Post deleted by Defbob
[Re: 340B5]
#289255
04/15/09 05:52 PM
04/15/09 05:52 PM
Re: Anybody ever say."I am going as fast as i want to"
[Re: 340B5]
#289257
04/15/09 06:08 PM
04/15/09 06:08 PM
Posts: 3,695 nc
emarine01
nc
Hmmmmm, could be mabey need more bucks cut out more weight NO NEVER
[Re: RodStRace]
#289260
04/15/09 06:59 PM
04/15/09 06:59 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
There are several barriers that it takes a jump in expense/program to cross. The 11.49 is one, then 10.99 the next, then 9.99, and so on (NHRA tracks).
The question to ask yourself, aside from whether you can afford the next level, is what class do you want to be in? A 10 or 11-second car is relatively easy to build, and can run Super Pro, Pro, and/or Box or No-Box in bracket racing.
In my case, it does not make sense to change the heads, cam and carb to run 9.50's, as the 10.20's I run now will find me in the same classes.
[Re: Triple Threat]
#289261
04/15/09 07:06 PM
04/15/09 07:06 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
I've got a low 7 sec blown altered....and have ZERO desire to run that thing...
I have a desire to drive it If your looking
sure....23k deposit and have at it...all the loud pedal you can handle...
[Re: Chassisman]
#289262
04/15/09 07:16 PM
04/15/09 07:16 PM
Posts: 1,175 where its cold and white durin...
2QUICK4U
I WANT TO GO AS FAST AS I CAN,MY WALLET STOPS ME,SO EVERY NOW AND THEN,I GET STUPID AND RUN MY HAYABUSA 190 ,WHEN THE FREEWAY IS OPEN,OR I JUMP ON THE TOLL ROAD TO SAN DIEGO.HOPEFULLY WHEN I GET BACK TO WORK,I CAN BUILD THAT LOW 7 SEC CAR, SO FOR NOW,I JUST GET TO DO SOME OFF ROADING WITH MY WR450 DIRT BIKE,JUST NOT AS FUN AS THE RACE CAR WAS.
[Re: quickd100]
#289265
04/15/09 07:47 PM
04/15/09 07:47 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I put my old car together (again) about 3 years ago with the hope of 11.70s or so. I never thought of the street car going any faster.The first pass was a 11.40 and it got faster from there. 11.17 and now im looking for 10s. So in a word no, not there yet.
6.50 @105.26
[Re: 340RICK]
#289268
04/15/09 08:41 PM
04/15/09 08:41 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
[Re: 340RICK]
#289269
04/15/09 08:48 PM
04/15/09 08:48 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
No i'm not fast enough yet . this should be the motor that gets me into that 3 digit number . back in 70s 14s 13s 12.99 yes that was the magic number . Then in the 80s 12s got into mid 11s 90s was low 11s 2000 hit that 10.999 then 2005 got crazy 10.50s last year 10.20s 2009 should be 9s why 32 years racing a feather in my cap . I'm 50 and still playing hopefully racing has no age. don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: 10 o to go]
#289270
04/15/09 09:00 PM
04/15/09 09:00 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I don't want to go to the expense of taking the chassis cert from 8.50 to 7.50, so I'd like to hit it with a small shot of spray and run right at my chassis limits. Then I'm done. I'm pretty sure a small Monty shot should get me yelled at for going under the cert If I keep the car much longer I'll slow it down a little with a pump gas motor and turn up the spray. Then I can drive it more on the street and still go as fast at the track.
[Re: wildcargo]
#289271
04/15/09 09:02 PM
04/15/09 09:02 PM
No I drive it in the back door.
dude, that is just wrong, you must rephrase, immediately!!!!!!
#289272
04/15/09 09:10 PM
04/15/09 09:10 PM
dartman366
Mt. Vernon, Ohio
It's all in the mind of the beholder,,,,you been hanging around with Fred WAY too much.
