Marvel Mystery Oil Actually Works!
#2889387
02/16/21 08:27 PM
02/16/21 08:27 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
So I had a noisy lifter that would come and go. It ticked about 90 percent of the time and I figured a lifter or even a cam and lifter job was in order. What the hell I said, let me try some of this snake oil stuff, right? Even the name, "Marvel Mystery Oil" can be a synonym for Snake Oil but behold, I dumped a quart into my motor and like magic, the tick went away after 15 minutes. I let the motor cool down, then restarted and no tick. I let the motor Idle for close to an hour with periodic romps on the pedal and still no tick. This stuff has been around forever and I can't believe I didn't try it sooner. I am now a believer.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Marvel Mystery Oil Actually Works!
[Re: RSI700VIPER]
#2889416
02/16/21 09:04 PM
02/16/21 09:04 PM
Posts: 1,402 Central Pa
moparjim79
Central Pa
So I had a noisy lifter that would come and go. It ticked about 90 percent of the time and I figured a lifter or even a cam and lifter job was in order. What the hell I said, let me try some of this snake oil stuff, right? Even the name, "Marvel Mystery Oil" can be a synonym for Snake Oil but behold, I dumped a quart into my motor and like magic, the tick went away after 15 minutes. I let the motor cool down, then restarted and no tick. I let the motor Idle for close to an hour with periodic romps on the pedal and still no tick. This stuff has been around forever and I can't believe I didn't try it sooner. I am now a believer. Some more information please? Vehicle? Drivetrain?
[Re: 1969ronnie]
#2889481
02/17/21 12:09 AM
02/17/21 12:09 AM
RSI700VIPER
NW New Jersey
yes , and what oil and filter brands and oil weights were you using beforehand ? what are oil change time and mileage intervals . IE , it's only my summer toy car , and the oil + filter is 4 years old because it's only got 2,ooo miles on it . 1971 426 Hemi, 10W-40 Brad Penn motor oil, WIX filter, and yes three season toy like all my cars. What is your point Ron? Regardless if I drive a car 500 miles or 5000 miles per year, I had a sticky lifter and MMO apparently fixed the problem. Saved me a weekend of work and a few hundred dollars of parts,
[Re: elmor353]
#2889507
02/17/21 05:29 AM
02/17/21 05:29 AM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
My grandfather had a small can of it on his workbench. When he passed away I cleaned out his little work area and grabbed it. I usually use it on small motors on RC and scale trains. I haven't tried it on any automotive stuff. I'll keep it in mind.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: 360view]
#2889575
02/17/21 11:24 AM
02/17/21 11:24 AM
RSI700VIPER
NW New Jersey
Best 7 bucks I ever spent. Think I'm going to add some to my other cars as a preventative measure.
[Re: Ray S]
#2889642
02/17/21 02:41 PM
02/17/21 02:41 PM
Posts: 4,707 Florida
BDW
I put a quart in every 20 gallons of gas Never heard of using it in the gas tank, no issues gumming things up?
[Re: ricks_RR]
#2889695
02/17/21 04:46 PM
02/17/21 04:46 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
Stuff is pretty much just basic old ATF.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2889718
02/17/21 06:21 PM
02/17/21 06:21 PM
Posts: 20,748 A collage of whims
topside
A collage of whims
Yeah, I think this was discussed some time back here, and the consensus was something like ATF & a possible solvent or something.
I recall about 20 years ago buying a '58 Plymouth - a warehouse find - that smoked enough (oil) to kill every mosquito in the County. I mean, bad. My buddy, who's actually quite the wrench, old racer, and collector, did an oil change with a bunch of MMO in the mix. Ran the thing for awhile, and it quit smoking. I drove the car around a bit afterward because I couldn't believe it. I'm still amazed by that.
[Re: RSI700VIPER]
#2889775
02/17/21 08:51 PM
02/17/21 08:51 PM
Posts: 149 PINE VALLEY
Ray S
PINE VALLEY
Best 7 bucks I ever spent. Think I'm going to add some to my other cars as a preventative measure. $14 / gal at Wallymart
[Re: mgoblue9798]
#2889832
02/17/21 10:08 PM
02/17/21 10:08 PM
RSI700VIPER
NW New Jersey
Well considering ATF is about the same price as MMO, I'm going with the cool label and great smell!
[Re: Ray S]
#2889843
02/17/21 10:22 PM
02/17/21 10:22 PM
Guitar Jones
ATF doesn't hurt seals, it's oil, very light weight oil. Has additional additives and cleaners but oil none the less.
[Re: Guitar Jones]
#2889891
02/18/21 12:40 AM
02/18/21 12:40 AM
Ray S
PINE VALLEY
ATF doesn't hurt seals, it's oil, very light weight oil. Has additional additives and cleaners but oil none the less. Probably not, but I had ATF swell polyurethane badly due to the additives so am wary...
