Re: Small Block Mechanical fuel pump for HP ?
[Re: Neil]
#2893019
02/25/21 01:11 PM
02/25/21 01:11 PM
Posts: 361 mississippi
lostdog
mississippi
Those Carter mech pumps require the special hardened eccentric too??? I didn't even consider this
[Re: DavidDean]
#2893040
02/25/21 02:30 PM
02/25/21 02:30 PM
Posts: 13,572 md
mopars4ever
md
[Re: lostdog]
#2893205
02/25/21 09:47 PM
02/25/21 09:47 PM
Posts: 20,492 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Those Carter mech pumps require the special hardened eccentric too??? I didn't even consider this I have bought one of those years ago from Mancini and they tell you to buy the special eccentric, which has some special coating on it I guess. Not even sure it's needed or if the HD eccentric is still an available MP item? I just threw that out there so you could research it just to make sure....
[Re: Neil]
#2893280
02/26/21 07:55 AM
02/26/21 07:55 AM
Posts: 324 Northport, al.
tvt59
Northport, al.
S&S used to make one. But you have to use a regulator with it.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
[Re: Neil]
#2893418
02/26/21 03:30 PM
02/26/21 03:30 PM
lostdog
mississippi
Those Carter mech pumps require the special hardened eccentric too??? I didn't even consider this I have bought one of those years ago from Mancini and they tell you to buy the special eccentric, which has some special coating on it I guess. Not even sure it's needed or if the HD eccentric is still an available MP item? I just threw that out there so you could research it just to make sure.... There's one at summit that seems it will supply the fuel I believe I need. On the tab that says "required parts" and the eccentric isn't on there. I don't know if that means I need it or not lol
[Re: lostdog]
#2893508
02/26/21 08:30 PM
02/26/21 08:30 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Which mechanical pump are you guys running for 500+ hp applications ? Why limit yourself with a mechanical pump??
[Re: hemi-itis]
#2893656
02/27/21 11:33 AM
02/27/21 11:33 AM
Posts: 971 rust belt
Moparite
rust belt
Why limit yourself with a mechanical pump?? Exactly! Go with an external electric.
[Re: hemi-itis]
#2893661
02/27/21 11:49 AM
02/27/21 11:49 AM
lostdog
mississippi
Which mechanical pump are you guys running for 500+ hp applications ? Why limit yourself with a mechanical pump?? Do you think I would be limited in my application? According to flow to hp chart ; I would need about 65gph for 600 hp and some of these mechanical pumps are well over that. I'm not ruling out using an electric pump but I also don't believe in doing a bunch of unnecessary stuff
