Small Block Mechanical fuel pump for HP ? #2892985
02/25/21 11:23 AM
02/25/21 11:23 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Which mechanical pump are you guys running for 500+ hp applications ?
Re: Small Block Mechanical fuel pump for HP ? [Re: lostdog] #2892998
02/25/21 11:50 AM
02/25/21 11:50 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Carter made a HV fuel pump for SBs. I've got one for sale. PM me if your interested.
Re: Small Block Mechanical fuel pump for HP ? [Re: DavidDean] #2893012
02/25/21 12:21 PM
02/25/21 12:21 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Those Carter mech pumps require the special hardened eccentric too???
Re: Small Block Mechanical fuel pump for HP ? [Re: Neil] #2893019
02/25/21 01:11 PM
02/25/21 01:11 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I didn't even consider this
Re: Small Block Mechanical fuel pump for HP ? [Re: lostdog] #2893034
02/25/21 02:17 PM
02/25/21 02:17 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I have one of those also
Re: Small Block Mechanical fuel pump for HP ? [Re: DavidDean] #2893040
02/25/21 02:30 PM
02/25/21 02:30 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Re: Small Block Mechanical fuel pump for HP ? [Re: lostdog] #2893205
02/25/21 09:47 PM
02/25/21 09:47 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have bought one of those years ago from Mancini and they tell you to buy the special eccentric, which has some special coating on it I guess. Not even sure it's needed or if the HD eccentric is still an available MP item? I just threw that out there so you could research it just to make sure....
Re: Small Block Mechanical fuel pump for HP ? [Re: Neil] #2893280
02/26/21 07:55 AM
02/26/21 07:55 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
S&S used to make one. But you have to use a regulator with it.
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: Small Block Mechanical fuel pump for HP ? [Re: Neil] #2893418
02/26/21 03:30 PM
02/26/21 03:30 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
There's one at summit that seems it will supply the fuel I believe I need. On the tab that says "required parts" and the eccentric isn't on there. I don't know if that means I need it or not lol
Re: Small Block Mechanical fuel pump for HP ? [Re: lostdog] #2893508
02/26/21 08:30 PM
02/26/21 08:30 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Why limit yourself with a mechanical pump?? work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Small Block Mechanical fuel pump for HP ? [Re: hemi-itis] #2893656
02/27/21 11:33 AM
02/27/21 11:33 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Exactly! Go with an external electric.
Re: Small Block Mechanical fuel pump for HP ? [Re: hemi-itis] #2893661
02/27/21 11:49 AM
02/27/21 11:49 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Do you think I would be limited in my application? According to flow to hp chart ; I would need about 65gph for 600 hp and some of these mechanical pumps are well over that. I'm not ruling out using an electric pump but I also don't believe in doing a bunch of unnecessary stuff
