Re: 70 Charger what is this? part 2
[Re: ackpht]
#2892916
02/25/21 01:56 AM
02/25/21 01:56 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Redoing the Charger's interior. Here is another component that I can't find on the electrical schematic- the connecting wires are green, red, black, and black. The car originally had A/C but no longer.
[img]http://www.flickr.com/photos/184542831@N07/50978074837/in/dateposted-public/[/img]
[img]http://www.flickr.com/photos/184542831@N07/50977265433/in/dateposted-public/[/img]
Can anyone tell me what this is?
I can't see the pictures either BUT in my '70, the factory service manual wire diagrams are close but not 100% complete. My interior wiring was 100% original and unmolested when I bought the car. A couple years ago I was making some changes and use the FSM to identify and bypass some wires related to the HVAC system. I looked and looked at the main diagrams and the best that I found was a small section in the heating A/C section. Maybe the same applies here.
[Re: SNK-EYZ]
#2892959
02/25/21 09:52 AM
02/25/21 09:52 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
The second picture is a capacitor. IIRC that plugs into the circuit board in the same slot that the ignition terminal of the instrument voltage regulator uses.
[Re: 6PakBee]
#2893007
02/25/21 12:12 PM
02/25/21 12:12 PM
Posts: 3,096 Morgan Hill, CA
ackpht
Morgan Hill, CA
Thanks all, I should have Googled the part number. Not sure why the pics didn't show. In addition to previous owner changes and deletions, I also am finding that the shop manual schematics do not match the car exactly. The A/C components do not appear on the main schematic. There have to be a switch and relay for the A/C clutch somewhere, or at least sockets where they used to be. I'll take a clue from Frankenduster and check the other sections.
[Re: SNK-EYZ]
#2893133
02/25/21 06:37 PM
02/25/21 06:37 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
[Re: NachoRT74]
#2893159
02/25/21 07:58 PM
02/25/21 07:58 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Interesting on the headlight delay unit. Was that part of the A01 light package on 70 Charger? Or, separate option.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2893212
02/25/21 09:55 PM
02/25/21 09:55 PM
ackpht
Morgan Hill, CA
Group code A01 does appear on the build sheet for this car (no fender tag).
The delay unit does not appear on the electrical schematic, only a connector that leads to it. I still don't know where it was mounted, though the existing lead can reach either end of the dash.
There is another module that I cannot identify. It is a silver cylinder with three leads going to it. The only label is "MADE IN USA". All the leads going to it are yellow or yellow/black, and I can't find that in the schematic.
[Re: A990]
#2893221
02/25/21 10:22 PM
02/25/21 10:22 PM
ackpht
Morgan Hill, CA
Thanks. That would explain the L65 code on the build sheet.
I would think the headlight delay would be code L42, "H/LAMP TIME DELAY", but that space is blank on the build sheet. But I seem to have one anyway...
EDIT: wrong build sheet. Got the right one from the 70 Charger directory. Coded for L42. Far as I can tell the headlight delay relay hangs off the bottom of the glovebox.