[Re: 360view]
#2890112
02/18/21 03:24 PM
02/18/21 03:24 PM
Posts: 16,923 NC
440Jim
NC
I was told: “never use one of these Ingersol Rand air impact guns without first squirting Marvel Mystery Oil in the air quick connector.” It worked “Marvelously” for that. Now that is a use I will follow. I have always used "air tool oil" for that. But when my little bottle (with drop stem) is empty, I will refill it with MMO. When I was running Alky injection, I stored the pump during winter by filling it with MMO and putting the pump in a zip lock bag. It helped keep the pump seal from shrinking (drying out).
[Re: Ray S]
#2890152
02/18/21 04:39 PM
02/18/21 04:39 PM
Guitar Jones
ATF doesn't hurt seals, it's oil, very light weight oil. Has additional additives and cleaners but oil none the less. Probably not, but I had ATF swell polyurethane badly due to the additives so am wary... Engine oil will destroy rubber motor mounts and suspension bushings as well. I would imagine it would do the same to polyurethane.
[Re: RJS]
#2890254
02/18/21 08:33 PM
02/18/21 08:33 PM
moparjim79
Central Pa
I had a collapsed lifter in a 350 Buick back in 1980. Threw a quart of Marvel in and in a few hours all was well!! Ron Yep, I had a Aspen with rackety lifters and off the advice of a friend, poured a qrt of trans fluid in. 2 mins run time and all was well. Same results w marvel
[Re: moparjim79]
#2890261
02/18/21 09:05 PM
02/18/21 09:05 PM
Ray S
PINE VALLEY
I had a collapsed lifter in a 350 Buick back in 1980. Threw a quart of Marvel in and in a few hours all was well!! Ron Yep, I had a Aspen with rackety lifters and off the advice of a friend, poured a qrt of trans fluid in. 2 mins run time and all was well. Same results w marvel CD2 Lifter Quiet was the best, but now unobtainium.
[Re: Magnumguy]
#2890976
02/20/21 12:47 PM
02/20/21 12:47 PM
Posts: 15,827 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'd like to try it on a loud lifter car at work. Do you add a quart to an engine, generally speaking? Do you add in place of one quart of oil at oil change, or change oil and refill with same amount of oil called for, plus MMO?
Facts are stubborn things.
[Re: larrymopar360]
#2891122
02/20/21 04:20 PM
02/20/21 04:20 PM
Guitar Jones
Just throw the quart in on top of the normal level. Done it plenty of times, nothing to get scared about Just don't leave it in there. Change the oil and filter after a bit.
[Re: Guitar Jones]
#2891140
02/20/21 05:06 PM
02/20/21 05:06 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Just throw the quart in on top of the normal level. Done it plenty of times, nothing to get scared about Just don't leave it in there. Change the oil and filter after a bit. Ohhhh. Bummer, I can't do that.
[Re: Ray S]
#2891216
02/20/21 09:12 PM
02/20/21 09:12 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm sure it's dirty. 5.7 with over 100,000 miles and I haven't checked idle or engine hours, but for sure very high. Not the best maintenance here. It just came out of fleet for lower rad hose and I think they did oil change while there.
[Re: larrymopar360]
#2891221
02/20/21 09:24 PM
02/20/21 09:24 PM
moparjim79
Central Pa
I'm sure it's dirty. 5.7 with over 100,000 miles and I haven't checked idle or engine hours, but for sure very high. Not the best maintenance here. It just came out of fleet for lower rad hose and I think they did oil change while there. AH HA! Ok, I was waiting for one of these to rear its ugly head-- this will not work on an MDS engine unfortunately, 99% of the time thats just a down right failed lifter usually taking a camshaft with it. And not to start any kind of tinkle match, but I've ram trans fluid and MMO in oil for the duration of the life of said oil until its next change.
[Re: moparjim79]
#2891440
02/21/21 12:36 PM
02/21/21 12:36 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I happen to know this poor car got ran without oil for a period. Damaged oil pan, gasket blew out....long story but it got driven back to shop with oil dumping and had to be out of oil or close to it by time it got back to shop. Nuff said on that. No it was NOT me. After this is when tap tap tap started. And remember, over 100k hard miles and tons of idle and engine hours.
[Re: srt]
#2891498
02/21/21 02:23 PM
02/21/21 02:23 PM
Posts: 19,342 north of coder
moparx
over the years, i have used ATF in several gunked up engines to clean them up. also at oil change time, dump a quart of diesel in the mix, run for a bit, then drain. marvel works good for soaking steel bolts that are stuck in aluminum castings. think penetrating oil.
[Re: srt]
#2891610
02/21/21 07:13 PM
02/21/21 07:13 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Pilots and aviation mechanics (A&P) use it frequently for it's ability to dislodge glaze from cylinders and heads. Remember aircraft are air cooled and meticulously maintained (should be at least). The stuff is basically a lot of mineral oil and some mineral spirits with a little bit of benzene solvents to cut oil that becomes plasticized from high heat (think outside cast iron skille)t. Anyplace you see that crusty black stuff or amber colored buildup n parts when disassembling an engine will be cleaner if you use this stuff in oil and fuel. Using it one needs to stay up on oil change intervals and filter changes. If used on old engines checking the oil pickup screen is a good idea. I recall seeing "experienced" engines that died of oil starvation after the stuff was used and the pickup was plugged solid. Regardless wearing surfaces generally stay clean (cam lobes and lifters, cyl walls, bearings) and the area around ring lands do stay clean. If using synthetic the best I method I recall was to put it in about 1,000 mi before a filter change, repeat every change.
