'62 343 hp 383 factory jetting? #2892195
02/23/21 11:44 AM
02/23/21 11:44 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
I recently built a B block using the factory inline 2x4 manifold. It will end up in a Christine clone, so it's actually a '350', but the intake manifold is the same. Had two Edelbrock AVS 500 cfm carbs on it, and took it to dyno. The A/F's were uneven from side to side, the carbs had the stock jetting. Just thought if the factory jetting/needles were biased someway like in a 426 Hemi, anyone happen to have information about the facory jetting?
Plynouth VIP '67 TT IC EFI
Re: '62 343 hp 383 factory jetting? [Re: jyrki] #2892280
02/23/21 02:25 PM
02/23/21 02:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
there's a big difference between factory 343hp carbs and those edelbrocks. i have race specs for the factory 2970s and 2971s carbs but they're a smaller different carb than the edelbrocks. long shot might be finding old 400cfm or 500cfm carter performance carbs from back in the '70's. when edelbrock made their "smaller" carb all they did was screw up the primary booster. crummy carbs in my opinion.
Re: '62 343 hp 383 factory jetting? [Re: lewtot184] #2892368
02/23/21 05:03 PM
02/23/21 05:03 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Yes, there may be, but I would assume the intake might want similar style jetting variation, and would like to know what the stock jetting was to decide weather there is any sence in trying. It can be driven as is, but it's far from being perfect.
Re: '62 343 hp 383 factory jetting? [Re: jyrki] #2892438
02/23/21 07:48 PM
02/23/21 07:48 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
the jetting for the 383 2 x4 is in the carb section of the mopar engine books .
Re: '62 343 hp 383 factory jetting? [Re: calrobb2000] #2892535
02/24/21 01:25 AM
02/24/21 01:25 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
I remembered so as well, but I looked at mine, and there isn't any with the factory intake, only Super Stock
Re: '62 343 hp 383 factory jetting? [Re: jyrki] #2892592
02/24/21 09:49 AM
02/24/21 09:49 AM
VA
dragon slayer Offline
VA
What are the original carbs you are trying to mimic? From the Carter book for the 1959-62 V8 they list the 2798 Frt and 2799 Rear for the 59 383 and 413.
Primary both are .089. The front Sec are .067 and the rear sec .055
These were 1 7/16 P and 1 9/16 S throats Idle jet .031 on both. Idle vacuum 19.5"
Re: '62 343 hp 383 factory jetting? [Re: dragon slayer] #2892603
02/24/21 10:24 AM
02/24/21 10:24 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the carb numbers i have are 2970 and 2971, but jetting appears to be the same as the 2798/2799. those small throttle bores would have small venturii (especially the secondaries compared to the edelbrocks) and the listed metering rods and small jets would be near impossible to find.
Re: '62 343 hp 383 factory jetting? [Re: jyrki] #2892618
02/24/21 11:02 AM
02/24/21 11:02 AM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Call Bob Kammer @ Kammer & Kammer Ents. 937-237-8675. He and his dad used to have one of those cars.
Re: '62 343 hp 383 factory jetting? [Re: jyrki] #2892675
02/24/21 01:38 PM
02/24/21 01:38 PM
A727Tflite Offline
A727Tflite  Offline
You have a baseline now, just work with what you have.
Trying to compare OE against aftermarket, race against stock, why waste you time.
Re: '62 343 hp 383 factory jetting? [Re: A727Tflite] #2892779
02/24/21 05:34 PM
02/24/21 05:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What I was thinking, change the ‘jet’ that feeds the cylinder with the issue, usually in the corners
Re: '62 343 hp 383 factory jetting? [Re: cudaman1969] #2892813
02/24/21 06:51 PM
02/24/21 06:51 PM
A727Tflite Offline
A727Tflite  Offline
That manifold is a real turd but I still am partial to them
Especially with the factory air cleaners on.
Re: '62 343 hp 383 factory jetting? [Re: A727Tflite] #2892909
02/25/21 01:09 AM
02/25/21 01:09 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Ok, since there doesn't seem to be much staggering with the original carbs, I think I'll leave it like it is. I was pretty amazed of how well it worked, the short block is a 4.25" stroke 400 with homeported old, factory looking source heads, comp cams 275 degree hydraulic flat tappet and stock valvetrain. The valvecovers are temprary.
Re: '62 343 hp 383 factory jetting? [Re: jyrki] #2892949
02/25/21 09:27 AM
02/25/21 09:27 AM
A727Tflite Offline
A727Tflite  Offline
Looking good in Finland. up
