Re: 511/TrickFlow combo/ UPDATE
[Re: viperblue72]
#2886587
02/10/21 11:06 PM
02/10/21 11:06 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Harley we ran it on 98 octane just for safe measure. Although dynamic compression is only 8.5 so it may run. Just fine on pump premium. That's awesome! Congrats! Interesting that your torque peak is a bit higher rpm than mine. My motor was a bit more square - hp/torque being almost equal.
[Re: viperblue72]
#2886698
02/11/21 12:04 PM
02/11/21 12:04 PM
Thumperdart
State of confusion
Yes you definitely do and there's another who knows how much lurking there. I never get why guys use the baby carbs on motors like yours unless it's a heavy turd......GREAT numbers....
[Re: viperblue72]
#2886704
02/11/21 12:15 PM
02/11/21 12:15 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I wonder if it’s the bigger intake. I ran a 337/adapter vs a 440-2/adapter on a 540 years ago. With the Indy intake the tq peaked at a slightly higher rpm. On that motor, there was a pretty big disparity in HP between the manifolds, with the 440-2 combo showing 40cfm more air being used at 6500rpm. However, on a milder 572 street/strip build, tested with the same 4150 carb and spacer, the difference between a 337 and a 440-2 wasn’t as big(15hp), and it didn’t really change where the peaks occurred. At the very bottom of the pull(3800), the 337 was up almost 30ft/lbs.
[Re: viperblue72]
#2886772
02/11/21 02:44 PM
02/11/21 02:44 PM
Posts: 16,928 NC
440Jim
NC
Can’t figure out how to load pics or videos. .... Last run we cooled it down to 120 degrees.. Thats when we made 743hp@6100 and 700tq@5000 When writing a reply, Below "Post Options" on the left is the "Attachment Manager". A picture of the dyno sheet would be nice. Congrats on the number. I said 700 would be easy; but you went well past that.
[Re: viperblue72]
#2886776
02/11/21 03:04 PM
02/11/21 03:04 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Man, that is impressive. I have a 512 with less compression, less cylinder head, less cam, TF intake, 950 Thumper, 1 7/8 headers that is probably 115 horsepower down from yours.(491 at the tire. 625 crank? maybe?) I've been kicking around the idea of upgrading the top end; heads, cam, intake, Dominator, headers, and this dyno session makes it a lot harder to NOT do it. Although I'm still weighing how it would act in a heavy car with a clutch and a 3.54 gear.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 440Jim]
#2886811
02/11/21 04:29 PM
02/11/21 04:29 PM
Posts: 2,141 junction city oregon
viperblue72
Can’t figure out how to load pics or videos. .... Last run we cooled it down to 120 degrees.. Thats when we made 743hp@6100 and 700tq@5000 When writing a reply, Below "Post Options" on the left is the "Attachment Manager". A picture of the dyno sheet would be nice. Congrats on the number. I said 700 would be easy; but you went well past that. Jim my problem is it’s saying my files are too large. I’m not sure how to change that. I’ll be getting the sheets today and will do my best to post what I can
[Re: Thumperdart]
#2886812
02/11/21 04:32 PM
02/11/21 04:32 PM
viperblue72
Yes you definitely do and there's another who knows how much lurking there. I never get why guys use the baby carbs on motors like yours unless it's a heavy turd......GREAT numbers.... Thumper I’ll be getting a hold of you soon. I may still see what you can do with this 1050/4150. From 5500 up the 950 was pulling 1.9” So it needs more carburetor badly. I’m sure a dominator would easily push it to 760hp.
[Re: viperblue72]
#2886826
02/11/21 04:59 PM
02/11/21 04:59 PM
fast68plymouth
So. Burlington, Vt.
my problem is it’s saying my files are too large What I do to downsize a file on my phone is email it to myself, and choose one of the smaller size options before I hit “send”. Then use the new smaller version to post.
[Re: viperblue72]
#2886828
02/11/21 05:01 PM
02/11/21 05:01 PM
fast68plymouth
So. Burlington, Vt.
From 5500 up the 950 was pulling 1.9” Where exactly was this reading being taken from? Was there an air turbine being used?
[Re: viperblue72]
#2886969
02/11/21 11:05 PM
02/11/21 11:05 PM
Posts: 570 UK
rb446
UK
Excellent result, our 589 pulled the same 1.9>2.0@5900>6000 with a 950HP, we made max power @only 5500 at 33 deg total and NGK 7's although it pulled to 5900 only losing 2hp. I would go straight to a Thumper BLP Dom with yours with that CR/cam, wouldn't mess with that 4150 if you have room under hood with a spacer and if you got any money left
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: viperblue72]
#2887151
02/12/21 12:09 PM
02/12/21 12:09 PM
Thumperdart
State of confusion
OR a 1000+ cfm 4150......
[Re: Thumperdart]
#2887158
02/12/21 12:13 PM
02/12/21 12:13 PM
viperblue72
OR a 1000+ cfm 4150...... That’s why I didn’t bother jetting it up a touch to get more out of it. I knew it needed more carburetor so there was no point seeing how much more I could get with jet changes. Can you pm me your number dom?!