My gut feeling is the benzene solvents really do the work and the mineral oil and spirits thin and mix with the oil to get the solvents into the lube circuits and carry the crud away to the oil filter. Which reminds me use high quality filters so as to trap the crud. I'd dump a quart in if I can catch it shortly before an oil change. I just have to catch it at right time. Fleet guy probably won't do it. IDC, I will. I haven't seen what filters they use, but I'm betting el cheapo. I remember as a kid, my dad pouring small amounts of ATF down carb of slant six, keeping idle up, and telling me it cleaned valves IIRC.
[Re: larrymopar360]
#2891730
02/22/21 01:04 AM
02/22/21 01:04 AM
Ray S
PINE VALLEY
When I first got the RV with 413 it hadn't run in years, I put in 6 qt of cheap oil and did a lot of cleaning: MMO in the intake when hot, and oil, and gas, and every time I shut it down hot I'd flood it with Seafoam then shut it off to cook clean. After 2 bottles of Seafoam and a lot of MMO it idled smooth, and I put a snake cam down the intake and in a spark plug hole to look; the intake had NO carbon left and the piston tops shined.
[Re: larrymopar360]
#2891734
02/22/21 01:30 AM
02/22/21 01:30 AM
Posts: 15,721 Jefferson State
srt
ESYC
ESYC
Jefferson State
I remember as a kid, my dad pouring small amounts of ATF down carb of slant six, keeping idle up, and telling me it cleaned valves IIRC. Brings back memories. As a kid I worked at an gas station where we serviced vehicles regularly. The owner had mix in a oil can of marvel 50% gas 25% and Diesel 25%, or thereabout by eyeball. He had a quart or so mixed up all the time. On crappy running cars we'd put some in a half pint or so plastic bottle with a hole drilled in the cap and squirt that down carb of a running engine about 2,500 rpm "to free up the rings" couldn't do it too fast or engine would stall. Thing was it made plumes of smoke. He had me always call the fire dept before doing a car as there was a lady on the back street that would sometimes call in a fire at the gas station. Poor old lady feared that someday the block would burn down because of the gasoline tanks (underground)..
[Re: srt]
#2892337
02/23/21 04:08 PM
02/23/21 04:08 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I remember as a kid, my dad pouring small amounts of ATF down carb of slant six, keeping idle up, and telling me it cleaned valves IIRC. Brings back memories. As a kid I worked at an gas station where we serviced vehicles regularly. The owner had mix in a oil can of marvel 50% gas 25% and Diesel 25%, or thereabout by eyeball. He had a quart or so mixed up all the time. On crappy running cars we'd put some in a half pint or so plastic bottle with a hole drilled in the cap and squirt that down carb of a running engine about 2,500 rpm "to free up the rings" couldn't do it too fast or engine would stall. Thing was it made plumes of smoke. He had me always call the fire dept before doing a car as there was a lady on the back street that would sometimes call in a fire at the gas station. Poor old lady feared that someday the block would burn down because of the gasoline tanks (underground).. Haha yep I remember tons of smoke when my dad did the ATF down the carb. Seafoam is the other product that I've only heard good things about. Ray S, those are amazing results!
[Re: fc7_plumcrazy]
#2892775
02/24/21 05:26 PM
02/24/21 05:26 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm yet to read instructions on bottle of MMO. Does it instruct to leave-in or dump?
[Re: cudaman1969]
#2893631
02/27/21 10:38 AM
02/27/21 10:38 AM
Posts: 203 Alabama
David1971
Alabama
When added to the crankcase, will Marvel cause seals to leak in a high mileage engine that has previously not leaked? I have always been told never to switch from conventional oil to synthetic for that reason.
Sorry to stray off topic a bit, but has anyone had experience with Rislone Engine Treatment? Is it more aggressive than Marvel?
Thanks, David
[Re: David1971]
#2894261
03/01/21 02:18 AM
03/01/21 02:18 AM
Ray S
PINE VALLEY
Thanks, David I think Rislone is essentially kerosene. I have also poured kerosene in an engine after draining the oil and putting the plug back, then let it dissolve the sludge. But in my 413 I had dropped the pan and cleaned it anyway.
[Re: Ray S]
#2894359
03/01/21 12:38 PM
03/01/21 12:38 PM
Posts: 1,696 central il.
second 70
central il.
Thanks, David I think Rislone is essentially kerosene. I have also poured kerosene in an engine after draining the oil and putting the plug back, then let it dissolve the sludge. But in my 413 I had dropped the pan and cleaned it anyway. My Dad used the old trick of adding a quart of kerosene to crankcase everytime he changed oil. Put it in run it at idle until warm drain oil and filter.
