Best Mini Starter? #289143
04/15/09 01:58 PM
04/15/09 01:58 PM
Dyno1 Offline OP
Dyno1  Offline OP
I have a new 440 Source Mini starter that does not like to start my hemi superstock engine. Who makes the best mini-starter for this? Thanks, Dyno
Post deleted by Defbob [Re: Dyno1] #289144
04/15/09 02:02 PM
04/15/09 02:02 PM
Re: Best Mini Starter? [Re: Dyno1] #289145
04/15/09 02:02 PM
04/15/09 02:02 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
I tried the autozone route and bought one for a new truck. That didn't work out well. I've heard good things about the ones from Mancini.
Re: Best Mini Starter? [Re: Dyno1] #289146
04/15/09 02:09 PM
04/15/09 02:09 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Robb MC Starter
Parts are available for them too on the website.
And he supports Moparts by using ad space on this forum.
https://board.moparts.org/ubbthreads/show...rue#Post5111743
https://board.moparts.org/ubbthreads/show...rue#Post5112198
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Best Mini Starter? [Re: HealthServices] #289147
04/15/09 02:18 PM
04/15/09 02:18 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I can personally attest to the fact that the Mancini one is awesome and cheap. I took out a Big End starter and replaced it and thought the Mancini was gonna twist the engine out of the hood. For $100 bones I was astonished!
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Best Mini Starter? [Re: Irun5snd8th] #289148
04/15/09 02:38 PM
04/15/09 02:38 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I can honestly say, the RobbMC starter is hands down, the best mini-starter I have ever owned. You bolt it up, and can actually spin the assembly, and adjustwhere you want to have the terminals. It was the only starter I couold find without having to beat-uo the headers on my 71 Plymouth 4 speed, with an 11 inch flywheel and TTI headers. I promise you reat customer support and a superbly engineered starter.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Best Mini Starter? [Re: sunroofgtx] #289149
04/15/09 02:43 PM
04/15/09 02:43 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I have had very good luck with powermaster starter. The mopar mini starter hit the oil galley on my KB block.
Re: Best Mini Starter? [Re: Bigcube] #289150
04/15/09 02:58 PM
04/15/09 02:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have been using salvage starters and have not gotten a bad one or had one go bad at 25-35 bucks a shot.
Re: Best Mini Starter? [Re: MoparforLife] #289151
04/15/09 05:14 PM
04/15/09 05:14 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
What compression is that hemi.I have 12.5 in the 440 and my mini spins it like a /6.My kid has the Source mini in his hipo 413 and it does the same.Unless you are 14 or 15 to one something is wrong.Rocky
Chrysler Firepower
Re: Best Mini Starter? [Re: MoparforLife] #289152
04/15/09 05:17 PM
04/15/09 05:17 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Robb MC Starter
I bought one last year. It has an adjustable nose, is small, and starts my 572 16-1 motor. It's a nice piece. Don't go low budget on a starter. It'll let ya down.
Re: Best Mini Starter? [Re: camastomcat] #289153
04/15/09 05:44 PM
04/15/09 05:44 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Powermaster
I have had it so hot that you could light a cigarette off of it .
Still works great.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Best Mini Starter? #289154
04/15/09 05:50 PM
04/15/09 05:50 PM
Stratford nj
cudadan Offline
cudadan  Offline
Stratford nj
been using factory starters for years no problems
, i use one from a 90 dodge ram, its a mini and it works perfect in my cuda
Re: Best Mini Starter? [Re: Bigcube] #289155
04/15/09 05:54 PM
04/15/09 05:54 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
Had a csr & the shaft broke put the powermaster back in no problems & its
been a while
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: Best Mini Starter? [Re: DRDart] #289156
04/15/09 06:14 PM
04/15/09 06:14 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
stock v6 starter on my last 4 motors from 14.5 to 16 to 1 never had a problem
Re: Best Mini Starter? [Re: plycuda] #289157
04/15/09 10:04 PM
04/15/09 10:04 PM
Dyno1 Offline OP
Dyno1  Offline OP
I ordered a XS Powermaster. I'll let everyone know how it works. the 440 source worked twice, then gave up? thanks everyone for the response. Dyno
Re: Best Mini Starter? [Re: Dyno1] #289158
04/15/09 10:17 PM
04/15/09 10:17 PM
The only starter i will ever usea gain is the MEZIERE TS104 starter, cranks like no order starter i have ever used, and im at 14.8 compression.
powermaster didnt sit right in my megablock. i couldnt get it to line up and i turned it in all different directions with adjustable positions.
Re: Best Mini Starter? #289159
04/15/09 10:25 PM
04/15/09 10:25 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Another vote for RobbMC. Customer service exceeds expectations should you ever need it.
Re: Best Mini Starter? [Re: Bigcube] #289160
04/15/09 10:56 PM
04/15/09 10:56 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The p/master is a nice unit,I have a mopar mini.There are 2 mopar mini starters,if you try to use the small block starter on a big block,it hits and needs to be clearanced!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Best Mini Starter? [Re: hemi-itis] #289161
04/16/09 12:34 AM
04/16/09 12:34 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i bought a Source starter as a spare but fitted it this season to try it out. never missed a beat all season long. you might have some kind of issue if your source starter isn't cutting it. i'm 512 cubes @ 12.5:1 & very happy with mine.
