Re: Mopar Performance Crankshaft
[Re: earlymopar]
#2894624
03/01/21 11:29 PM
03/01/21 11:29 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
does it have 340 or 360 main bearing size?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: earlymopar]
#2894720
03/02/21 10:39 AM
03/02/21 10:39 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
Don't most of the circle track classes have a 358" limit? I go a block from a local guy and he put 8 sleeves in it because the class allowed Mopars to run at 360". This could explain the stroke.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: earlymopar]
#2895077
03/03/21 01:40 AM
03/03/21 01:40 AM
Posts: 3,504 DFW
mr_340
DFW
MP had a bunch of different strokes available on these 1053 Steel cranks. I think the idea was to go to a shorter stroke when the block would be bored/honed to the next size. I have one of the 3.51" stroke cranks, as well as a 3.55" and a 3.65" stroke. When they put them on sale, they sold some pistons too, but they didn't match up with the crank strokes well. One set was listed for a 3.54" stroke, but was really for the 3.45" stroke (old 355 combo).
Floyd Lippencott IV
[Re: earlymopar]
#2895135
03/03/21 09:53 AM
03/03/21 09:53 AM
Posts: 3,916 usa
lewtot184
usa
But then I dug out a set of pistons that I got with the crankshaft... They were listed as 340/360 pistons with a bore of 4.060" (so +.060" over 360 or, +.020" over 340). They were also listed as designed for a stock rod length 8.123" and a stroke of 3.510". This messes up the 358 spec class idea since this bore and stroke would yield 363CI. Possibly there are smaller bore pistons made for the same stroke that would make the 358CI formula (such as a +.030" over 360 piston). using 8.123" rod length math will really mess you up.
