Hey Guys,
I would appreciate some insight on fixing a remote starting issue on my wife's van. We recently had a head replaced under recall. Since then the remote start does not work if the van sits over night. If the ignition is turned on with the key and the van runs a minute, the remote start will work. However, upon sitting over night it will not work. I've looked online and tried all the fixes but none seem to work. The dealer is at a loss as to why. Any ideas on what could be causing this intermittent issue?
Thanks!
