Cutting Dana for a e- body #2891574
02/21/21 05:28 PM
02/21/21 05:28 PM
Btween a rock and a hard place
moparlulu Offline OP
Cutting a truck Dana 60 down for a a 70 challenger and can’t remember how much offset the tubes need from side to side anyone? Forgetfulness sucks!
Re: Cutting Dana for a e- body [Re: moparlulu] #2891576
02/21/21 05:36 PM
02/21/21 05:36 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
There is a calculator on Dr. Diffs web site.
Re: Cutting Dana for a e- body [Re: moparlulu] #2891622
02/21/21 07:28 PM
02/21/21 07:28 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If you are going to put big tires on the rear it would be wise to cut it to 68-70 b-body, or 67 b-body width, and use doc diff hangers. I would do it to any e-body.unless it was a 100 point car. 1-3/8" offset on the one I have.
Re: Cutting Dana for a e- body [Re: 4406bbl] #2891818
02/22/21 11:35 AM
02/22/21 11:35 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I should be more clear, the drivers side tube is 1-3/8" longer, the offset may be a little less.
Re: Cutting Dana for a e- body [Re: 4406bbl] #2892052
02/22/21 10:44 PM
02/22/21 10:44 PM
It shows 1 3/16” offset for most mopars, so I’ll use that. He “the owner” wants to stay with the wheels he has now.... he bought everything from The dr. Thanks for the help....
Re: Cutting Dana for a e- body [Re: 4406bbl] #2892517
02/23/21 11:47 PM
02/23/21 11:47 PM
CA
crackedback Offline
crackedback  Offline
CA
THIS ^^^^^^
The drivers tube is 1 3/8" longer which then places the pinion in the proper position.
