeper 47* TC? Could THAT be then adapted to the 413/440, ie stack them? The starter may or may not have clearance of course. The Cummins doesn't have a bellhousing pattern, just a bolt on adapter to fit a multitude of applications. Those 8 bolt holes inside that adapter are what bolts to the block. There are two different adapters for the Dodge/Ram application. One for the non lockup/Getrag (up to '93) and one for the lockup/NV4500 and beyond transmissions. The later version is about 1.125 deeper and has a different starter mounting as well as how the starter is clocked. I don't know why John would rather have switches instead of pressure switches because that is a PITA to keep up with. I will say you can't just use those little switches like PATC sells, at least I wouldn't. I used two adjustable Hobbs switches, one low and one high with two relays wired so while the low pressure switch closes it doesn't activate the relay until the high pressure switch activates the high switch relay. The high switch relay is then latched to the low switch relay so it stays locked until the low pressure switch is released. Kind of confusing I know and I would have to dig up the schematic again myself to redo it but it locks up at about 46-47 and unlocks at about 42-44 MPH. Otherwise it will hunt between lock and unlock at the pressure switch setting. I ran the whole deal through the O/D circuit in the PCM so I wouldn't get lockup without it being in O/D and used a third relay in that circuit so I wouldn't burn the driver out in the PCM. Works like factory, really.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2896232
03/05/21 08:52 PM
03/05/21 08:52 PM
Guitar Jones
I know you want to keep the 413 but in reality you could buy a rusted out P pumped 12 valve truck for $5k or less and swap the engine and trans and be money ahead even with a trans overhaul and good converter.
[Re: Guitar Jones]
#2896336
03/06/21 12:59 AM
03/06/21 12:59 AM
Posts: 149 PINE VALLEY
Ray S
PINE VALLEY
I know you want to keep the 413 but in reality you could buy a rusted out P pumped 12 valve truck for $5k or less and swap the engine and trans and be money ahead even with a trans overhaul and good converter. It's not that I have an affectionate attachment - it just runs great and I really don't want to remove the front end to cherry-pick it all out. My vain hope was to jack it up and do a trans R&R, which I've done, and (besides the shaft shortening) is a few hours. I also did got a reply from Randy (mrrandyj): "In my opinion you should use a Gear Vendors overdrive behind your 727. You can get a towing 12" torque converter that will not slip much going down the road. If you really must have a lock-up torque converter, you can find a 1978 big block 727 case and convert it to lock-up using a small block lock-up 727 for the parts you need. That way you won't need any expensive adapters to get the transmission to bolt to the engine. With a lot of the adapters you cannot use the larger size torque converter, it will not fit. If it was mine I would use your existing transmission, buy a good non lock-up torque converter, and install a Gear Vendors. Randy" and my response was: "Thank you Randy, If I find a good used GV unit I'll consider it, otherwise $3-5k for any of these solutions will never be worth it in gas savings..."
[Re: Guitar Jones]
#2896340
03/06/21 01:06 AM
03/06/21 01:06 AM
Ray S
PINE VALLEY
Sounds like a better idea, John might have had the PATC style simple switches in mind for the comment. My 97 RAM locks in 3rd and OD and the feel is noticeable. Since I installed 3.21 gear set in the diff climbing the local 6% grade in 3rd lockup is perfect.
[Re: Guitar Jones]
#2898106
03/11/21 11:18 AM
03/11/21 11:18 AM
Ray S
PINE VALLEY
That is as close as you are going to get with a 46RH. I honestly don't know how that would hold up in his application though. The billet cover and lockup clutch take up room in the converter that the turbine, stator and impeller occupy so all those components have to be smaller, which equals weaker. It's one of the reasons high horsepower automatic drag cars use GM transmissions, the bell housing is deeper. You could of course have someone build a special one off converter (expensive) and space the trans back but then the crossmember needs to be moved and the driveshaft shortened. Maybe not a big deal in Ray's case but is in others. I had to do that when I converted my '92 diesel to a lockup. Everything had to move rearward 1.250".
This thread https://www.classicwinnebagos.com/forum/index.php?topic=14273.0details one crazy drama of a mechanic's DIY trans mod. TLDR; he used an Ultrabell at the end, in front of a non-locking 46RH and manual OD switch. But, because of the thicker bell he had to use a smaller TC. Actually sounds reasonable, and high-quality OD clutches are called for.
[Re: Ray S]
#2898708
03/13/21 12:01 PM
03/13/21 12:01 PM
Ray S
PINE VALLEY
I case someone is interested, I found this list application list.
