Shifters #2888967
02/15/21 10:27 PM
02/15/21 10:27 PM
florida dade
cesar perez Offline OP
florida dade
Whats a better choice in shifter hurst . Quarter shift ....winters or turbo action
Re: Shifters [Re: cesar perez] #2888975
02/15/21 10:58 PM
02/15/21 10:58 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i like my B&M pro ratchet , with Hurst T handle
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Shifters [Re: cesar perez] #2888976
02/15/21 11:02 PM
02/15/21 11:02 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I like the B&M Pro Stick in that level of shifter. Basically the same as the Hurst with a better cable.
Winters and T/A are the same piece. Old school, clunky, big...some guys still like them.
Re: Shifters [Re: cesar perez] #2889002
02/15/21 11:58 PM
02/15/21 11:58 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
race car or street car
manual or auto vb
forward or rev pattern ?
Re: Shifters [Re: cesar perez] #2889025
02/16/21 03:48 AM
02/16/21 03:48 AM
It depends on what you like, you should try and sit in a car with all the types you mention and ask the owners if you can shift without the motor running to see which one you want.
Some of the race shifters can be a real pain to shift from park to 1st gear or from any forward gear into reverse or park scope
I really liked the early B&M Chrome box cable shifters, simple and easy, reliable but no reverse lock out so they got outlaw by NHRA for drag racing shruggy
I like and use the Winters, Fairbanks and T/A shifters with the rear exit cables ( they're all the same design) in my cars with race 727 tranny with the reverse manual valve body up
Re: Shifters [Re: cesar perez] #2889059
02/16/21 09:34 AM
02/16/21 09:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have no love for the museum piece T/A shifter so I’d go with your other choice..... even though I’d throw em both out for my PPP.
Re: Shifters [Re: J_BODY] #2889094
02/16/21 11:02 AM
02/16/21 11:02 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
PPP hands down....with rear entry cable.
Re: Shifters [Re: Dragula] #2889217
02/16/21 02:07 PM
02/16/21 02:07 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Do any shifters have their cables come in to the shift lever on the trans (727 reverse manual)
from the rear?
I assumed the rear entry option was so, but looking on PPP's ad, the the cable comes in to the front of the trans
on both cable exit options.
Our 70 Charger has the B&M Ratchet front cable,
On the 71 RR I would love to avoid snaking another cable over and around everything...
Thanks, Joe
Re: Shifters [Re: jlatessa] #2889220
02/16/21 02:11 PM
02/16/21 02:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
PPP or M&M are the best. Of your choices a quarter stick.
Re: Shifters [Re: jlatessa] #2889233
02/16/21 02:47 PM
02/16/21 02:47 PM
The original Fairbanks and Winter 727 shifter, not sure about the current T/A shifters, had the rear exit cable that had a bell crank mounted on the rear of the tranny that shifted from the rear. More better header clearances on them also up
I called to order a PPP for my S/P car with a Powerglide tranny and once the total price got to $700.00+ I decided to go with another brand work scope
Re: Shifters [Re: jlatessa] #2889255
02/16/21 03:43 PM
02/16/21 03:43 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Both my TA and PPP shifters come in from the rear on a 727.
Ok
Re: Shifters [Re: cudatom] #2889272
02/16/21 04:04 PM
02/16/21 04:04 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
CudaTom do they employ a bell crank to reverse the movement or is it integral
in the shifter?
Thanks, Joe
Re: Shifters [Re: cesar perez] #2889286
02/16/21 04:25 PM
02/16/21 04:25 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I used a Hurst ratchet shifters for years until the cable finally got to hot one day (Was breaking in a new cam and didn't think to put a fan to blow air at bottom of car.) I than put a Turbo Action shifter in since it's a rear cable entry. I love the rear cable entry, but I prefer the ratchet shifter over the gate style. I've been wanting to try a PPP shifter, but can't justify spending that much on a shifter when I don't need it at the moment.
Re: Shifters [Re: jlatessa] #2889345
02/16/21 07:11 PM
02/16/21 07:11 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
No bell crank, it comes in similar to how the TA shifter does, mine is also a air shifter. Not sure if they are different than the manual but I would think if they are you could use it w/o using the air shifter function. This is also a reverse manual VB.
Ok
Re: Shifters [Re: jlatessa] #2889356
02/16/21 07:25 PM
02/16/21 07:25 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
in the shifter?
Thanks, Joe
On my screen the shifter from PPP is the kwick shift I. It should be the 8th diagram (the one after the 727 proflight with the double neutral) the 9th diagram is rear entry w/a standard VB. Hope this helps.
Ok
Re: Shifters [Re: cudatom] #2889394
02/16/21 08:38 PM
02/16/21 08:38 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have used the Pro Ratchet, from memory the Quarter Stick was pretty similar
Last shifter I bought was a PPP, but I had a hell of a time getting it., which was a common complaint from what I have observed.
The M&M are well stocked from what I have heard
Alan Jones
Re: Shifters [Re: LA360] #2889450
02/16/21 10:21 PM
02/16/21 10:21 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Before you go PPP, use the search! I was pissed when I paid for the transmission bracket (blanket) that had no chance of working. You WILL have to make your own bracket.
Re: Shifters [Re: LA360] #2889486
02/17/21 01:00 AM
02/17/21 01:00 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
1/4 stick is a gate not ratchet i believe
Tex
New best MPH 130.32
Re: Shifters [Re: tex013] #2889553
02/17/21 10:34 AM
02/17/21 10:34 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I tried a Cheetah Shifter, I'd pull from first to third. Hated it.
Went with a B&M Pro Ratchet, loved it it but the pot metal arm broke in the staging lanes. I've since fixed that...So far so good.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Shifters [Re: Adobedude] #2889559
02/17/21 10:45 AM
02/17/21 10:45 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have had a T/A Cheetah in my car for over 35 years now with 0 problems and it still has the original cable. I recently looked into installing a Shiftnoid electric assist setup to my T/A but it can't be done because of the way the shifter gates are. They do make an air assist setup for my application however I dont want to go thru that as its only legal in one of the two classes I regularly run. If I was starting over I would go with a PPP. Lever attached to the shifter is a DD adjustable starting line RPM controller, I can stage the car without looking at the tach. I just installed it last fall and it works great !!!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
