Re: motor plate pics
[Re: J_BODY]
#2884571
02/05/21 11:40 PM
02/05/21 11:40 PM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
![[Linked Image]](https://hosting.photobucket.com/images/dd90/miradaus/001(13).jpg) Just added the vac pump last year because all the cool kids have them ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) ....just have to step up in the crank trigger department I take it when you put it in the car you hooked the vacuum pump up to the suction side? Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2884581
02/06/21 12:37 AM
02/06/21 12:37 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Yeah we corrected that.... good eye!
Alt is bolted to the plate. Wish I had a better pict of the bracket. Only part that gets swapped between our two engines.
[Re: J_BODY]
#2885774
02/09/21 09:26 AM
02/09/21 09:26 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Best one I have at the moment...
[Re: J_BODY]
#2885790
02/09/21 09:55 AM
02/09/21 09:55 AM
an8sec70cuda
Yes, it has a DMI low mount kit on it, just hadn't put it back on it yet when that pic was taken. Didn't even realize that, lol.
[Re: an8sec70cuda]
#2885791
02/09/21 09:59 AM
02/09/21 09:59 AM
an8sec70cuda
Found one w/ the alternator...
[Re: HardcoreB]
#2886071
02/09/21 10:14 PM
02/09/21 10:14 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
16 years ago........Vince Impasato and Chuck Millen from Best Machine in Michigan when I flew in on dyno day. The motor plate was definitely a beefy piece.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#2886125
02/10/21 12:39 AM
02/10/21 12:39 AM
Posts: 290 no mans land
racerbychoice
no mans land
do you guys all use mid-plates when you use a motor-plate?
dj
[Re: racerbychoice]
#2886170
02/10/21 06:22 AM
02/10/21 06:22 AM
Posts: 9,894 MI, usa
dvw
MI, usa
No mid plate with mine. but it does have struts on the trans to control fore/aft movement. Doug
[Re: BigFish69]
#2886190
02/10/21 08:57 AM
02/10/21 08:57 AM
Posts: 4,105 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
thanks for the pictures im working with a small block for the first time lot less room to work with then the big blocks height wise. Then kick the plate upward from it's mounting source on the block. If you can see well in my fuzzy pic that's what i did to gain material and again it ties to the upper cage struts.
