Torque converter in Procharged BB combos #2891402
02/21/21 11:38 AM
02/21/21 11:38 AM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
For those who run a milder boosted BB (up to 10 psi of boost) in a street driven combo backed by a 727, what torque converter are you using?
Not asking necessarily about stall speed, but what brand and model of converter? Steel stator? Anti-balloning plate etc?
Thank you in advance
Re: Torque converter in Procharged BB combos [Re: B5496RR] #2891407
02/21/21 11:54 AM
02/21/21 11:54 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
ATI makes some great convertors for blown applications. I actually run one of their 9.5 blown A convertors in my street driven 605 Hemi due to the massive amount of torque it makes. Love it. Temps are nice and cool and it works really well..
Re: Torque converter in Procharged BB combos [Re: Dragula] #2891438
02/21/21 12:34 PM
02/21/21 12:34 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
PTC
Re: Torque converter in Procharged BB combos [Re: B5496RR] #2891449
02/21/21 12:46 PM
02/21/21 12:46 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I am very happy with the converter Ultimate Converter Concepts reworked for me. I had a converter that was setup for a NA 430 and recently switched to a Gen 3 hemi with supercharger. The converter was way off with the supercharged hemi and UCC reworked it. I picked up 6 mph in the 1/8 mile. Ultimate Converter was very easy to work with and the converter is performing great, showing 7% slippage in the 1/4.
Re: Torque converter in Procharged BB combos [Re: B5496RR] #2891609
02/21/21 07:10 PM
02/21/21 07:10 PM
Andrews,In. U.S.of A.
67_Satellite Online content
67_Satellite  Online Content
I ran an old 11" 2200 r.p.m. stall Fairbanks behind the old 383with E-heads,8.0:1 compression, small cam@ 15 lbs. of boost without any ill effects. It was originally bought in the mid 80's by a friend, and I got it in a bunch of parts which was part of a barter/trade deal. I ran it because I had it, but it wasn't right for the combo. Didn't hurt it and couldn't" drive through it" like I did the cheap 10" 3K stall I tried later. I still have it, and would use it again with confidence in the right application. I currently have a 9.5" Dynamic behind the 470 which was built for the combo. It acts like a "loose" convertor for the first 15 feet from a dead stop, drives like a stocker after that cruising unless I get on the go pedal, when it becomes a loose convertor again. Really the best of both worlds. If you have the $$$ have one made by a good company to your specifications. If no bucks are available for the "right " one get the best name brand, non-custom convertor you can afford.
Re: Torque converter in Procharged BB combos [Re: B5496RR] #2891612
02/21/21 07:16 PM
02/21/21 07:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The real questions:
What RPM do you have boost?
Do you need it to launch?
Boffin Emeritus
Re: Torque converter in Procharged BB combos [Re: polyspheric] #2891642
02/21/21 08:15 PM
02/21/21 08:15 PM
napa ca
P
procharged 484 Offline
P
napa ca
Go to PTC website fill out spec sheet and find out exactly what you need . I have one behind a 484 hemi with F2 and it drives fantastic on street
Re: Torque converter in Procharged BB combos [Re: procharged 484] #2892112
02/23/21 08:39 AM
02/23/21 08:39 AM
pa
572charger Offline
572charger  Offline
pa
no body would make me a converter for a 727 making 1400 hp even lenny said i need a 10 " converter and he didnt make one only company that would was Coan every company said i would break the transmission
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
