Page 1 of 3 1 2 3
Which is Faster, Bore & Stroke ? #2891647
02/21/21 08:38 PM
02/21/21 08:38 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Lets say rpm limit is 7k and engine size is 555.....There are a number of combinations to get near the cube limit, but which would be quicker? A smaller bore and big stroke, or a big bore small stroke?
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891650
02/21/21 08:46 PM
02/21/21 08:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
My thinking is that steep rod angles hurt power. I'd llean towards a bore that's equal to or larger than the stroke. but that's only my thought, I'm not an engine builder.
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891651
02/21/21 08:51 PM
02/21/21 08:51 PM
Andrews,In. U.S.of A.
67_Satellite Offline
A lot of other factors go into which would be "quicker", but for a given engine family, go with the biggest bore which is practical, then adjust stroke to get the cubes desired.
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891663
02/21/21 09:05 PM
02/21/21 09:05 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Bigger bores mean more reciprocating weight and more drag.
I imagine the proper answer is a nice blend of the two.
- Stu Harmon
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891672
02/21/21 09:24 PM
02/21/21 09:24 PM
I'm thinking the type of motor, N/A or what type power adder, will have something to do which works better. scope
Don't most of the faster all out Pro Stock N/A motors have a 4.625 size bore with less than 4.0 inch stroke to make 500 C.I.. On your deal I would look at 4.5+ on the bore and around 4.375 stroke to get close to 555 C.I. scope Adjust as needed wrench up
My next all out N/A motor will start as a 4.500 bore Koleno block with a older 4.375 stroke Bryant top fuel full counter weighted crankshaft with 2.200 rod journals with B1-MC heads and a pair of Dominator carbs up
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891681
02/21/21 09:46 PM
02/21/21 09:46 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Not sure but I ended up going with 4.5 bore and a 4.35 stroke. Using 7.1 rods with 2.2 rod journals. Ends up being a tad over 553 CI.
Ok
Re: Which is Faster, Bore & Stroke ? [Re: cudatom] #2891691
02/21/21 10:08 PM
02/21/21 10:08 PM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
On gasoline, the biggest bore possible makes the most power, because moving the cylinder wall away from the valve improves flow. Assuming adequate cylinder wall thickness for effective ring seal.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891692
02/21/21 10:10 PM
02/21/21 10:10 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
Wedge or Hemi ? Wedge the big bore Short stroke seems to be the go to...... Canted valve leans towards Big Bore short stroke also
.... for Hemi....... I don't think it matters as much.
Current Pro stock thinking is 4.71-4.75 bore and stroke in the 3.5, 3.55 depending on deck height rods are in the 5.95-6.10 range .Last DRCE my uncle built was a 8.70 DH , 4.71X3.55 with 6.10 C to C rods.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
Re: Which is Faster, Bore & Stroke ? [Re: Taylor] #2891698
02/21/21 10:39 PM
02/21/21 10:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Stroke will make more power, most engines can only go .060 but you can stroke them 1/2 inch or more. Chevy, I know I know, 427-4.25 bore x 3.75 stroke, 454 4.25 bore x 4.00 stroke, which makes more power turning same rpm?
Re: Which is Faster, Bore & Stroke ? [Re: cudaman1969] #2891720
02/22/21 12:12 AM
02/22/21 12:12 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
One of the magazines did a big bore short stroke vice versa dyno comparison some years ago. Same heads, cam and induction.
I don't recall the difference being more than a few HP.
As far as which one might be faster, I suspect if there is any difference between 2 engines that make the sameish power, it will be the engine that can accelerate itself the quickest.
Kevin
Re: Which is Faster, Bore & Stroke ? [Re: Twostick] #2891725
02/22/21 12:39 AM
02/22/21 12:39 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
500 inch blown fuel engines are long stroke, small bore. 500 inch gasoline ProStock engines are big bore, short stroke.
Torque monster - more stroke. Peaky high RPM - big bore, big valves.
7k limit would favor a long stroke.
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891729
02/22/21 12:58 AM
02/22/21 12:58 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
From my experience, you want the biggest bore, and still keep the cylinder walls thick enough they do not flex, you don't make any power if the rings don't stay sealed under power. And on the dyno testing, just keeping track of the engines I dynoed, the peak numbers may be close, but those that I did the average HP numbers were always higher on the big bore engines, and higher average numbers usually will out run higher peak numbers given the same chassis combination. The best example was to 383 small block chey's I built for mud jeeps. One was a 350 block stroked, the other was a 400 de-stroked. The 350 had some better heads, and made about 20HP more, but the 400 had better average numbers, in the mud pit, the 400 jeep smoked the 350 block.
Re: Which is Faster, Bore & Stroke ? [Re: CMcAllister] #2891740
02/22/21 02:20 AM
02/22/21 02:20 AM
Minnesota
Minnesota
The fuel motors really need the wall thickness. Plus the slow burning nitro doesn't mind the long stroke.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Which is Faster, Bore & Stroke ? [Re: Twostick] #2891792
02/22/21 10:27 AM
02/22/21 10:27 AM
New York
polyspheric Offline
polyspheric  Offline
New York
That's the reason.
Boffin Emeritus
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891841
02/22/21 12:31 PM
02/22/21 12:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In the mid-level typical bracket race engine(1.5-ish hp/ci), assuming the head/induction/exhaust are identical between the two configurations(and are appropriately sized for the desired output) I would expect the power difference to be negligible, especially if there is going to be an upper rpm limit of 7K.
Re: Which is Faster, Bore & Stroke ? [Re: fast68plymouth] #2891845
02/22/21 12:40 PM
02/22/21 12:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
7000 rpm is the limiting factor IMO. Would likely flavor more stroke. But generally a bigger bore will make more power than more stroke, but when you are talking BB Mopar the bores are not very large for sure. The old saying bore makes power stroke moves where it happens.
Re: Which is Faster, Bore & Stroke ? [Re: polyspheric] #2891848
02/22/21 12:54 PM
02/22/21 12:54 PM
Minnesota
Minnesota
That's the reason.
Why would you keep everything the same? The bore and stroke needs to be considered when building the rest of the motor. You can use a bigger intake valve if you have a 4.5-in bore versus a 4.310 bore. Cam events would be different with a shorter stroke versus longer stroke, and the intake. That's the problem with some of these comparisons that the magazines and TV shows do. They don't build the motor around the one variable that they are testing.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Which is Faster, Bore & Stroke ? [Re: Hemi_Joel] #2891855
02/22/21 01:22 PM
02/22/21 01:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
As long as the bore doesn't restrict the size of the intake valve at the desired RPM level, it doesn't make much difference. If your combo needs more valve and it won't fit. Then it needs more bore.
Doug
Re: Which is Faster, Bore & Stroke ? [Re: dvw] #2891862
02/22/21 01:36 PM
02/22/21 01:36 PM
Dragula Offline OP
Dragula  Offline OP
Originally Posted by dvw
As lon[s][/s]g as the bore doesn't restrict the size of the intake valve at the desired RPM level, it doesn't make much difference. If your combo needs more valve and it won't fit. Then it needs more bore.
Doug
So the bigger bore shows its an advantage right there.
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2891878
02/22/21 02:26 PM
02/22/21 02:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
You don’t understand, ya gotta play with what you have available. Really like to see some of these 5” bore mopar engines. Like hitting a nail, short swing, nail won’t go deep, big swing that nail going clear thru. Bigger hammer might help a little but big swing gets the job DONE. One of the 5 basic tools, a lever!
Page 1 of 3 1 2 3
