Re: Come on ... BE HONEST...what do you properly TORQUE... ?
[Re: dOc !]
#2890806
02/19/21 11:19 PM
02/19/21 11:19 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Pretty much just cam sprockets, bearing caps and head bolts. But with over 45 years as an auto mechanic I have a pretty good feel for things.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Stanton]
#2890915
02/20/21 10:51 AM
02/20/21 10:51 AM
Posts: 10,698 North Dakota
6PakBee
North Dakota
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop.
[Re: 5thAve]
#2890987
02/20/21 12:57 PM
02/20/21 12:57 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Head bolts, rod bolts, main caps, rockers shaft bolts, etc. Don't think I've ever torqued intake bolts, oil pan bolts or anything on the front of the motor for that matter. I'm anal about the tightening sequence though.
[Re: moparjim79]
#2891056
02/20/21 02:37 PM
02/20/21 02:37 PM
Guitar Jones
Incremental is the way it should be done and the way I like to do it, but let 's face it, unless this is a high performance car it probably isn't going to matter. There is a difference between a race engine and a stock daily driver. For instance, for a driver just torquing rod bolts is fine, for a race engine, the bolt stretch method should be mandatory.
[Re: dOc !]
#2891099
02/20/21 03:47 PM
02/20/21 03:47 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since the OP wasn't engine-specific, don't forget lug nuts.
[Re: 6PakBee]
#2891132
02/20/21 04:35 PM
02/20/21 04:35 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop. About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2891198
02/20/21 08:30 PM
02/20/21 08:30 PM
Posts: 3,068 Michigan
A727Tflite
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop. About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws. Just like the vehicle assembly plants - they use DC nut runners on everything. And the manufacturing plants use them too along with “multiples”.
[Re: Hemi_Joel]
#2891223
02/20/21 09:27 PM
02/20/21 09:27 PM
Posts: 1,402 Central Pa
moparjim79
Central Pa
[/quote] About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws. [/quote] That was awesome
[Re: cudaman1969]
#2891253
02/20/21 10:59 PM
02/20/21 10:59 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
45 years ago couldn’t keep oil pan bolts from coming lose or falling out on the race car, on a whim I looked in a service manual, used the torque and never came lose again. Long story short I torque EVERYTHING I can get to at factory spec. I used to have trouble with transmission pans. After I found we had an inch pound wrench I used the spec, typically 12 in lbs, found it took several rounds to get them all tight at once, no more leaks.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: poorboy]
#2891295
02/21/21 02:55 AM
02/21/21 02:55 AM
Posts: 43,099 Bend,OR USA
Cab_Burge
I remember a older Service station mechanic telling me that he had calibrated elbows on most tightening he did on cars in that stations bays. I will use a inch lb. torque wrench and convert the lighter ft. lbs. into inch lbs. like using 23 Ft. Lbs. on 5/16 bolts, 23x12=276 inch lbs. 20x12=240 + 3x12=36. 36+240= 276
[Re: 6PakBee]
#2891345
02/21/21 10:15 AM
02/21/21 10:15 AM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I’m surprised.... NO one mentions the critical torque spec of the ...... Muffler bearing Maybe the from Bend oVeR can check in
[Re: dOc !]
#2891348
02/21/21 10:19 AM
02/21/21 10:19 AM
Posts: 13,571 md
mopars4ever
md
I find a correlation between the lack of using a torque wrench and leaky valve covers and oil pans. Quite the opposite for me. They are the only ones I have found that needed hand tightening instead of a torque wrench. All seemed to be too loose.
[Re: dOc !]
#2891413
02/21/21 11:57 AM
02/21/21 11:57 AM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
I use a torque wrench on all mechanical assemblies where I can actually gain enough clearence to do so. When I can't, it bothers me!
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: mopars4ever]
#2891628
02/21/21 07:44 PM
02/21/21 07:44 PM
Posts: 6,220 nowhere
Sniper
nowhere
I find a correlation between the lack of using a torque wrench and leaky valve covers and oil pans. Quite the opposite for me. They are the only ones I have found that needed hand tightening instead of a torque wrench. All seemed to be too loose. I'm thinking of the ones reefed down so hard that they warp the rails and never seal. Both ends of the spectrum are bad.
[Re: 3hundred]
#2891783
02/22/21 10:18 AM
02/22/21 10:18 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Same here, oil pans and valve covers too.
[Re: justinp61]
#2891801
02/22/21 10:48 AM
02/22/21 10:48 AM
MarkZ
Worthy
Worthy
Same here, oil pans and valve covers too. Type of pan/cover and gasket probably matters as well. If you're using a cork gasket with a stamped steel cover, then torque spec is crucial. I've been using cast aluminum covers/pans with anti-crush gaskets now for years and don't have any issues with hand tightening. Still using a stamped oil pan, but for that I bought Andy's pan reinforcements.
[Re: justinp61]
#2891908
02/22/21 03:42 PM
02/22/21 03:42 PM
Posts: 12,225 Looking for a way out of Middl...
