Page 3 of 5 1 2 3 4 5
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2883724
02/03/21 07:12 PM
02/03/21 07:12 PM
South Dakota
hotairballoonpilot Online work OP
hotairballoonpilot  Online Work OP
South Dakota
More priming and blocking as time and other work allows me. I am using PPG DP90LV epoxy primer. Stuff dries a semi gloss and blocks sands like a surfacer. Stuff works great being able to highlight the very faint low spots. Car is now in all 220 grit and will get 2 coats over everything of the 90LV. I will wet sand that and be ready for paint. Plan is once it is all in LV then I will tackle the few small areas in the engine compartment. Then get things coated in Yellow Blaze PPG Concept color.
146703255_3669996633049678_954227365193233522_n.jpg146093778_3669996759716332_4474458150577330916_n.jpg146756883_3669996993049642_2506627008093899690_n.jpg
Contact Me about AMD Prices
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2883726
02/03/21 07:13 PM
02/03/21 07:13 PM
South Dakota
South Dakota
more
146071639_3669996683049673_7662950709677041327_n.jpg146074444_3669996936382981_2851004830991937263_n.jpg146129452_3669996569716351_7086189747984786713_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2883728
02/03/21 07:16 PM
02/03/21 07:16 PM
South Dakota
South Dakota
I loosely set the body panels. Then seen that they are all able to set I set them out so could block through the edges and not onto the other panels. So if the fender to door lines look off that is the set up.
144790625_3662273333822008_3895282536847655951_n.jpg144781076_3662273400488668_3024980759230806446_n.jpg143540407_3662273470488661_7062083411496523814_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2883729
02/03/21 07:16 PM
02/03/21 07:16 PM
South Dakota
South Dakota
last for now
143540407_3662273470488661_7062083411496523814_n.jpg144859729_3662273527155322_354860856665298931_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2883779
02/03/21 09:31 PM
02/03/21 09:31 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Great progress. Those character lines on the sides of that car, that is not an easy car to block out and get all of those lines looking good.
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2885892
02/09/21 03:36 PM
02/09/21 03:36 PM
South Dakota
South Dakota
into its final priming. blow it apart to wet sand and paint.
147279356_3684262618289746_7486866976759276565_n.jpg148177849_3684262468289761_8459407551248027561_n.jpg148563980_3684262544956420_5134294313022068584_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2885894
02/09/21 03:37 PM
02/09/21 03:37 PM
South Dakota
South Dakota
more
148901353_3684262411623100_3988629887923114868_n.jpg148928973_3684262764956398_7742843255763514192_n.jpg148964342_3684262834956391_2645529879186316509_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2885896
02/09/21 03:37 PM
02/09/21 03:37 PM
South Dakota
South Dakota
more
148677735_3684263031623038_5587352157980606082_n.jpg148493784_3684262974956377_738709272011452842_n.jpg148456861_3684262914956383_4671973313165549816_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2885897
02/09/21 03:38 PM
02/09/21 03:38 PM
South Dakota
South Dakota
last for now
148200557_3684262694956405_2650870042449929733_n.jpg148964342_3684262834956391_2645529879186316509_n.jpg148928973_3684262764956398_7742843255763514192_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2887364
02/12/21 06:44 PM
02/12/21 06:44 PM
South Dakota
South Dakota
deck lid painted underside
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2887365
02/12/21 06:45 PM
02/12/21 06:45 PM
South Dakota
South Dakota
engine compartment painted
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2887366
02/12/21 06:45 PM
02/12/21 06:45 PM
South Dakota
South Dakota
last for tonight
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906953
04/05/21 06:02 PM
04/05/21 06:02 PM
South Dakota
South Dakota
Finally had a few days that I could devote to spraying the entire car after I wet sanded the car. Only things I have left are to paint the deck lid hinges as I originally thought I would paint them when I did the outside and the trunk jams but as I was masking the car off said to heck with it I would paint them separate. Then have the dual mirrors to shoot. Paint is PPG Concept single stage with DCU 2002 clear mixed in the final coats. Will scuff and buff everything then assemble.
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906954
04/05/21 06:02 PM
04/05/21 06:02 PM
South Dakota
South Dakota
more
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906955
04/05/21 06:03 PM
04/05/21 06:03 PM
South Dakota
South Dakota
again
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906956
04/05/21 06:03 PM
04/05/21 06:03 PM
South Dakota
South Dakota
more
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906958
04/05/21 06:04 PM
04/05/21 06:04 PM
South Dakota
South Dakota
more
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906959
04/05/21 06:04 PM
04/05/21 06:04 PM
South Dakota
South Dakota
more
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906960
04/05/21 06:04 PM
04/05/21 06:04 PM
South Dakota
South Dakota
more
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2906961
04/05/21 06:05 PM
04/05/21 06:05 PM
South Dakota
South Dakota
last for now. That's a lot of yellow!
