Re: Fan Belt Keeps Coming Off [Re: John_Kunkel] #2894750
03/02/21 11:40 AM
03/02/21 11:40 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Is it a stock lower crank pulley? Or a smaller diameter aftermarket??
Re: Fan Belt Keeps Coming Off [Re: QuickBpBp] #2894753
03/02/21 11:46 AM
03/02/21 11:46 AM
central il.
second 70 Offline
second 70  Offline
central il.
GSMopar couldn't keep a belt on his new hemi build and I told him I changed to a TopCog belt on my hemi and no more problem. He bought one and it solved his too he's running low 10's.
Re: Fan Belt Keeps Coming Off [Re: second 70] #2894869
03/02/21 04:03 PM
03/02/21 04:03 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Could be that the reduction in mass helps that design work better at higher RPMs??
Joe
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2894893
03/02/21 04:37 PM
03/02/21 04:37 PM
Minn
SportF Offline
SportF  Offline
Minn
One thing that hasn't been mentoined yet is, once a belt comes off, its probably internally damaged and wants to come off again. I threw a belt at the track, put it back on, and made another pass. Checked it and it was still on, but now "V" up instead of down. New belt and its been years.
Re: Fan Belt Keeps Coming Off [Re: SportF] #2894936
03/02/21 06:23 PM
03/02/21 06:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
this is simple and works for me.
Re: Fan Belt Keeps Coming Off [Re: second 70] #2894945
03/02/21 06:54 PM
03/02/21 06:54 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
What I noticed is that the DAYCO Top Cog belt sits fully down in the pulleys when compared to the other standard v-belts.
It could be that the DAYCO Top Cog belt is actually narrower and actually the correct width since others have said that the standard generic v-belts belts available now are a wider width.
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2895097
03/03/21 06:10 AM
03/03/21 06:10 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I thought many original belts were 11/32", just slightly narrower than 3/8"?
Not original, 136 Amp Denso on the 500" stroker for the '71 Charger using March crank and water pump pulleys.
I have had the engine at 7,000+ RPM (I think 7,200 on the chassis dyno) and no problems with the belt setup.
Re: Fan Belt Keeps Coming Off [Re: lewtot184] #2895104
03/03/21 07:40 AM
03/03/21 07:40 AM
BDW Online content
BDW  Online Content
That's pretty slick, what's that bracket from?
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2895105
03/03/21 07:48 AM
03/03/21 07:48 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I chased a belt issue for longer than I care to admit and it ended up being due to a wonky bolt hole. You'd torque it down and right at the end it would kick the alternator bracket out. I had to grind a spacer out of flat and never had another issue. It was so minimal you'd never would have guessed but it was enough. I believe the added friction, and thus the added heat, attributed to a premature alternator failure.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Fan Belt Keeps Coming Off [Re: BDW] #2895111
03/03/21 08:27 AM
03/03/21 08:27 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i just fabbed it up. been using something like that since the late '60's. that's a fat belt in the photo and they're not the best for rpm. a 5/16" wide belt is more user friendly.
Re: Fan Belt Keeps Coming Off [Re: lewtot184] #2895133
03/03/21 09:43 AM
03/03/21 09:43 AM
USA
K
Kippy Offline
Kippy  Offline
K
USA
One of your pulleys is bent, its not running true. At higher RPM it can and throw a belt. It can be hard to see by eye but if you've checked all the obvious this could be your problem.
It happened to me and drove me nuts until I checked and replaced the harmonic balancer pulley.
Re: Fan Belt Keeps Coming Off [Re: lewtot184] #2895406
03/03/21 09:31 PM
03/03/21 09:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Fan Belt Keeps Coming Off [Re: TJP] #2895685
03/04/21 03:10 PM
03/04/21 03:10 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had a 350 in a Camaro that would throw a belt almost every time I drove it. New belts didn't help. It turned out to be a defective alternator pulley. It lined up with the crank and water pump but had a section where it was slightly wider at one point. This was like a flat spotted tire where at that same point every revolution, the belt tension would change just enough to upset the contact and the belt would bounce out of position.
Re: Fan Belt Keeps Coming Off [Re: SportF] #2896490
03/06/21 03:31 PM
03/06/21 03:31 PM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
Originally Posted by SportF
One thing that hasn't been mentoined yet is, once a belt comes off, its probably internally damaged and wants to come off again. I threw a belt at the track, put it back on, and made another pass. Chec[font:Arial Black][/font]ked it and it was still on, but now "V" up instead of down. New belt and its been years.
Whenever a belt rolls over in the pulley, which usually causes it to come off-it was one of the end belts on the slab it came from. It most likely does not have cord all the way thru the belt and should not have been used in the first place. So, when you buy a new V belt, flip it inside out-if there is a taper on the narrow part of the belt, get a different belt.
Re: Fan Belt Keeps Coming Off [Re: lemondana] #2896736
03/07/21 12:23 PM
03/07/21 12:23 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I want to thank everyone for their input. It gave me some ideas for things to check on.
I have used the Dayco top cog belts but that made no difference.
One thing I will try is a smaller crank pulley. The one on the car now is a large diameter.
I have watched the pulleys when the car is running and I didn't see any that were wobbling.
I mentioned earlier that I used a strait edge to align the alternator pulley with the crank and water pump pulleys so I don't think the issue is there.
I will try a smaller crank pulley and possibly a tensioner that I found on Mancini's website.
I will post what I find.
Thanks again for your help!
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2896752
03/07/21 01:17 PM
03/07/21 01:17 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What is difference from stock?
If nothing then something is fubar with what you have. A dial indicator on the pulley while you rotate it by hand will tell you a lot more than your eyeball will. Balancer pulley might be a bit tricky in the car but you ought to be able to do it. Don;t forget to closely check the brackets as well since they could have a crack and while not obvious under a light load could cause the issue.
The factory setup didn't really have a rep for throwing belts. So unless something is bent/broken, you deviated from stock or are spinning it to crazy rpm's it should suffice.
