'62 343 hp 383 factory jetting?
#2892195
02/23/21 10:44 AM
02/23/21 10:44 AM
Posts: 2,906 Finalnd, Perkele
jyrki
Finalnd, Perkele
I recently built a B block using the factory inline 2x4 manifold. It will end up in a Christine clone, so it's actually a '350', but the intake manifold is the same. Had two Edelbrock AVS 500 cfm carbs on it, and took it to dyno. The A/F's were uneven from side to side, the carbs had the stock jetting. Just thought if the factory jetting/needles were biased someway like in a 426 Hemi, anyone happen to have information about the facory jetting?
Plynouth VIP '67 TT IC EFI
Re: '62 343 hp 383 factory jetting?
[Re: lewtot184]
#2892368
02/23/21 04:03 PM
02/23/21 04:03 PM
jyrki
Finalnd, Perkele
Yes, there may be, but I would assume the intake might want similar style jetting variation, and would like to know what the stock jetting was to decide weather there is any sence in trying. It can be driven as is, but it's far from being perfect.
[Re: calrobb2000]
#2892535
02/24/21 12:25 AM
02/24/21 12:25 AM
jyrki
Finalnd, Perkele
I remembered so as well, but I looked at mine, and there isn't any with the factory intake, only Super Stock .
[Re: dragon slayer]
#2892603
02/24/21 09:24 AM
02/24/21 09:24 AM
Posts: 3,324 usa
lewtot184
usa
What are the original carbs you are trying to mimic? From the Carter book for the 1959-62 V8 they list the 2798 Frt and 2799 Rear for the 59 383 and 413.
Primary both are .089. The front Sec are .067 and the rear sec .055
These were 1 7/16 P and 1 9/16 S throats Idle jet .031 on both. Idle vacuum 19.5" the carb numbers i have are 2970 and 2971, but jetting appears to be the same as the 2798/2799. those small throttle bores would have small venturii (especially the secondaries compared to the edelbrocks) and the listed metering rods and small jets would be near impossible to find.
[Re: jyrki]
#2892675
02/24/21 12:38 PM
02/24/21 12:38 PM
Posts: 1,844 Michigan
Transman
I recently built a B block using the factory inline 2x4 manifold. It will end up in a Christine clone, so it's actually a '350', but the intake manifold is the same. Had two Edelbrock AVS 500 cfm carbs on it, and took it to dyno. The A/F's were uneven from side to side, the carbs had the stock jetting. Just thought if the factory jetting/needles were biased someway like in a 426 Hemi, anyone happen to have information about the facory jetting? You have a baseline now, just work with what you have. Trying to compare OE against aftermarket, race against stock, why waste you time.
[Re: Transman]
#2892779
02/24/21 04:34 PM
02/24/21 04:34 PM
Posts: 5,309 fredericksburg,va
cudaman1969
fredericksburg,va
I recently built a B block using the factory inline 2x4 manifold. It will end up in a Christine clone, so it's actually a '350', but the intake manifold is the same. Had two Edelbrock AVS 500 cfm carbs on it, and took it to dyno. The A/F's were uneven from side to side, the carbs had the stock jetting. Just thought if the factory jetting/needles were biased someway like in a 426 Hemi, anyone happen to have information about the facory jetting? You have a baseline now, just work with what you have. Trying to compare OE against aftermarket, race against stock, why waste you time. What I was thinking, change the ‘jet’ that feeds the cylinder with the issue, usually in the corners
[Re: Transman]
#2892909
02/25/21 12:09 AM
02/25/21 12:09 AM
jyrki
Finalnd, Perkele
Ok, since there doesn't seem to be much staggering with the original carbs, I think I'll leave it like it is. I was pretty amazed of how well it worked, the short block is a 4.25" stroke 400 with homeported old, factory looking source heads, comp cams 275 degree hydraulic flat tappet and stock valvetrain. The valvecovers are temprary.