'90-'93 A518 transmission assemblies
TRANSMISSION ASSEMBLY, Complete w/Overdrive Assy., 4-Speed Automatic, A518
5300 8101 1 B2,3-D1 A518, w/5.2L Eng. w/o Electronic T/Converter Lock-Up, Up To 1-14-1991 5300 7782 1 B2,3-D1 A518, w/5.2L Eng. w/o Electronic T/Converter Lock-Up, After 1-14-1991 5300 8148 1 B,D A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1992 5211 8184 1 B,D A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992 5211 8732 1 B,D A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 5300 8142 1 N 1 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1992 5211 8730 1 N 1 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 5300 8143 1 N 5 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1992 5211 7685 1 N 5 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992 5211 8731 1 N 5 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 4505 154 1 D 5,6,8 A518, w/3.9L,5.2L Eng. w/o Electronic T/Converter Lock-Up, Up To 2-12-1991 Warren Built 4505 154 1 D 5,6,8 Up To 2-8-91 Toluca Built 5300 7783 1 D 5,6,8 A518, w/3.9L,5.2L Eng. w/o Electronic T/Converter Lock-Up, After 2-12-1991 Warren Built 5300 7783 1 D 5,6,8 After 2-8-1991 Toluca Built 5211 8231 1 D 5 A518, w/3.9L Eng. w/Electronic T/Converter Lock-Up, 1992 5211 8187 1 D 5 A518, w/3.9L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992 5211 8734 1 D 5 A518, w/3.9L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 5300 8147 1 D 5,6,8 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1992 5211 8185 1 D 5,6,8 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992 5211 8735 1 D 5,6,8 A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 5300 8149 1 D 5,6,7,8 A518, w/5.2L Eng. w/o Electronic T/Converter Lock-Up, 1992 5300 8102 1 B2,3-T4 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, Up To 1-2-1991 5300 7784 1 B2,3-T4 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, After 1-2-1991 5211 8230 1 B 2,3 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, 1992 5211 8721 1 B 2,3 A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992 5211 8736 1 B 2,3 A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 5300 8102 1 D 1,2,3,4 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, Up To 1-2-1991 5300 7784 1 D 1,2,3,4 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, After 1-2-1991 5211 8230 1 D 1,2,3,4 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, 1992 5211 8721 1 D 1,2,3,4 A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992 5211 8736 1 D 1,2,3,4 A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 4505 156 1 D 5,6,7,8 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, Up To 1-21-91 (Some Trans. May Be Stamped 4505154) 5300 7786 1 D 5,6,7,8 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, After 1-21-91 5300 8152 1 D 5,6,7,8 A518, w/5.9L Eng. w/o Electronic T/Converter Lock-Up, 1992 5211 8722 1 D 5,6,7,8 A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992 5211 8739 1 D 5,6,7,8 A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992 5300 7779 1 D 2,3 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, 1991 5211 7524 1 D 2,3 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, 1992 5211 7689 1 D 2,3 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, 1993, Up To 10-1-1992 5211 8733 1 D 2,3 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, After 10-1-1992 5300 7780 1 D 6,7 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, 1991 5211 7525 1 D 6,7 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, 1992 5211 7694 1 D 6,7 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, 1993, Up To 10-1-1992 5211 8737 1 D 6,7 A518, w/5.9L CUMMINS DIESEL Eng., w/o Lock-Up, After 10-1-1992
[Re: Ray S]
#2901015
03/20/21 10:41 AM
03/20/21 10:41 AM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Oh, and another reason not to use a GV or 46RH is that I would need to add a $400 pinion E-brake, as my 727 has the tailshaft drum brake (I'd rebuilt recently). Gearvendors makes a divorced unit. If your motorhome has a hanger bearing, you could install the GV unit in place of it and only have to shorten one driveshaft. Kevin
[Re: Ray S]
#2901077
03/20/21 02:00 PM
03/20/21 02:00 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just to add more to the mix, I've learned that there are 2.74 ratio first gear parts out there now (there are raging debates as to whether there were such OEM options for the 727).
No debate, it's a myth.
[Re: John_Kunkel]
#2901157
03/20/21 06:53 PM
03/20/21 06:53 PM
Guitar Jones
There are low gear sets for the 727 but none were OEM. The one set I saw used a 904 planetary and sun gear scabbed together with the 727 parts. Looked really cheesy to me. I don't know who made or sold it.
[Re: Guitar Jones]
#2901578
03/22/21 12:28 PM
03/22/21 12:28 PM
Ray S
PINE VALLEY
There are low gear sets for the 727 but none were OEM. The one set I saw used a 904 planetary and sun gear scabbed together with the 727 parts. Looked really cheesy to me. I don't know who made or sold it. I talked to http://www.aandatrans.com and they sell billet low gear sets, PN 22134H**** ~$600 to $900 http://www.jvxracing.com no longer sells the sets that are in their catalog...
[Re: John_Kunkel]
#2901595
03/22/21 01:11 PM
03/22/21 01:11 PM
Ray S
PINE VALLEY
No debate, it's a myth. Do we know what the "police and taxi" option trans is? Only upgraded planetaries? The motorhome 727 came with upgraded planets.
[Re: Ray S]
#2902383
03/24/21 01:46 PM
03/24/21 01:46 PM
John_Kunkel
Rio Linda, CA
"Upgraded" how? A BB motorhome, police or taxi trans is basically just a HD unit using the same 4-pinion planetary as any production trans, so that might be considered an "upgrade" from 3-pinion units. The 383-2 unit circled above would have 3-pinion planetaries front and rear.
[Re: John_Kunkel]
#2902437
03/24/21 04:47 PM
03/24/21 04:47 PM
Ray S
PINE VALLEY
"Upgraded" how? A BB motorhome, police or taxi trans is basically just a HD unit using the same 4-pinion planetary as any production trans, so that might be considered an "upgrade" from 3-pinion units. The 383-2 unit circled above would have 3-pinion planetaries front and rear. Yes, "upgraded" meaning 4-pinions... Which implies that the only difference in police or taxi units was the pinion count (?)
[Re: mgoblue9798]
#2908733
04/10/21 01:04 PM
04/10/21 01:04 PM
Ray S
PINE VALLEY
Ray I have done some checking and a 12" converter can be used if a midplate style adapter is used to mate the 518 to the big block. If you go with the ultrabell instead of adapter then you may be limited to the 11' as Guitar mentioned. Just a heads up. Thanks - The Cope Racing build would have such a plate. I'm still on the fence regarding the main options: 1. 1978+ locking TC 727 with lower 1st and diff ratio change. 2. Same 727 with GV and modern low stall TC 3. Well built 518 Another consideration is that the A727 has the P-brake on the tailhousing. Id have to weld on a pinion brake if I lost that...
