Dumb mistake - damaged block #2894260
03/01/21 02:07 AM
03/01/21 02:07 AM
California
70Drop Offline OP
70Drop  Offline OP
California
I was putting my big-block back together after a refresh. I put in a new oil pick-up tube that was a bit too deep for the pan, so I decided to push down on the tube while it was still installed in the block. The photo shows the result: I broke off a piece of iron where the pick-up tube threads into the block. Dumb mistake. I've been thinking about how I would best fix this. I'm guessing I'm gonna have to get it welded. Just wanted to see if anyone has thoughts on this. Thanks.
Re: Dumb mistake - damaged block [Re: 70Drop] #2894269
03/01/21 04:40 AM
03/01/21 04:40 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I would glue a bung in the hole & fit an external pickup.
Re: Dumb mistake - damaged block [Re: rebel] #2894303
03/01/21 09:41 AM
03/01/21 09:41 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Maybe drilling and tapping it a little deeper? Any way, the motor comes apart. Tough break.
Re: Dumb mistake - damaged block [Re: 70Drop] #2894322
03/01/21 10:52 AM
03/01/21 10:52 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well that sucks.
Here is what I would do/easiest way I know.
Remove the oil pump. Follow the oil passage from the broken area to the flat part of the block where the oil pump bolts on.
Drill and tap that hole in the location where the oil pump bolts on for NPT. Plug that hole. You want it air tight. Sink the tapped hole below flush.
Then run a single line static external oil pickup using one of the Milodon billet pumps that comes with the -12 male sticking out.
Rich H.
Esse Quam Videri
Re: Dumb mistake - damaged block [Re: 70Drop] #2894345
03/01/21 12:02 PM
03/01/21 12:02 PM
PA
Scully Offline
Scully  Offline
PA
I always heat the pickup tube with the cutting torch and it bends with ease.
Re: Dumb mistake - damaged block [Re: Scully] #2894351
03/01/21 12:20 PM
03/01/21 12:20 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Grind it down to break then tap deeper, get another tube to weld-extend the old pickup the amount it went deeper
Re: Dumb mistake - damaged block [Re: Scully] #2894353
03/01/21 12:27 PM
03/01/21 12:27 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I agree with Zippy's solution and meerly adding to try to create an upward small upward slope to the braided pickup line where it exits the oil pump, if space allows. The amoumt of oil left in the line helps keep the pump primed for quick pressure on start up, especially after sitting.Plenty of info in other treads on this site, and pictures and description on pg. 29 of Andy Finkbeiner's big block book. Bill
Re: Dumb mistake - damaged block [Re: ZIPPY] #2894368
03/01/21 01:02 PM
03/01/21 01:02 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Originally Posted by ZIPPY
Well that sucks.
this penguin and and you don't even need to tear it down
Re: Dumb mistake - damaged block [Re: B1MAXX] #2894651
03/02/21 04:56 AM
03/02/21 04:56 AM
California
70Drop Offline OP
70Drop  Offline OP
California
Thanks much. You guys are the best. I think I'll go with the external pick-up. Probably a good idea anyhow, even if I hadn't damaged the block
Re: Dumb mistake - damaged block [Re: 70Drop] #2894654
03/02/21 06:22 AM
03/02/21 06:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I old feed can be blocked at the other end of the passage. Much easier.
Doug
