Waterpumps ?
#2893798
02/27/21 05:03 PM
02/27/21 05:03 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Ok Age old question . Which works better , Flowcooler or Edelbrock . Big block 505 . World block . I replaced my radiator wuth same brand/unit . Now it suis on 200/205 on freeway @ 65mph. It also runs that 10/15f warmer in town . I have a 600+mile each way run coming up in 2 weeks I know the World block runs warmer than my factory block
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Waterpumps ?
[Re: lewtot184]
#2893845
02/27/21 06:37 PM
02/27/21 06:37 PM
Posts: 989 Addison,IL
OUTLAWSSAA
Addison,IL
Milodon Mechanical Water Pumps 16260 Make sure this fits your vehicle: Recent Vehicles Milodon 16260 - Milodon Mechanical Water Pumps View All Media https://static.summitracing.com/global/images/prod/large/mil-16260.jpg?rep=FalseMilodon Overview $91.75 1 Add To Cart Click here to add MIL-16260 to your shopping wishlist.+Compare Fast Shipping Low Price Guarantee Tech Advice Easy Returns (4) Review This Product Q&A 1 Answered Question Water Pump, Mechanical, High-Volume, Big Block Mopar, 383/400/426/440, Aluminum, 1959 -1979, Each In Stock (more than 10 available) Estimated Ship Date: Monday 3/1/2021 Would you rather pick it up? Select Location Check Fit View Similar Products See parts for Milodon Milodon Mechanical Water Pumps Part Type: Water Pumps, Mechanical Application: Find out if this fits your application Save Email
Re: Waterpumps ?
[Re: OUTLAWSSAA]
#2893856
02/27/21 07:19 PM
02/27/21 07:19 PM
tex013
Sydney,Australia
thanks Lew I kind of think the Eddy and Source seem similar visually Outlaw thanks , reviews arent so good .
I have a GMB (Japan) pump i fitted a anti cav plate to , 6 blade looks like Milodon . I also have a Source pump , had good results with them , first one ran7/8 yrs . Have new one on now . I will refit GMB pump . Order a Flowkooler and see where i go . I know its either too slow or too fast flow . I can also fit a gutted Tstat as a restrictor of sorts .
Tex
Re: Waterpumps ?
[Re: tex013]
#2893873
02/27/21 08:05 PM
02/27/21 08:05 PM
Posts: 851 Brisbane Australia
572B1
Brisbane Australia
Tex Hi Tex, what track are you driving to.
Re: Waterpumps ?
[Re: 572B1]
#2893879
02/27/21 08:30 PM
02/27/21 08:30 PM
tex013
Sydney,Australia
Tex Hi Tex, what track are you driving to. Mildura for ANDRA finals , from Sydney Tex
Re: Waterpumps ?
[Re: tex013]
#2893884
02/27/21 08:53 PM
02/27/21 08:53 PM
572B1
Brisbane Australia
Tex Hi Tex, what track are you driving to. Mildura for ANDRA finals , from Sydney Tex Have a safe trip, hope you do well.
Re: Waterpumps ?
[Re: 572B1]
#2893886
02/27/21 09:01 PM
02/27/21 09:01 PM
tex013
Sydney,Australia
Tex Hi Tex, what track are you driving to. Mildura for ANDRA finals , from Sydney Tex Have a safe trip, hope you do well. thanks mate . Tex
Re: Waterpumps ?
[Re: Suregrip391]
#2893982
02/28/21 09:56 AM
02/28/21 09:56 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I use the MOPAR aluminum unit for A/c and overdrive it with a 6 cylinder pully. Keeps my 540 @ 180* on the hiway.
Re: Waterpumps ?
[Re: lewtot184]
#2894124
02/28/21 04:56 PM
02/28/21 04:56 PM
tex013
Sydney,Australia
thanks guys for the replies . Pump is on way , Flowkooler . I use March pulleys so 1:1 near enough . I have a AFCO crossflow radiator I have not run a tstat in nearly 15 years , i do not like the idea of being in the staging lanes with cold motor and quick call up with going to burn out etc with tstat shut . I use the Mopar Performance 5 blade viscous fan , though i have the Jag short viscous drive on it now after fan ate radiator in Jan after 10 years or so use grrr . I have factory shroud . Mopar viscous drive puts fan max 1/2"off core now is closer to 1 It did seem visually @ 1100rpm the GMB pump with cav plate moves more coolant than the Source unit . Will see . Testing saturday so see how it goes on freeway to the track .
Tex
Re: Waterpumps ?
[Re: tex013]
#2894152
02/28/21 06:36 PM
02/28/21 06:36 PM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
I think you will like the Flowkooler pump because it flows pretty good at idle. I have an inline filter in my upper hose and I can see the coolant moving nicely through it. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Waterpumps ?
[Re: fourgearsavoy]
#2894158
02/28/21 06:48 PM
02/28/21 06:48 PM
tex013
Sydney,Australia
I think you will like the Flowkooler pump because it flows pretty good at idle. I have an inline filter in my upper hose and I can see the coolant moving nicely through it. Gus thanks Gus . Tex
Re: Waterpumps ?
[Re: tex013]
#2894256
03/01/21 12:53 AM
03/01/21 12:53 AM
Posts: 5,155 CT
GTX MATT
CT
Has anyone compared the way the impeller of the so called high flow designs fit the volute of the housings? Or how the volute of the aftermarket housings compare to OEM?
You may find that certain designs work well with certain housings and not others if they vary much from the OE design.
Re: Waterpumps ?
[Re: tex013]
#2894301
03/01/21 09:24 AM
03/01/21 09:24 AM
RapidRobert
I also have a Source pump , had good results with them . is that the one with the curved blades?
Re: Waterpumps ?
[Re: RapidRobert]
#2894498
03/01/21 05:32 PM
03/01/21 05:32 PM
tex013
Sydney,Australia
I also have a Source pump , had good results with them . is that the one with the curved blades? yes . the same as the newer one . Tex
Re: Waterpumps ?
[Re: tex013]
#2894726
03/02/21 10:44 AM
03/02/21 10:44 AM
RapidRobert
I also have a Source pump , had good results with them . is that the one with the curved blades? yes . the same as the newer one . Tex Thank you. I have one & I had heard that it was worthless, appreciated!
