Re: Which is Faster, Bore & Stroke ?
[Re: Dragula]
#2891663
02/21/21 09:05 PM
02/21/21 09:05 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Bigger bores mean more reciprocating weight and more drag.
I imagine the proper answer is a nice blend of the two.
[Re: Dragula]
#2891681
02/21/21 09:46 PM
02/21/21 09:46 PM
Posts: 1,103 Massillon, Ohio
cudatom
Massillon, Ohio
Not sure but I ended up going with 4.5 bore and a 4.35 stroke. Using 7.1 rods with 2.2 rod journals. Ends up being a tad over 553 CI.
Ok
[Re: cudatom]
#2891691
02/21/21 10:08 PM
02/21/21 10:08 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
On gasoline, the biggest bore possible makes the most power, because moving the cylinder wall away from the valve improves flow. Assuming adequate cylinder wall thickness for effective ring seal.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Dragula]
#2891692
02/21/21 10:10 PM
02/21/21 10:10 PM
Posts: 70 Souderton
Taylor
Souderton
Wedge or Hemi ? Wedge the big bore Short stroke seems to be the go to...... Canted valve leans towards Big Bore short stroke also .... for Hemi....... I don't think it matters as much.
Current Pro stock thinking is 4.71-4.75 bore and stroke in the 3.5, 3.55 depending on deck height rods are in the 5.95-6.10 range .Last DRCE my uncle built was a 8.70 DH , 4.71X3.55 with 6.10 C to C rods.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi 2020 1320 Challenger....stock daily driver.
[Re: Taylor]
#2891698
02/21/21 10:39 PM
02/21/21 10:39 PM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
Stroke will make more power, most engines can only go .060 but you can stroke them 1/2 inch or more. Chevy, I know I know, 427-4.25 bore x 3.75 stroke, 454 4.25 bore x 4.00 stroke, which makes more power turning same rpm?
[Re: Twostick]
#2891725
02/22/21 12:39 AM
02/22/21 12:39 AM
Posts: 11,637 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
500 inch blown fuel engines are long stroke, small bore. 500 inch gasoline ProStock engines are big bore, short stroke.
Torque monster - more stroke. Peaky high RPM - big bore, big valves.
7k limit would favor a long stroke.
[Re: Dragula]
#2891729
02/22/21 12:58 AM
02/22/21 12:58 AM
Posts: 880 Missouri
jwb123
Missouri
From my experience, you want the biggest bore, and still keep the cylinder walls thick enough they do not flex, you don't make any power if the rings don't stay sealed under power. And on the dyno testing, just keeping track of the engines I dynoed, the peak numbers may be close, but those that I did the average HP numbers were always higher on the big bore engines, and higher average numbers usually will out run higher peak numbers given the same chassis combination. The best example was to 383 small block chey's I built for mud jeeps. One was a 350 block stroked, the other was a 400 de-stroked. The 350 had some better heads, and made about 20HP more, but the 400 had better average numbers, in the mud pit, the 400 jeep smoked the 350 block.
[Re: CMcAllister]
#2891740
02/22/21 02:20 AM
02/22/21 02:20 AM
Hemi_Joel
Minnesota
7k limit would favor a long stroke. The fuel motors really need the wall thickness. Plus the slow burning nitro doesn't mind the long stroke.
[Re: Twostick]
#2891792
02/22/21 10:27 AM
02/22/21 10:27 AM
Posts: 4,209 New York
polyspheric
New York
Same heads, cam and induction
That's the reason.
Boffin Emeritus
[Re: Dragula]
#2891841
02/22/21 12:31 PM
02/22/21 12:31 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
In the mid-level typical bracket race engine(1.5-ish hp/ci), assuming the head/induction/exhaust are identical between the two configurations(and are appropriately sized for the desired output) I would expect the power difference to be negligible, especially if there is going to be an upper rpm limit of 7K.
[Re: fast68plymouth]
#2891845
02/22/21 12:40 PM
02/22/21 12:40 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
7000 rpm is the limiting factor IMO. Would likely flavor more stroke. But generally a bigger bore will make more power than more stroke, but when you are talking BB Mopar the bores are not very large for sure. The old saying bore makes power stroke moves where it happens.
[Re: polyspheric]
#2891848
02/22/21 12:54 PM
02/22/21 12:54 PM
Hemi_Joel
Minnesota
That's the reason. Why would you keep everything the same? The bore and stroke needs to be considered when building the rest of the motor. You can use a bigger intake valve if you have a 4.5-in bore versus a 4.310 bore. Cam events would be different with a shorter stroke versus longer stroke, and the intake. That's the problem with some of these comparisons that the magazines and TV shows do. They don't build the motor around the one variable that they are testing.
[Re: dvw]
#2891862
02/22/21 01:36 PM
02/22/21 01:36 PM
Posts: 12,401 Taxes & Virus's R-US, NY
Dragula
As lon[s][/s]g as the bore doesn't restrict the size of the intake valve at the desired RPM level, it doesn't make much difference. If your combo needs more valve and it won't fit. Then it needs more bore. Doug So the bigger bore shows its an advantage right there.
[Re: Dragula]
#2891878
02/22/21 02:26 PM
02/22/21 02:26 PM
cudaman1969
fredericksburg,va
You don’t understand, ya gotta play with what you have available. Really like to see some of these 5” bore mopar engines. Like hitting a nail, short swing, nail won’t go deep, big swing that nail going clear thru. Bigger hammer might help a little but big swing gets the job DONE. One of the 5 basic tools, a lever!
