Waterpumps ? #2893798
02/27/21 05:03 PM
02/27/21 05:03 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok
Age old question . Which works better , Flowcooler or Edelbrock .
Big block 505 . World block .
I replaced my radiator wuth same brand/unit . Now it suis on 200/205 on freeway @ 65mph. It also runs that 10/15f warmer in town .
I have a 600+mile each way run coming up in 2 weeks
I know the World block runs warmer than my factory block
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Waterpumps ? [Re: tex013] #2893823
02/27/21 05:53 PM
02/27/21 05:53 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
flow cooler!!!!!!!!!! avoid the edelbrock/440 source.
Re: Waterpumps ? [Re: lewtot184] #2893845
02/27/21 06:37 PM
02/27/21 06:37 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Milodon Mechanical Water Pumps 16260
Make sure this fits your vehicle:
Recent Vehicles
Milodon 16260 - Milodon Mechanical Water Pumps
View All Media
https://static.summitracing.com/global/images/prod/large/mil-16260.jpg?rep=False
Milodon Overview
$91.75
Add To Cart
Click here to add MIL-16260 to your shopping wishlist.+Compare
Fast Shipping
Low Price Guarantee
Tech Advice
Easy Returns
(4)
Review This Product
Q&A
1 Answered Question
Water Pump, Mechanical, High-Volume, Big Block Mopar, 383/400/426/440, Aluminum, 1959 -1979, Each
In Stock (more than 10 available)
Estimated Ship Date: Monday 3/1/2021
Would you rather pick it up? Select Location
Check Fit
View Similar Products
See parts for Milodon
Part Type:
Water Pumps, Mechanical
Application:
Find out if this fits your application
Save
Email
Re: Waterpumps ? [Re: OUTLAWSSAA] #2893856
02/27/21 07:19 PM
02/27/21 07:19 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks Lew
I kind of think the Eddy and Source seem similar visually
Outlaw thanks , reviews arent so good .
I have a GMB (Japan) pump i fitted a anti cav plate to , 6 blade looks like Milodon . I also have a Source pump , had good results with them , first one ran7/8 yrs . Have new one on now .
I will refit GMB pump . Order a Flowkooler and see where i go .
I know its either too slow or too fast flow . I can also fit a gutted Tstat as a restrictor of sorts .
Tex
New best MPH 130.32
Re: Waterpumps ? [Re: tex013] #2893873
02/27/21 08:05 PM
02/27/21 08:05 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Originally Posted by tex013
Ok
Tex
Hi Tex, what track are you driving to.
Re: Waterpumps ? [Re: 572B1] #2893879
02/27/21 08:30 PM
02/27/21 08:30 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok
Tex
Mildura for ANDRA finals , from Sydney
Tex
New best MPH 130.32
Re: Waterpumps ? [Re: tex013] #2893884
02/27/21 08:53 PM
02/27/21 08:53 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Ok
Tex
Tex
Have a safe trip, hope you do well.
Re: Waterpumps ? [Re: 572B1] #2893886
02/27/21 09:01 PM
02/27/21 09:01 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok
Tex
Tex
thanks mate .
Tex
New best MPH 130.32
Re: Waterpumps ? [Re: tex013] #2893938
02/28/21 12:45 AM
02/28/21 12:45 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i have a flow cooler on my 340 with an allu rad nd am NOT real happy with .
cools fine driving but i think water flow at low rpm is too slow , heats up in heavy traffic .
also noticed impeller is smaller in dia than the other two i have here ?
prob wil repace it with a gmb for this summer .
Re: Waterpumps ? [Re: calrobb2000] #2893980
02/28/21 09:50 AM
02/28/21 09:50 AM
USA
Suregrip391 Online content
Suregrip391  Online Content
USA
Milodon high flow pump AND Milodon high flow stat, they work very well together. Try both.
Re: Waterpumps ? [Re: Suregrip391] #2893982
02/28/21 09:56 AM
02/28/21 09:56 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use the MOPAR aluminum unit for A/c and overdrive it with a 6 cylinder pully. Keeps my 540 @ 180* on the hiway.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Waterpumps ? [Re: hemi-itis] #2894038
02/28/21 12:34 PM
02/28/21 12:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have a '69 coronet r/t, 440/375hp, with a factory22" radiator. it's running hot before you turn the key,..lol. i've had the radiator re-cored from the original 2 row 76 tube piece of crap to a 3 row 144 tube; not as crappy. i've tried every kind of water pump made and without doubt the edelbrock/440 source were the worst. the milodon or any of the large diameter 6 blade pumps with the anti-cavitation plate work better than stock or the edelbrock/440source. in my car the flow cooler was at least 15 degrees cooler than the 440 source and from now on is my go to pump. i've played with every kind of mechanical fan i could buy. the best fan i've used for cooling is the old '070 clutch/7 blade. thermostats are a little hit and miss because of the variance in opening rates. the old robert shaw or thompson brass are the best; if you can find one. i've tried flow orifice discs instead of a thermostat and would only recommend in hot climates and then you would have to play opening sizes.
Re: Waterpumps ? [Re: lewtot184] #2894124
02/28/21 04:56 PM
02/28/21 04:56 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys for the replies .
Pump is on way , Flowkooler . I use March pulleys so 1:1 near enough . I have a AFCO crossflow radiator
I have not run a tstat in nearly 15 years , i do not like the idea of being in the staging lanes with cold motor and quick call up with going to burn out etc with tstat shut . I use the Mopar Performance 5 blade viscous fan , though i have the Jag short viscous drive on it now after fan ate radiator in Jan after 10 years or so use grrr . I have factory shroud . Mopar viscous drive puts fan max 1/2"off core now is closer to 1
It did seem visually @ 1100rpm the GMB pump with cav plate moves more coolant than the Source unit .
Will see . Testing saturday so see how it goes on freeway to the track .
Tex
New best MPH 130.32
Re: Waterpumps ? [Re: tex013] #2894152
02/28/21 06:36 PM
02/28/21 06:36 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think you will like the Flowkooler pump because it flows pretty good at idle. I have an inline filter in my upper hose and I can see the coolant moving nicely through it.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Waterpumps ? [Re: fourgearsavoy] #2894158
02/28/21 06:48 PM
02/28/21 06:48 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Gus beer
thanks Gus . luck
Tex
New best MPH 130.32
Re: Waterpumps ? [Re: tex013] #2894256
03/01/21 12:53 AM
03/01/21 12:53 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Has anyone compared the way the impeller of the so called high flow designs fit the volute of the housings? Or how the volute of the aftermarket housings compare to OEM?
You may find that certain designs work well with certain housings and not others if they vary much from the OE design.
Re: Waterpumps ? [Re: tex013] #2894301
03/01/21 09:24 AM
03/01/21 09:24 AM
Quote
I also have a Source pump , had good results with them .
is that the one with the curved blades?
Re: Waterpumps ? [Re: RapidRobert] #2894498
03/01/21 05:32 PM
03/01/21 05:32 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Originally Posted by RapidRobert
Quote
yes . the same as the newer one .
Tex
New best MPH 130.32
Re: Waterpumps ? [Re: tex013] #2894635
03/02/21 01:15 AM
03/02/21 01:15 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Save the money on the Milodon shiny box. I bought one and it’s a reboxed GMB pump.
Re: Waterpumps ? [Re: tex013] #2894726
03/02/21 10:44 AM
03/02/21 10:44 AM
Quote
Tex
Thank you. I have one & I had heard that it was worthless, appreciated!
