Re: 74 360 4 speed Duster V21 hood
[Re: hotairballoonpilot]
#2883724
02/03/21 07:12 PM
02/03/21 07:12 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
More priming and blocking as time and other work allows me. I am using PPG DP90LV epoxy primer. Stuff dries a semi gloss and blocks sands like a surfacer. Stuff works great being able to highlight the very faint low spots. Car is now in all 220 grit and will get 2 coats over everything of the 90LV. I will wet sand that and be ready for paint. Plan is once it is all in LV then I will tackle the few small areas in the engine compartment. Then get things coated in Yellow Blaze PPG Concept color.
Contact Me about AMD Prices
#2883728
02/03/21 07:16 PM
02/03/21 07:16 PM
hotairballoonpilot
South Dakota
I loosely set the body panels. Then seen that they are all able to set I set them out so could block through the edges and not onto the other panels. So if the fender to door lines look off that is the set up.
#2906953
04/05/21 06:02 PM
04/05/21 06:02 PM
hotairballoonpilot
South Dakota
Finally had a few days that I could devote to spraying the entire car after I wet sanded the car. Only things I have left are to paint the deck lid hinges as I originally thought I would paint them when I did the outside and the trunk jams but as I was masking the car off said to heck with it I would paint them separate. Then have the dual mirrors to shoot. Paint is PPG Concept single stage with DCU 2002 clear mixed in the final coats. Will scuff and buff everything then assemble.
