Transmission help 99 Ram
#2884991
02/07/21 10:08 AM
02/07/21 10:08 AM
Posts: 3,159 Md.
carnut68
Md.
Here's the problem. Reverse is slipping when you apply the throttle. It will pull itself from idle on the level on an incline it slips. Trans was rebuilt ,but now has about 40,000 miles on it. Quality parts used. There is no problem with the forward gears, firm shifts. Does this sound like a band adjustment? Fluid is full and bright red no smell. Thoughts/suggestions. A- 518 /46Re behind a 5.2.
America First!
Re: Transmission help 99 Ram
[Re: carnut68]
#2885251
02/07/21 06:38 PM
02/07/21 06:38 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
From 20 mph in Drive, shift it to 1 and see if there is deceleration braking...if none or little, could be rear band adjustment. If deceleration braking is good, could be the OD direct clutch.
[Re: cudaman1969]
#2885862
02/09/21 02:26 PM
02/09/21 02:26 PM
Posts: 3,159 Md.
carnut68
Md.
Thanks. That gives a few things to check.
America First!
[Re: John_Kunkel]
#2887568
02/13/21 11:13 AM
02/13/21 11:13 AM
Posts: 3,159 Md.
carnut68
Md.
From 20 mph in Drive, shift it to 1 and see if there is deceleration braking...if none or little, could be rear band adjustment. If deceleration braking is good, could be the OD direct clutch. So I did the 20 mph shift it has some deceleration ,but not as much as I would expect. I do know the OD clutches where replaced because the guy that rebuilt the trans had to borrow a tool to get the OD apart.
America First!
