Re: Mom's 68 road runner
[Re: Hemi Allstate]
#2920995
05/10/21 10:56 PM
05/10/21 10:56 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
How's it going? Was thinking about this project today.
Rich H.
Esse Quam Videri
[Re: Hemi Allstate]
#2921632
05/12/21 12:43 PM
05/12/21 12:43 PM
ZIPPY
S.E. Michigan
Thanks for the update! Roof looks so nice, clean and shiny. Wish I could say the same, will probably end up changing the roof skin.
Did the left quarter, repaired everything behind it and am working on the right side now.
Will probably end up doing a build thread at some point.
Had a similar issue with uphill climbing a few year ago, as I had to move my '68 Charger out of the detached shop to get the GTX in, and move the Charger to the attached garage which the driveway has an uphill slope. So I had to climb a hill to get in (rather than to get out). The original 318 is still in it and runs fine, trans is good etc but the master cylinder froze up years ago so I wasn't too comfortable driving it in there. Nobody was around to help at the time and I ended up slowly pulling it in there with my tractor. Hope to get to that one after the GTX. Big plans for it...hopefully life will cooperate.
Rich H.
Esse Quam Videri
[Re: Hemi Allstate]
#2922058
05/13/21 11:09 AM
05/13/21 11:09 AM
ZIPPY
S.E. Michigan
The trunk was good enough for me as it sat, I had blasted,patched it and shot DP90LF on it many years ago which preserved it, but the rear crossmember and frame tabs that connect to it were bad.
Once all the back spot welds (rear crossmember/trunk/tail panel area) were dealt with, and one quarter panel was cut off the only thing in the way of changing the trunk floor was 2 down bars/roll bar which (after the plates were cut off) I was able to flex upward with a ratchet strap just enough to sneak in a once piece trunk floor from the side.
So one thing led to another and I did put a trunk floor in it. I know I will be happier with the end result, and saved myself hours of repairing and straightening the rear spot weld area.
I didn't want to cut my trunk gutters b/c being a '69 the partial VIN is documented on the left one, so I just cleaned them up and repaired bad spots.
I'm using the new AMD larger inner wheelhouses to mini tub, there was enough rust at the bottom of the originals to make them worth changing. Spring relocation will have to wait, but at least by then more than half the job will already be done.
Yep you are right, I should probably start a thread.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2922227
05/13/21 08:24 PM
05/13/21 08:24 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Yep you are right, I should probably start a thread. [/quote] And lots of pictures ! These projects can very easily snowball . DAMHIK Mark
[Re: basketcase]
#2923053
05/16/21 07:19 AM
05/16/21 07:19 AM
Hemi Allstate
Mt. Eden Ky.
Ha Ha ! Imagine that ! Looking good Dave ! Thanks ! Mark
[Re: Hemi Allstate]
#2925230
05/21/21 02:39 PM
05/21/21 02:39 PM
ZIPPY
S.E. Michigan
Nice! Other than work to smooth the rear corner (where top of the quarter meets the side + the quarter extension), any other effort needed to make the quarter mate with the quarter extension? It looks like the '69 quarters are farther off in the tail light area than the '68s, as I had to add metal in a few places to make mine mate up with the extensions. And yes, I need to start a build thread to illustrate that I test fit my rear window trim and will need similar rework in that area to get it in the ballpark ( but I'm not touching it until the dutchman is replaced). Sure is nice to see all that work sealed up!
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2949673
08/02/21 12:44 PM
08/02/21 12:44 PM
Hemi Allstate
Mt. Eden Ky.
Hey Rich, Sorry I am slow to reply. I have made a little progress on the car. The quarters and roof are in good shape after blocking the quarters several times. I removed the deck lid , and stripped it. It had some rust in the pinch weld at the lower rear of the lid and one other small place that I welded up. The lid was then epoxy primed and I have "ironed" the top of it before it was re-primed with urethane and began blocking it out. I think one more time will get it ,as it is looking pretty good now. The driver's door is next. It was hit in a parking lot incident when the car was a couple years old. I don't think it was bad though. I made a handle out of romex to help me carry the lid to and from the paint booth easily. Thanks for asking ! Hows the GTX coming along? Mark
[Re: Hemi Allstate]
#2949971
08/03/21 11:26 AM
08/03/21 11:26 AM
ZIPPY
S.E. Michigan
That's great! Nice to see things are moving along Things escalated a little bit on my end and now I'm working on a new roof skin. I'm trying not to rush + post-covid music gigs came back (guitar player -vocalist part time/auto parts electronic cataloging full time) I've done a vlog on my Facebook to keep track, of it all using an old device I keep in the shop.... Saving the videos to a memory card so I can always play them and take still screen shots of important stuff later for pics, if and when I get around to posting a build thread somewhere, either here or forbbodiesonnly, or both. .....for the time being I'm kind of using Facebook as a free storage/discussion with FB friends area.... . Keep up the great work sir
Rich H.
Esse Quam Videri
[Re: 69Cuda340S]
#2950052
08/03/21 03:47 PM
08/03/21 03:47 PM
Hemi Allstate
Mt. Eden Ky.
What a story and history on that car. And to restore your mothers car with your own hands, and doing an outstanding job too, amazing. Love this project!! Thank you 69Cuda , I am glad that you are enjoying the story, and I appreciate your kind words. Mark
[Re: ZIPPY]
#2950055
08/03/21 04:05 PM
08/03/21 04:05 PM
Hemi Allstate
Mt. Eden Ky.
[quote=ZIPPY]That's great! Nice to see things are moving along Things escalated a little bit on my end and now I'm working on a new roof skin. I'm trying not to rush + post-covid music gigs came back (guitar player -vocalist part time/auto parts electronic cataloging full time) I've done a vlog on my Facebook to keep track, of it all using an old device I keep in the shop.... Saving the videos to a memory card so I can always play them and take still screen shots of important stuff later for pics, if and when I get around to posting a build thread somewhere, either here or forbbodiesonnly, or both. .....for the time being I'm kind of using Facebook as a free storage/discussion with FB friends area.... Thanks Rich, I am not rushing it, just focusing on one piece at a time. It's still making some progress, just a little slow. I have also been working on the taillights , and other small parts. That's good that you are able to do gigs again. We all hope that doesn't change. I enjoy playing guitar, but I am not a performing artist like yourself. I entertain myself mostly ! I am on FB I would love to check out your progress. Can you send me a link to your FB page ? Thanks, Mark .
