hood Insulation Pad #2894141
02/28/21 05:59 PM
02/28/21 05:59 PM
South San Francisco, Ca
70sixpkrt Offline OP
Is this the correct way a hood insulation pad go? Or is it backwards? For a 70 Charger R/T. I bought this one about 30 yrs ago from Yearone.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: hood Insulation Pad [Re: 70sixpkrt] #2894199
02/28/21 08:54 PM
02/28/21 08:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The visible side should be flat, not puffy, with visible contours that mimic the hood underside.
They weren't particularly thick, nor puffy.
For a long time, the aftermarket ones were incorrect.
Re: hood Insulation Pad [Re: topside] #2894257
03/01/21 01:18 AM
03/01/21 01:18 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
What company is making “correct” pads?
China is the enemy.
Re: hood Insulation Pad [Re: 1972CudaV21] #2894318
03/01/21 10:34 AM
03/01/21 10:34 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
The correct molded style is either a product from REM or Repops. REM only sells through it network of vendors which is quite large and Repops sells both retail and wholesale.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: hood Insulation Pad [Re: 69bfan] #2894408
03/01/21 02:39 PM
03/01/21 02:39 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Thank you. I looked them up and found their websites. What about https://www.detroitmuscletechnologies.com/..?
China is the enemy.
