window tint glue removal ? #2884088
02/04/21 05:47 PM
02/04/21 05:47 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
the window tint on drivers door pealed off and now glue from the tint is blury , have to rol window down at intersections to see oncoming cars !
what do you use to get this off ?
tried several things even laquer thinner but it just smears around and refuses to come off ?
thank you !
Re: window tint glue removal ? [Re: calrobb2000] #2884090
02/04/21 05:49 PM
02/04/21 05:49 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Use a razor blade. Once done, go back over it with glass cleaner to get any small stuff that's left over.
Re: window tint glue removal ? [Re: parksr5] #2884262
02/05/21 10:15 AM
02/05/21 10:15 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would check with some window tint shops.
I am sure they have to go through that process when they replace the tint on a car.
Re: window tint glue removal ? [Re: 340Cuda] #2884637
02/06/21 09:31 AM
02/06/21 09:31 AM
South-east Mn
blaze Offline
blaze  Offline
South-east Mn
This is what I've used in the past. Spray it on, scrape it all off with a razor blade and paper towels
Re: window tint glue removal ? [Re: blaze] #2884677
02/06/21 12:24 PM
02/06/21 12:24 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Goof off works well with a razor blade.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: window tint glue removal ? [Re: BloFish] #2884707
02/06/21 01:38 PM
02/06/21 01:38 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I used a steamer and a blade. Comes right off.
Re: window tint glue removal ? [Re: calrobb2000] #2884716
02/06/21 02:08 PM
02/06/21 02:08 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
I have removed and cleaned lots, if you want to remove another peice, get under edge with razor blade and pull or if you have compressed air, a blower and blow it off, clean up with foam type window cleaner, lots of it and a razor blade, I have done 4 door glass and a back window like this in under one hour
Re: window tint glue removal ? [Re: Ramtough] #2884764
02/06/21 04:51 PM
02/06/21 04:51 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Windex and razor blade just keep glass wet this is how I've done it in the past
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: window tint glue removal ? [Re: 67mprfan] #2886062
02/09/21 09:41 PM
02/09/21 09:41 PM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
Rubbing alcohol
Re: window tint glue removal ? [Re: EDDIEB] #2886206
02/10/21 10:04 AM
02/10/21 10:04 AM
RWG75
RWG75
Whatever carb / brake cleaner ya got laying around should do it. Spray it on, let it soak, scrap it off, revisit with cleaner on a rag as needed. Not sure I ever used it for window tint but it works for inspection stickers, those big nasty "tow me away" stickers, rear view mirror adhesive......
Re: window tint glue removal ? [Re: ] #3105736
12/26/22 04:54 PM
12/26/22 04:54 PM
FrankUnderwoodd
FrankUnderwoodd
A razor blade is the best in such cases, and a simple windows cleaning solution afterward. It should help.
This is one of the reasons I don’t like tinting – it’s not easily removable and doesn’t look that good when damaged. That’s why I prefer using magnetic fabric sunshades with extensive UV protection in my car. These are easily removable and protect the insides of the vehicle from sun radiation well.
The area where I live is rather gloomy, and sometimes, I want more light in my car. Tinting would make it difficult for me to drive on days that are already too dark to see well.
Re: window tint glue removal ? [Re: BloFish] #3105796
12/26/22 09:24 PM
12/26/22 09:24 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
iagree
Re: window tint glue removal ? [Re: ] #3105809
12/26/22 10:15 PM
12/26/22 10:15 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Well that was certainly helpful...and timely too!
Re: window tint glue removal ? [Re: calrobb2000] #3106062
12/28/22 05:20 AM
12/28/22 05:20 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not sure about window tint glue, but I found that the Hops #9 gun cleaner dissolves many adhesives and is pretty safe on plastics.
Sort of like removing paint with brake fluid.
