Page 3 of 5 1 2 3 4 5
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886587
02/10/21 11:06 PM
02/10/21 11:06 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by viperblue72
Harley we ran it on 98 octane just for safe measure. Although dynamic compression is only 8.5 so it may run. Just fine on pump premium.
That's awesome! Congrats!
Interesting that your torque peak is a bit higher rpm than mine. My motor was a bit more square - hp/torque being almost equal.
Re: 511/TrickFlow combo/ UPDATE [Re: markz528] #2886595
02/10/21 11:17 PM
02/10/21 11:17 PM
junction city oregon
V
viperblue72 Offline OP
V
I wonder if it’s the bigger intake. Everything else in our combos are super similar. I did switch to a 1.6 rocker which gave me a few more degrees yet and .683 net lift.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886698
02/11/21 12:04 PM
02/11/21 12:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes you definitely do and there's another who knows how much lurking there. I never get why guys use the baby carbs on motors like yours unless it's a heavy turd......GREAT numbers....
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886704
02/11/21 12:15 PM
02/11/21 12:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
I ran a 337/adapter vs a 440-2/adapter on a 540 years ago.
With the Indy intake the tq peaked at a slightly higher rpm.
On that motor, there was a pretty big disparity in HP between the manifolds, with the 440-2 combo showing 40cfm more air being used at 6500rpm.
However, on a milder 572 street/strip build, tested with the same 4150 carb and spacer, the difference between a 337 and a 440-2 wasn’t as big(15hp), and it didn’t really change where the peaks occurred.
At the very bottom of the pull(3800), the 337 was up almost 30ft/lbs.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886772
02/11/21 02:44 PM
02/11/21 02:44 PM
NC
440Jim Offline
440Jim  Offline
NC
Can’t figure out how to load pics or videos.
Last run we cooled it down to 120 degrees.. Thats when
we made 743hp@6100 and 700tq@5000
When writing a reply, Below "Post Options" on the left is the "Attachment Manager".
A picture of the dyno sheet would be nice.
Congrats on the number. I said 700 would be easy; but you went well past that.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886776
02/11/21 03:04 PM
02/11/21 03:04 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Man, that is impressive. I have a 512 with less compression, less cylinder head, less cam, TF intake, 950 Thumper, 1 7/8 headers that is probably 115 horsepower down from yours.(491 at the tire. 625 crank? maybe?) I've been kicking around the idea of upgrading the top end; heads, cam, intake, Dominator, headers, and this dyno session makes it a lot harder to NOT do it. Although I'm still weighing how it would act in a heavy car with a clutch and a 3.54 gear. shruggy work
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 511/TrickFlow combo/ UPDATE [Re: 440Jim] #2886811
02/11/21 04:29 PM
02/11/21 04:29 PM
V
V
Jim my problem is it’s saying my files are too large. I’m not sure how to change that. I’ll be getting the sheets today and will do my best to post what I can
Re: 511/TrickFlow combo/ UPDATE [Re: Thumperdart] #2886812
02/11/21 04:32 PM
02/11/21 04:32 PM
V
V
Thumper I’ll be getting a hold of you soon. I may still see what you can do with this 1050/4150. From 5500 up the 950 was pulling 1.9”
So it needs more carburetor badly. I’m sure a dominator would easily push it to 760hp.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886826
02/11/21 04:59 PM
02/11/21 04:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
What I do to downsize a file on my phone is email it to myself, and choose one of the smaller size options before I hit “send”.
Then use the new smaller version to post.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886828
02/11/21 05:01 PM
02/11/21 05:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Where exactly was this reading being taken from?
Was there an air turbine being used?
Re: 511/TrickFlow combo/ UPDATE [Re: fast68plymouth] #2886925
02/11/21 09:17 PM
02/11/21 09:17 PM
V
V
Duane I believe it was the back of the carb. He has a air hat but doesn’t use it.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886930
02/11/21 09:22 PM
02/11/21 09:22 PM
V
V
I think I have the the picture posting figured out.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886938
02/11/21 09:39 PM
02/11/21 09:39 PM
V
V
Raw numbers
618BCDC8-385F-4002-B50C-E5F45C536CDB.jpegFCE10907-D8AE-4FE6-A10A-FCE086F17730.jpeg876E398D-871D-415F-9DFD-F38515CB9863.jpegDA1959A0-E09B-45CB-81F4-49E4224B2FDB.jpeg
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886940
02/11/21 09:40 PM
02/11/21 09:40 PM
V
V
Ok guys hopefully this satisfies you. I may have missed a page or two so let me know if there’s anything else you’d like to see.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886943
02/11/21 09:42 PM
02/11/21 09:42 PM
V
V
This should be a little easier to see.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2886969
02/11/21 11:05 PM
02/11/21 11:05 PM
UK
rb446 Offline
rb446  Offline
UK
Excellent result, up our 589 pulled the same 1.9>2.0@5900>6000 with a 950HP, we made max power @only 5500 at 33 deg total and NGK 7's although it pulled to 5900 only losing 2hp. I would go straight to a Thumper BLP Dom with yours with that CR/cam, wouldn't mess with that 4150 if you have room under hood with a spacer and if you got any money left smile
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: 511/TrickFlow combo/ UPDATE [Re: rb446] #2887007
02/12/21 12:58 AM
02/12/21 12:58 AM
V
V
😂 I may have to wait a few paychecks. And I am not sure what will fit under a fiberglass six pack hood on a cuda. I also have to figure out clutch and rear, possibly a cage, driveline, wilwood front brake kit, and more I’m sure 🤣. But I’ll get there as quickly as I can.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2887075
02/12/21 09:14 AM
02/12/21 09:14 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Very nice results. I bet that put a smile on your face. The torque curve is nice and flat too. Looks like it might be able to be fattened up a touch, but who knows. I have a 400-3 that i hand ported the plenum for sale. If your interested PM me.
Re: 511/TrickFlow combo/ UPDATE [Re: viperblue72] #2887151
02/12/21 12:09 PM
02/12/21 12:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
OR a 1000+ cfm 4150......
Re: 511/TrickFlow combo/ UPDATE [Re: Thumperdart] #2887158
02/12/21 12:13 PM
02/12/21 12:13 PM
V
V
That’s why I didn’t bother jetting it up a touch to get more out of it. I knew it needed more carburetor so there was no point seeing how much more I could get with jet changes.
Can you pm me your number dom?!
