What belt driven pump #2893015
02/25/21 12:30 PM
02/25/21 12:30 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
I need to know what belt driven pump you are using I looking at BLP AND AEROMOTIVE I am going to run the bypass regulator with a return line double adjustable. Blp is fixed at low rpm.AND adjust after idle the automotive is adjustable on both I think ??? I am running on alcohol thanks for any information. THANKS
Re: What belt driven pump [Re: dragon] #2896891
03/07/21 09:47 PM
03/07/21 09:47 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I’m currently running a Waterman pump, but have run Aeromotive without issue. Reason for change was that I went to cable driven pump.
Re: What belt driven pump [Re: mopar_mark] #2897007
03/08/21 08:22 AM
03/08/21 08:22 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Waterman should be able to convert to cable.
I run a waterman cable drive pump
Re: What belt driven pump [Re: dragon] #2897168
03/08/21 05:38 PM
03/08/21 05:38 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I have the APD on my dragster. 2-3 lbs at idle then goes up to 6-7 with rpm. Only downside is you have to fill the bowls if you change jets or run out of fuel...
Re: What belt driven pump [Re: FastmOp] #2897534
03/09/21 09:33 PM
03/09/21 09:33 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
What I meant was, I switched from Aeromotive to Waterman, as I wanted to run cable drive
