543 stroker kit update #2891152
02/20/21 05:27 PM
02/20/21 05:27 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Some people asked me to do a little progress update on the 543 stroker build from 440 Source. I have made a bit of progress with my limited time and thought I'd put together a video series showing what you get in the kit and walk through the build highlighting the differences between a stock style rebuild and stuffing a 4.5" crank in there.
At the present, I've fit the rotating assembly, torn it back down, ground the block for clearance, and gave it a good cleaning.
My Edelbrock heads went out for porting in January and I'm expecting them back soon. The custom cam is here (thanks Dewayne). I'm waiting on a few more parts to get here before I can start final assembly.
- Stu Harmon
Re: 543 stroker kit [Re: feets] #2891157
02/20/21 05:56 PM
02/20/21 05:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looking good.
Re: 543 stroker kit update [Re: feets] #2891169
02/20/21 06:21 PM
02/20/21 06:21 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
That was cool.
Carl Kessel
Re: 543 stroker kit update [Re: feets] #2891486
02/21/21 01:58 PM
02/21/21 01:58 PM
moparx Offline
moparx  Offline
nice video feets ! up
beer
Re: 543 stroker kit update [Re: moparx] #2892257
02/23/21 01:39 PM
02/23/21 01:39 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I used to think my kids were weird for watching unboxing videos and it just hit me I'm doing the exact same thing, albeit with much more expensive toys. lol
This is great stuff.
Are your videos going to cover installation into the car too?
Re: 543 stroker kit update [Re: MarkZ] #2892289
02/23/21 02:41 PM
02/23/21 02:41 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The idea is to cover things that change when building a stroker. I've got it going back together now. The video showing the block work has been done and needs editing.
I plan on continuing the videos through engine dyno testing and some after it is installed.
- Stu Harmon
Re: 543 stroker kit update [Re: feets] #2892307
02/23/21 03:07 PM
02/23/21 03:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good job.
I'd be interested to know what the as-delivered wrist pin clearance is, if you have a minute.
This is done very roughly, but maybe it will help later:
https://youtu.be/7gAK3LaDfAc
Rich H.
Esse Quam Videri
Re: 543 stroker kit update [Re: ZIPPY] #2892610
02/24/21 10:31 AM
02/24/21 10:31 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Originally Posted by ZIPPY
Good job.
A wee bit late. biggrin
I've hung the pistons already. The pins were fit very nicely on the pistons, naturally. Rods were a bit tight. I made a flap wheel from a 1/4" rod and 2000 grit paper and eased them out to size.
Some spirolox dropped right in. Others put up a fight.
- Stu Harmon
Re: 543 stroker kit update [Re: feets] #2892823
02/24/21 07:31 PM
02/24/21 07:31 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Good job.
I don't believe I'da said that out loud...
Kevin
Re: 543 stroker kit update [Re: Twostick] #2893043
02/25/21 02:33 PM
02/25/21 02:33 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Good job.
Kevin
It's not a big deal, assuming you're talking about the rods.
The pins would start going inon one side of the rod but would not pass through. I took a 1/4" rod and slit the end with a Dremel. A little piece of 2000 grit microfine paper was put into the slot and I chucked the rod in my mill.
I spun the 2000 grit at 1500 rpm and used it to ease a .0001" or two out of the rod. It is a very low pressure operation with a very slow material removal rate. The pins now fit the rods perfectly.
Each rod had a tight side. It is surely a result of them pressing in the bronze bushing.
- Stu Harmon
Re: 543 stroker kit update [Re: feets] #2893254
02/26/21 12:00 AM
02/26/21 12:00 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
That’s a nice review👍
China is the enemy.
Re: 543 stroker kit update [Re: 1972CudaV21] #2893282
02/26/21 08:13 AM
02/26/21 08:13 AM
Land of the Brave, Home of the...
63CandyMatic Offline
Looking good feets. Will be a fun assembly and build to observe.
Thanks for taking time to document and post it.
Re: 543 stroker kit update [Re: feets] #2893408
02/26/21 03:05 PM
02/26/21 03:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good job.
Kevin
Wow. Appreciate the honest response. I hope it works out and you have a good engine.
Seems like it would be really difficult to get the bores straight but maybe just taking your time,having a good feel for it, measuring and not cutting too much material would do it.
Knowing you have all that and more going on, I'm sure it will be fine.
Me, I have always paid a professional for pin fit, since most everywhere I work with has a Sunnen rod hone and they can do a good job for not much cost to get it corrected.
On the handful I have had done, they have usually start out either interference fit like yours was, or the parts will just slip together
and "seem okay" but end up with inadequate clearance when measured.
Good luck with the beast.
Rich H.
Esse Quam Videri
Re: 543 stroker kit update [Re: ZIPPY] #2933171
06/14/21 12:20 PM
06/14/21 12:20 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Just finished up the videos, some good info in there on the kits. I did not know that the pistons are not a zero deck style for the application in a 440
Were you able to manage fitting an internal pickup? Or are you forced to external?
Re: 543 stroker kit update [Re: feets] #2933327
06/14/21 08:42 PM
06/14/21 08:42 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Eagle rods were the same, I don't think they are using a mandrel and temperature difference to put the bushings in. In the field on compressor jobs,we use a mandrel and hammer to put brass bushings in aluminum rods, I just warm the rod end and tap them in and I don't get the one tight side phenomena the eagles had, which was a very thin ridge of material on one side. I just used a swivel pipe reamer to knock the thin ridge down and it was good after that.
