Re: Shifters
[Re: cesar perez]
#2888975
02/15/21 10:58 PM
02/15/21 10:58 PM
Posts: 2,471 Sydney,Australia
tex013
Sydney,Australia
i like my B&M pro ratchet , with Hurst T handle
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Shifters
[Re: cesar perez]
#2888976
02/15/21 11:02 PM
02/15/21 11:02 PM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I like the B&M Pro Stick in that level of shifter. Basically the same as the Hurst with a better cable.
Winters and T/A are the same piece. Old school, clunky, big...some guys still like them.
Re: Shifters
[Re: cesar perez]
#2889025
02/16/21 03:48 AM
02/16/21 03:48 AM
Posts: 43,295 Bend,OR USA
Cab_Burge
It depends on what you like, you should try and sit in a car with all the types you mention and ask the owners if you can shift without the motor running to see which one you want. Some of the race shifters can be a real pain to shift from park to 1st gear or from any forward gear into reverse or park ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I really liked the early B&M Chrome box cable shifters, simple and easy, reliable but no reverse lock out so they got outlaw by NHRA for drag racing ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I like and use the Winters, Fairbanks and T/A shifters with the rear exit cables ( they're all the same design) in my cars with race 727 tranny with the reverse manual valve body ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: Shifters
[Re: jlatessa]
#2889220
02/16/21 02:11 PM
02/16/21 02:11 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
PPP or M&M are the best. Of your choices a quarter stick.
Re: Shifters
[Re: jlatessa]
#2889233
02/16/21 02:47 PM
02/16/21 02:47 PM
Cab_Burge
The original Fairbanks and Winter 727 shifter, not sure about the current T/A shifters, had the rear exit cable that had a bell crank mounted on the rear of the tranny that shifted from the rear. More better header clearances on them also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I called to order a PPP for my S/P car with a Powerglide tranny and once the total price got to $700.00+ I decided to go with another brand ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
Re: Shifters
[Re: jlatessa]
#2889345
02/16/21 07:11 PM
02/16/21 07:11 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
No bell crank, it comes in similar to how the TA shifter does, mine is also a air shifter. Not sure if they are different than the manual but I would think if they are you could use it w/o using the air shifter function. This is also a reverse manual VB.
Ok
Re: Shifters
[Re: jlatessa]
#2889356
02/16/21 07:25 PM
02/16/21 07:25 PM
cudatom
Massillon, Ohio
CudaTom do they employ a bell crank to reverse the movement or is it integral in the shifter?
Thanks, Joe On my screen the shifter from PPP is the kwick shift I. It should be the 8th diagram (the one after the 727 proflight with the double neutral) the 9th diagram is rear entry w/a standard VB. Hope this helps.
Ok
Re: Shifters
[Re: cudatom]
#2889394
02/16/21 08:38 PM
02/16/21 08:38 PM
Posts: 6,149 Melbourne , Australia
LA360
I have used the Pro Ratchet, from memory the Quarter Stick was pretty similar
Last shifter I bought was a PPP, but I had a hell of a time getting it., which was a common complaint from what I have observed.
The M&M are well stocked from what I have heard
Alan Jones
Re: Shifters
[Re: LA360]
#2889486
02/17/21 01:00 AM
02/17/21 01:00 AM
tex013
Sydney,Australia
The M&M are well stocked from what I have heard 1/4 stick is a gate not ratchet i believe Tex
Re: Shifters
[Re: tex013]
#2889553
02/17/21 10:34 AM
02/17/21 10:34 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I tried a Cheetah Shifter, I'd pull from first to third. Hated it. Went with a B&M Pro Ratchet, loved it it but the pot metal arm broke in the staging lanes. I've since fixed that...So far so good.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: Shifters
[Re: Adobedude]
#2889559
02/17/21 10:45 AM
02/17/21 10:45 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I have had a T/A Cheetah in my car for over 35 years now with 0 problems and it still has the original cable. I recently looked into installing a Shiftnoid electric assist setup to my T/A but it can't be done because of the way the shifter gates are. They do make an air assist setup for my application however I dont want to go thru that as its only legal in one of the two classes I regularly run. If I was starting over I would go with a PPP. Lever attached to the shifter is a DD adjustable starting line RPM controller, I can stage the car without looking at the tach. I just installed it last fall and it works great !!!
