Re: Inside car battery shut off
[Re: humpty]
#2892671
02/24/21 01:14 PM
02/24/21 01:14 PM
Posts: 200 Texas
Chief
Texas
I looked at those but couldn't figure out how to actuate them from two points. Either way - I can see tech having an issue with them. It would be a nice setup with a big red kill button within easy reach.
I haven't wired one, but I would think it would wire up similar to a light that can be turned on or off from a switch on either side of the room.. Dave
Dave Covey
[Re: Chief]
#2892765
02/24/21 04:41 PM
02/24/21 04:41 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
Some of these solutions would make Rube Goldberg smile.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2892768
02/24/21 04:53 PM
02/24/21 04:53 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Some of these solutions would make Rube Goldberg smile. haha My solution to all this is to never turn the switch off unless the car is parked at home. Nothing on my car uses power when the key is off and I use a continuous duty solenoid for the alternator so even its not hot unless the key is on. I'll be honest though, if the car sits in the garage a few weeks I always forget to turn the power on when I get in, luckily I am not belted up for that.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: JERICOGTX]
#2892936
02/25/21 07:09 AM
02/25/21 07:09 AM
Posts: 10,009 MN
JERICOGTX
MN
I've already sent these to Jeff, but here is mine. I'd never build another car that didn't have a inside cutoff switch. Couple tabs, a morse cable,(that is a shifter cable from B&M), some heim joints, and a lever. Done.
69 GTX
68 Road Runner