IMGTX
Same here, oil pans and valve covers too. #1 important thing for pans and covers is clean and check them with a straight edge. Too many gorillas work on the car before me and think tighten it until it bends the wrench and the pan. For trans/oil/valve covers I do not use anything bigger than a 1/4" drive ratchet. Same thing with plastic intakes. I do follow the gasket manufacturers recommendation about sealant but if it doesn't have specs I do this. Trans pans I oil both sides of the gasket and snug repeatedly in a crisscross pattern until it feels good or the gasket starts to just barely squeeze out. Oil pan I spread a thin thin smear of sealant on both sides of the gasket and snug repeatedly in a crisscross pattern until it feels good or the gasket starts to just barely squeeze out. Valve covers, I use sealant on the valve cover side of the gasket and oil on the bottom of the gasket then snug then repeatedly in a crisscross pattern until it feels good or the gasket starts to just barely squeeze out. If I have a leak I snug a little more but that doesn't happen often and it is usually when a center bolt valve cover has been bent in the middle. The most important thing is to do what works best for you.
[Re: 360view]
#2891951
02/22/21 06:18 PM
02/22/21 06:18 PM
Posts: 21,814 Kirkland, Washington
Pacnorthcuda
Keep a “fisherman’s scale” in your tool box and every wrench becomes a torque wrench. IF you factor the length of the wrench into the calculation!
[Re: NANKET]
#2893237
02/25/21 11:08 PM
02/25/21 11:08 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
I can usually tell what torque to apply after many many years of experience as well, however, every one of the front suspension bolts on my current '69 Barracuda restoration are torqued to spec. Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: Sniper]
#2893319
02/26/21 10:40 AM
02/26/21 10:40 AM
6PakBee
North Dakota
Anyone that thinks they can tell how tight something is torqued "by hand" is fooling themselves.
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head.
[Re: 6PakBee]
#2893374
02/26/21 01:17 PM
02/26/21 01:17 PM
IMGTX
Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. I'm about to do that on a 440 Chrysler 300. My plan was a plumbing bar clamp. I would be very interested in his way.
[Re: Sniper]
#2893392
02/26/21 02:17 PM
02/26/21 02:17 PM
Posts: 4,941 WI
Dcuda69
WI
Yep! Our Snap on guy did a demo for our classes at school. None, I mean NONE of us were right on and that includes a few of us with 30+ years turning wrenches. Like I said earlier....new stuff is WAY different than stuff built 50 years ago. If you're not torquing stuff you're begging for come backs.
[Re: 6PakBee]
#2893393
02/26/21 02:20 PM
02/26/21 02:20 PM
Sniper
nowhere
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. Maybe you need to go back and reread how to set front wheel bearing preload. Having just converted my 51 from the original style setup to the later style, such as used in 74, there is no torque on the bearings when you are done.
[Re: IMGTX]
#2893395
02/26/21 02:27 PM
02/26/21 02:27 PM
6PakBee
North Dakota
Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. I'm about to do that on a 440 Chrysler 300. My plan was a plumbing bar clamp. I would be very interested in his way. IIRC what Vern did was use a bar and a block of wood against the firewall. Took a punch and, in combination with the bar, pressed on a side of the plug to turn it sideways. He then pulled it out with a smaller bar. Cleaned the bore up with some abrasive cloth (as I remember this was the worst part), then used a socket and the bar/wood combo to press the plug in. He was leveraging everything off the firewall using the wood block as a spreader. I can't remember him disconnecting the kickdown linkage or the throttle linkage but he must have as this was the driver's side head. This was a mid 60's Chrysler wagon if my memory isn't totally crap today.
[Re: Sniper]
#2893397
02/26/21 02:30 PM
02/26/21 02:30 PM
Pacnorthcuda
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. Maybe you need to go back and reread how to set front wheel bearing preload. Having just converted my 51 from the original style setup to the later style, such as used in 74, there is no torque on the bearings when you are done. The procedure still involves a torque spec to arrive at the desired result. Unless you are good at doing it without, and many people are.
[Re: Sniper]
#2893435
02/26/21 04:06 PM
02/26/21 04:06 PM
6PakBee
North Dakota
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. Maybe you need to go back and reread how to set front wheel bearing preload. Having just converted my 51 from the original style setup to the later style, such as used in 74, there is no torque on the bearings when you are done. I couldn't find a '74 manual online but this is the procedure from the '73 manual.
[Re: jlatessa]
#2893499
02/26/21 07:57 PM
02/26/21 07:57 PM
RealWing
Ontario, Canada
Yes it is homemade. I attached a photo. If you need some measurements, let me know. Jim
[Re: jlatessa]
#2893540
02/26/21 10:36 PM
02/26/21 10:36 PM
RealWing
Ontario, Canada
Yes, thanks, a couple of dimensions will save me some time. Do the two tabs in front locate in the k frame?
Thanks again, Joe The 2 vertical pieces fit alongside the oil pan and support the engine/K Frame on the oil pan flange. US Car tools has one which is somewhat similar and locates in the K Frame http://store.uscartool.com/Mopar-K-Frame-Stand-Drivetrain-Restoration-Tool_p_84.html
[Re: jlatessa]
#2893773
02/27/21 04:02 PM
02/27/21 04:02 PM
RealWing
Ontario, Canada
Thanks again, Joe Some more photos and dimensions
[Re: 6PakBee]
#2895411
03/03/21 09:48 PM
03/03/21 09:48 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
I I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again . A front wheel bearing is unique. You are compressing 2 tapered wheel bearings. There IS a spot where they get tightened to and most of us can easily find it. Even the range from too loose there is backlash to too tight and it's hard to turn is pretty close to each other. Anything that crushes a gasket like in the engine not only gets torqued to spec but a pattern is important. Rod bolts stretch when torqued properly, also important. I always torque U bolts to rear housing too, it's not as tight as most of you "by feel" think it is. Every wheel and every suspension fastener and if it's crushing a sleeve, at ride height.
