assembly lube #2891031
02/20/21 01:59 PM
02/20/21 01:59 PM
St.Pete,Florida
lancer493 Offline OP
St.Pete,Florida
I'm assembling a big block for race only application.Am mainly interested in piston/cylinder/ ring assembly lube.What have you used in this specific area of assembly when the engine won't be run immediately. It will sit for a while before firing up, as I haven't put the trans together yet. Thanks, Bill
Re: assembly lube [Re: lancer493] #2891032
02/20/21 02:05 PM
02/20/21 02:05 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Yo Bill ... last one I did was with a straight 30 weight oil with high zinc ....,
Kendall I believe...
Re: assembly lube [Re: dOrk !] #2891102
02/20/21 03:52 PM
02/20/21 03:52 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
STP . My favorite
....BAD A$$ STREET CAR.....
Re: assembly lube [Re: dOrk !] #2891107
02/20/21 04:08 PM
02/20/21 04:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Ya that was probably 30 years ago. Lol 😂
Kendal oil changed names at least twice since then. Brad Penn and now Penn Grade. Still great oil.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: assembly lube [Re: pittsburghracer] #2891111
02/20/21 04:10 PM
02/20/21 04:10 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
nothing but wd 40 here. never failed
Re: assembly lube [Re: pittsburghracer] #2891159
02/20/21 05:58 PM
02/20/21 05:58 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
That Puttsylvania oil can’t be beat !
I still have HALF A CASE of oil that has followed me around the last THIRTY? years ......
Me thimks It came from my grandpa !
Re: assembly lube [Re: dOrk !] #2891185
02/20/21 07:23 PM
02/20/21 07:23 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Scheafer 20w-50 racing oil. It looks kinda greenish. That is some sticky stuff.
Brian
Re: assembly lube [Re: '72CudaRacer] #2891197
02/20/21 08:30 PM
02/20/21 08:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You guys put some pretty heavy stuff on the rings(except the WD40 guy) I use Castle brand lube called Thrust on all my ring/piston assembly jobs. It's a little thicker than WD40 so it should hang in there longer until you fire it up. twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: assembly lube [Re: fourgearsavoy] #2891204
02/20/21 08:51 PM
02/20/21 08:51 PM
St.Pete,Florida
St.Pete,Florida
Lots of ideas here.I'm sure they all work well. My main concern is what will remain effective if I store it for a while before I fire it up. Thanks, Bill
Re: assembly lube [Re: lancer493] #2891256
02/20/21 11:02 PM
02/20/21 11:02 PM
I use 5W20Wt on all the bearing ,pistons and rings, cylinders walls get lube off of the residual oil on the rings and piston skirts and I wipe the cylinder walls several times to get the excess oil off of the cylinder walls with a clean white rag to get them as clean as possible after thoroughly cleaning them before assembling the short block. No assembly lube for me, the motor runs on oil, correct work thumbs
I use the cam lube call for by the cam maker on the lobes if it is flat tappet type cam and not a roller cam and lifter up wrench
you can not keep the motor to clean while prepping it and assembling it.
I do prime the motors and rotate them over on the engine stand with the spark plugs out and again before starting them in the car or on the engine dyno with the starter with the plugs out wrench up
Re: assembly lube [Re: Cab_Burge] #2891260
02/20/21 11:13 PM
02/20/21 11:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have been told by guys who build a lot of serious engines not to make the rings and lands sloppy wet as the oil creates issues, coking, etc on start up. In the old days, guys used to dunk the piston in a bucket of oil before installing it. Not good.
I use motor oil on the cylinder walls, rings, skirts, etc. Not dripping wet, just lubed. Bearings, cams, rocker gear, etc. gets GM EOS. I have some of the good old high zinc stuff that has followed me around over the years.
Pre-lube just before starting is also done.
Re: assembly lube [Re: CMcAllister] #2891289
02/21/21 01:42 AM
02/21/21 01:42 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Total Seal recomends using a powder they sell on rings, seats the rings faster, I used it and appears it works ok.
Re: assembly lube [Re: wyoming] #2891296
02/21/21 03:00 AM
02/21/21 03:00 AM
I've never had a ring seal problem even when I use to dip the complete piston in oil and never wipe the cylinder walls down to remove the excessive oil shruggy
I have also tried installing the rings and piston dry using the old Total Seal recommendation on their zero gap rings back in the mid 1970, only once though realcrazy shruggy
Re: assembly lube [Re: Cab_Burge] #2891309
02/21/21 07:38 AM
02/21/21 07:38 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A few drops of oil in the ring grooves, wipe some oil on the skirts. WD40 on the cylinder wall after they have been thoroughly cleaned with ATF.
Doug
Re: assembly lube [Re: dvw] #2891339
02/21/21 10:01 AM
02/21/21 10:01 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
How about the famous Lubriplate ? I have two cans of that that I inherited up
But use it sparingly tsk
NOT like some old fart here that use and aBuSe smilies !
Re: assembly lube [Re: dOrk !] #2891378
02/21/21 11:11 AM
02/21/21 11:11 AM
Washington
madscientist Offline
Washington
Nothing on the rings. Ever.
Wipe the bores with a white lint free cloth and Marvels Mystery oil, ATF or even WD-40 until the cloth comes out clean. Then put NOTHING on the cylinder walls unless you are using Total Seal’s powder or paste or whatever it is.
Then you use a QUALITY assembly lube and just put a light coating on the skirts. Real light. It should just cover the skirts and that’s it.
As you assemble the short block, you will notice that the lube on the skirts will migrate all around the bores, the rings will be LIGHTLY lubricated by that and there isn’t a bunch of oil loaded behind the rings. The engine will fire quickly, won’t smoke and the rings will be 99% seated before the engine runs 5 seconds.
You can see this on the dyno. Instead of the first 10-12 pulls showing big power gains as the rings come in, the power will be relatively stable as you begin your dyno work.
I use Torco assembly lube for everything. I never use oil. There is a separate cam lube and engine assembly lube. I don’t like assembly lubes that look like grease or pastes except for flat tappets.
Re: assembly lube [Re: madscientist] #2891397
02/21/21 11:31 AM
02/21/21 11:31 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
STP on bearings. Oil on everything else
Re: assembly lube [Re: dOrk !] #2891406
02/21/21 11:53 AM
02/21/21 11:53 AM
Alberta
440_Offroader Offline
Alberta
If you don't run your engine right after assembly, it turns yellow and hardens. So much for lubrication there. I haven't used lubricate in years...
Re: assembly lube [Re: 440_Offroader] #2891461
02/21/21 01:09 PM
02/21/21 01:09 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
LUBRIPLATE ? turns yellow and hardens ??
Re: assembly lube [Re: madscientist] #2891471
02/21/21 01:29 PM
02/21/21 01:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Rings go on the pistons dry. But I do make the face of them wet while doing the same to the skirt just before dropping it in the hole. I just don't want anything to be dry as a popcorn fart while assembling, rotating or on start up.
