Re: transmission fluid additives
[Re: racerx]
#2894626
03/01/21 11:40 PM
03/01/21 11:40 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
Straight non synthetic ATF type F up And this stuff is getting hard to find in my area i have around 40 quarts in stock of Valvoline and Pennzoil non synthetic type F ATF fluid, I'll probably have to switch to ATI Synthetic ATF after all the old stuff is gone I currently have 3 gallons of the ATI synthetic ATF in stock, maybe do some fluid testing this year at the track with my bracket car
[Re: moparx]
#2894972
03/02/21 08:20 PM
03/02/21 08:20 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
many, many [and many ! ] years ago, one of the, at the time, big name transmission guru's said to add a quart of [10wt i think] detergent motor oil to the mix. does anyone remember who this was, and what was the motor oil supposed to do ? It was in Chrysler Power mag. I think it was called "Talking Torqueflites" Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dbran451]
#2895205
03/03/21 01:37 PM
03/03/21 01:37 PM
Posts: 19,408 north of coder
moparx
i put a quart of 0w5 synthetic every time i change my fluid what is this supposed to accomplish/do ? TIA.
[Re: moparx]
#2895278
03/03/21 04:27 PM
03/03/21 04:27 PM
Posts: 287 PA
Harry's Taxi 2
PA
many, many [and many ! ] years ago, one of the, at the time, big name transmission guru's said to add a quart of [10wt i think] detergent motor oil to the mix. does anyone remember who this was, and what was the motor oil supposed to do ? I think it was Marv Booth? I have the Chrysler Power article somewhere. I'll try to remember to check tomorrow.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: FastmOp]
#2896836
03/07/21 06:20 PM
03/07/21 06:20 PM
Posts: 4,070 Mo.
racerx
Mo.
CAT wet clutch hydraulic fluid.
I replace every 25 runs Fastmop.....is there a certain weight they use fir the transmission? I'm new to this fluid regular cheap type F is getting hard to find. .
[Re: fourgearsavoy]
#2896865
03/07/21 08:23 PM
03/07/21 08:23 PM
Posts: 183 Macon, Missouri
TJ2
Macon, Missouri
many, many [and many ! ] years ago, one of the, at the time, big name transmission guru's said to add a quart of [10wt i think] detergent motor oil to the mix. does anyone remember who this was, and what was the motor oil supposed to do ? It was in Chrysler Power mag. I think it was called "Talking Torqueflites" Gus As I recall... in that "Talking Torqueflites" article by Marv Booth, he mentioned using straight 30w engine oil in place of using regular Dexron or Type F transmission fluid. Seems like he said you could use a quart or two as an additive... all the way to using ONLY 30w, with no regular transmission fluid. Seems like he claimed or spoke of using the 30w engine oil even in motor home/RV applications, saying that the thicker viscosity of the 30w even aided gas mileage a small bit in these heavy rigs. If anyone happens to still have that issue/article available and handy, please fact check this for me... as my memory of this information may be off a bit... it has been quite a long time ago!
