b/m super duty shift cable lube or not?? #2893868
02/27/21 07:55 PM
02/27/21 07:55 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
do you guys lube your new shifter cables with anything? or install them as is?. im replacing the old shift cable on my pro ratchet and was thinking of lubing it up with dry graphite?thanks
Re: b/m super duty shift cable lube or not?? [Re: hp340nos] #2893880
02/27/21 08:33 PM
02/27/21 08:33 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
One vote for nothing, though I never tried (or even considered) adding anything. The one in my car now has been going strong for around 10 years. I replaced one that was too short and didn't last I think because of the bends it had to do..and/or closness to exhaust.. that short one lasted only a few months. From my very limited experience I would think that the bends and heat sources are more important than lubrication inside the cable.
Re: b/m super duty shift cable lube or not?? [Re: Exit1965] #2893885
02/27/21 08:55 PM
02/27/21 08:55 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Never in all my years had I ever had to lube up the cable.
If you were going to, I'd only use a graphite lube.
Re: b/m super duty shift cable lube or not?? [Re: hp340nos] #2894560
03/01/21 08:11 PM
03/01/21 08:11 PM
Minn
SportF Offline
SportF  Offline
Minn
Your shift cable isn't a cable, but a stiff wire. And even if you put 90W in there at minus 20 when the engine warmed up it would be fine. What on earth could it hurt?
