Page 3 of 3 1 2 3
Re: Where is my HP/TQ [Re: Brian Hafliger] #2894105
02/28/21 03:58 PM
02/28/21 03:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Are/were there any cast B1 TR manifolds ever made?
The only thing I ever saw was a weld together “kit”.
If someone is buying a sheet metal manifold....... it could be sized for however big the motor is.
Re: Where is my HP/TQ [Re: Brian Hafliger] #2894128
02/28/21 05:08 PM
02/28/21 05:08 PM
Texas
Chief Offline OP
Chief  Offline OP
Texas
Agree.
The intake is the one that Koffles or maybe Mopar Performance had made to go with the heads. It was a 3 piece intake. I bolted the runners to the heads and slide the plenum over them. Squared it up and welded.
Runners were bell mouthed and funnel shaped tapering down to port size, made an open plate and attached a Big and Ugly on top..
Here is what I have.. The Indy intake looks almost identical to the Mopar Performance. Second picture is of a Big and Ugly hat on a tunnel ram.
Dave Covey
Re: Where is my HP/TQ [Re: Chief] #2894147
02/28/21 06:21 PM
02/28/21 06:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
In this pic of the kit....... it sure looks like some serious porting would be required to at least one end of the runners.
Re: Where is my HP/TQ [Re: fast68plymouth] #2894194
02/28/21 08:42 PM
02/28/21 08:42 PM
Texas
Chief Offline OP
Chief  Offline OP
Texas
No argument porting would help. I radiused the entry and port matched at the head. No idea what it flows. But I can't imaging it wouldn't flow ehough air.
Dave Covey
Re: Where is my HP/TQ [Re: Chief] #2894252
03/01/21 12:21 AM
03/01/21 12:21 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
I have one of those weld up kits. I spent many hours on the Bridgeport with that thing back in 1996. A very good B1 head guy told me to open the top of the runners to 6 square inches and taper it down to the port size. It ran the same on a 572 with two dominators on gas and with a bird catcher on alcohol. It made 907hp with the dominators. That was over 25 years ago can't remember the cam specs but I will try to find them.
Re: Where is my HP/TQ [Re: Chief] #2894253
03/01/21 12:22 AM
03/01/21 12:22 AM
SoCal
Brian Hafliger Offline
SoCal
This is where I think you might be overlooking this. What is the total intake tract length? That is HUGE in power production. Second, what is the plenum volume? Third, what is the runner size in the plenum vs. at the flange and taper? All these things HAVE to work together to make REAL power. Your engine makes power, but it would seem even you are not happy with the results. I'm trying to make you look closer at the puzzle pieces to determine the problem. Or you can leave it alone...
Brian Hafliger
Re: Where is my HP/TQ [Re: Brian Hafliger] #2894254
03/01/21 12:44 AM
03/01/21 12:44 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
iagree Even back then I thought mine should have made more power and always wondered how a good manifold would have been.
Re: Where is my HP/TQ [Re: B1HEAD_USER] #2894356
03/01/21 12:28 PM
03/01/21 12:28 PM
Texas
Chief Offline OP
Chief  Offline OP
Texas
Good to know. Mine had already been worked on when I got it and since I have a friend who has one just like it with no issues I didn't think I would have any. Both are injected engines. Mine fit the ports perfectly when I put it on and I didn't think to measure the top as I wasn't expecting any issues. I'll check it next time it is off (maybe before) but the plan for the future is to build an new one.
Thanks for the info on yours..
Dave Covey
Re: Where is my HP/TQ [Re: Brian Hafliger] #2894357
03/01/21 12:30 PM
03/01/21 12:30 PM
Texas
Chief Offline OP
Chief  Offline OP
Texas
Believe me you guy's have me looking. Any suggestions on dimensions you mention?
Dave Covey
Page 3 of 3 1 2 3
